Old 09-23-2011, 07:50 AM   #2746
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
Originally Posted by G-RDR View Post
bigdon quote: "My TT tank is plumbed into the bottom of the main tank. Both tanks are vented separately. I have had no problems with the venting."
bigdon,
I've got a TT tank on order. Is the way you have yours plumbed in the way the directions say to do it? (Assuming it comes with instructions.)
Do you have to drill a hole in the main tank? I like the idea of being able to remove the TT tank for shorter trips and just run off the main.
I am trying to get prepared in advance so that I can put the tank on next weekend then do an quick 800 mi trip to NM the following weekend.
Any help anyone can give is appreciated!
(I know this is not addressed to me...but thought I'd contribute)
It does come with instructions, and it does state you need to drill the OEM tank. I didn't do that...I went through the vent PM me your email address and I'll send you a step-by-step that a buddy and I did so we can plumb it right (based on ALL the help from inmates here!)
I do recommend high quality EFI hose (1/4") and clamps (Stainless steel), along with a single quick disconnect (high flow, OMEGA)...
Cheers,
Nadim
Adventurer transitioning from 4x4 to 2x1
'07 G650Xch - Under Mod-struction
DiscoDino is offline   Reply With Quote
Old 09-23-2011, 08:19 AM   #2747
bigdon
Oddometer: 2,642
My tank was installed using the TT supplied directions. I had the dealer install. I called and got a price quote and thought that would be the way to go as I did not have time to do it. I think they quoted roughly $300 to install. When I picked it up the bill was $700. I was pissed and will not use that dealer again.
My tank was installed using the TT supplied fuel lines and petcocks which are junk when used with the gas that is available in Texas. The petcocks started leaking in just a few weeks and the fuel lines started to leak in 4-6 months.
DO NOT I repeat DO Not use the supplied stuff.
I had to remove the stock tank to be able to change out the fuel lines.I also installed Quality Pingle Petcocks at about $70 each.
As far as taking the TT tank off and running the bike. Mine is installed with self sealing quick disconnects. The tank will come off in about 15 minuets . I have never tried to reinstall the stock plastics but would think they will not fit because of the extra mounting points for the TT Tank. It would run but be very ugly!
IMO YMMV
ADV Relay Rider 08 (The Texas Connection)
Ride Pooie Ride
Don't stop riding until you get to the crash , you might save it!
bigdon is online now   Reply With Quote
Old 09-23-2011, 08:03 PM   #2748
G-RDR
gedubya
G-RDR's Avatar
Oddometer: 44
discodino, I sent you a PM
G-RDR is offline   Reply With Quote
Old 09-23-2011, 08:47 PM   #2749
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
Emailed!
Old 09-25-2011, 01:40 AM   #2750
mcgiggle
Oddometer: 272
camchain rail
I'm wondering wether to rip the engine down and see if the camchain tensioner rail need replacing (30000 miles covered) but looking at what needs to be taken apart I'm now thinking leave alone, what do you think guys?
I know Walter ripped his motor down but I don't recall the rail being replaced or worn.
If I don't do it now that means 70000 miles on the bike before I'm home again.
Cheers
Pete
UK-India-UK 2009/2010
Current trip Buenos Aires-NYC
http://www.facebook.com/curryhunt
mcgiggle is offline   Reply With Quote
Old 09-25-2011, 09:26 AM   #2751
G-RDR
gedubya
G-RDR's Avatar
Oddometer: 44
bigdon, I sent you a PM
Old 09-25-2011, 10:09 AM   #2752
FinnDuro
Winter wonderlanding
FinnDuro's Avatar
Oddometer: 379
I would not worry about it, sounds like a pretty far fetched & more of a theoretical problem scenario to me. Can't think why mere 30.000 miles on Rotax would wear that cam rail down...
Stable: BMW R 80 GS -90, KTM 690 Enduro R -12 // finnduro.com
FinnDuro is offline   Reply With Quote
Old 09-25-2011, 12:45 PM   #2753
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,984
Cheers
Pete
I had no discernible wear on the two plastic rails mate ... so left them alone and didnt replace them
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 09-26-2011, 06:27 PM   #2754
jonnyc21
Trials Ninja
jonnyc21's Avatar
Oddometer: 1,038
Eek TT Tank quick R&R...
IMO YMMV
I agree, after installing my TT tank I can't see where the stock plastics would fit back on the bike. if you wanted to remove it getting the upgraded fuel lines and quick diskconnects would let you do that, but you would likly need a custom cover of some kind or modify the stock plasticks to make them fit with the mounting bracket setup for the TT tank.
Good luck!
jonnyc21 is offline   Reply With Quote
Old 09-26-2011, 11:15 PM   #2755
mcgiggle
Oddometer: 272
Cheers guys, I'm a great believer in if it ain't broken etc etc.
Old 09-27-2011, 06:20 AM   #2756
evanphoto
May G-d bless Evel
evanphoto's Avatar
Oddometer: 415
oil filter
hi all,
going to do my first oil change. what do you guys like for an oil filter? what size? 2007 bmw 650x challenge
"It’s a good feeling when they stand up and fight us. If 10 of them are gonna decide to stand up and fight us, I can tell you 10 of them are gonna die,"
Cpt. Schneider, US Army in Iraq, 2004
evanphoto is offline   Reply With Quote
Old 09-27-2011, 06:54 AM   #2757
cdavisrosco
Oddometer: 124
Originally Posted by evanphoto View Post
hi all,
I buy them from Beemer Boneyard
http://www.beemerboneyard.com/11412343118m.html
They also sell a 4 pack and the crush washers, which is what I buy:
http://www.beemerboneyard.com/oilfilters1.html
http://www.beemerboneyard.com/11412343118m4fcw.html
cdavisrosco is offline   Reply With Quote
Old 09-27-2011, 10:09 AM   #2758
cdavisrosco
Oddometer: 124
BTW, I just listed a new Staintune pipe for the G650X in the Flea Market if anyone is interested ->
http://advrider.com/forums/showthread.php?t=728980
Old 09-27-2011, 05:52 PM   #2759
kclark
1SevenZero
kclark's Avatar
Oddometer: 90
TT Tank
I recently installed the TT Tank. Mine is installed per the instructions. I couldn't picture a reason to remove it for shorter rides. If your worried about the weight of the gas making it heavy in corners on short rides, just don't fill it. Honestly on my recent ride with it filled to capacity I didn't notice it in corners at all. My use is about 70% dirt (single track and double track).
kclark is offline   Reply With Quote
Old 09-29-2011, 08:46 AM   #2760
Niedz
Niedz's Avatar
Oddometer: 635
Oil change question--
I know you are supposed to change the oil with it hot, but why specifically?
If the motor is cold and you drain the crankcase and the reservoir up top, what is the difference hot or cold?
fabrication fun, rack n roll
Niedz is offline   Reply With Quote
Times are GMT -7.   It's 08:44 PM.
