Old 01-13-2012, 06:57 AM   #3061
August West
Wharf Rat
August West's Avatar
Oddometer: 555
[QUOTE=Johnnyboxer;17739339]If you want to save cash...........................make sure it has a nice and bendy steel gear lever from an earlier F650GS/Dakar
It does.
August West screwed with this post 01-13-2012 at 07:04 AM
August West is offline   Reply With Quote
Old 01-14-2012, 01:21 AM   #3062
mcgiggle
Oddometer: 272
Originally Posted by Boughton View Post
Has anyone else experienced the on/off/res valves on the TT tank to leak. I just got an x challenge and it came with a TT tank, however the valves are leaking. I haven't had time to take them apart, I'm assuming maybe just a few dried out o-rings?
Mine's leaked on and off since new :(
I've been thinking about a pair from these guys http://www.pingelonline.com/fuel_valves.htm but propa expensive so haven't got round to it yet!
Cheers
Pete
UK-India-UK 2009/2010
Current trip Buenos Aires-NYC
http://www.facebook.com/curryhunt
mcgiggle is offline   Reply With Quote
Old 01-14-2012, 10:01 AM   #3063
konfucius
konfucius's Avatar
Oddometer: 220
Anyone found adjustable clutch and brake levers for the xchallange?
konfucius is offline   Reply With Quote
Old 01-14-2012, 11:56 AM   #3064
jessehere
Ridin'
jessehere's Avatar
Oddometer: 782
http://www.wunderlichamerica.com/mm5...Category_Code=
But I just use cut down stock levers.
jessehere is offline   Reply With Quote
Old 01-14-2012, 11:56 AM   #3065
cdavisrosco
Oddometer: 124
http://www.wunderlichamerica.com/mot...e/8160658.html
They also sell them individually.
edit - oops, I see two people answered at the same time...
cdavisrosco is offline   Reply With Quote
Old 01-14-2012, 03:11 PM   #3066
imeny
imeny's Avatar
Oddometer: 129
Cool2 levers
Anyone found regular clutch and brake levers ? other than OEM ?
imeny is offline   Reply With Quote
Old 01-14-2012, 03:25 PM   #3067
The Jester
The Jester's Avatar
Oddometer: 848
honda cb500 twin brake lever. 5 pattern part.
Life is not a rehearsal!
The Jester is offline   Reply With Quote
Old 01-14-2012, 09:43 PM   #3068
kiwiAdventure
kiwiAdventure's Avatar
Oddometer: 1,409
Brake pads are expensive for the g650x $77 for font pads
BMW 1200gs 16
BMW 450 enduro 09
kiwiAdventure is offline   Reply With Quote
Old 01-15-2012, 03:06 AM   #3069
Mtrain
free range
Mtrain's Avatar
Oddometer: 440
Try the pads for the yamaha xt660 as they are the same.
Mtrain is offline   Reply With Quote
Old 01-15-2012, 04:22 AM   #3070
Don't shoot me!!!
Snowflakes are cold...
Don't shoot me!!!'s Avatar
Oddometer: 569
Or Ktm 690...
Don't shoot me!!! is offline   Reply With Quote
Old 01-15-2012, 07:35 AM   #3071
Xtreamdirt
Xtreamdirt's Avatar
Oddometer: 10
temperature light
Originally Posted by Xtreamdirt View Post
I cant seem to find a answer to my question through the search function.
When I turn the ignition on all my warning lights goes on (for a couple of seconds like it should) except my temperature light, it never goes on, is that correct or is the bulb faulty?
I'm just scared the bulb(I dont know if it is a bulb, maybe LED) is faulty in that way I wll never know when the bike is overheating.
Xtreamdirt is offline   Reply With Quote
Old 01-15-2012, 08:57 AM   #3072
jjmead1
now THAT"S a bike!
jjmead1's Avatar
Oddometer: 565
Hello all.
I just sold my Country and replaced it with a Challenge. The Challenge has a bad right peg and was wondering if anyone has personal experience with the Pivot Pegs. I need pegs for sure, but was wondering if the Pivot is the way to go. They seem to be within $40 of the other replacements. Pros? Cons?
Thanks.
jjmead1 is offline   Reply With Quote
Old 01-15-2012, 02:07 PM   #3073
The Jester
The Jester's Avatar
Oddometer: 848
Friday 13th
Not normally one for superstition but we had a nightmare on Friday (13th). 2 miles from home I glanced down to see the oil light flash on. Pushing the bike home a neighbour stopped to give me a lift. I hooked the trailer up to the landrover and went to start it - battery flat. After 30 minutes on charge I got it started to find the pipe to the silencer had rusted through. I retrieved the bike and went to work thinking that would be it but my wife came home with her car door handle in her handbag. Arghhhh.
I got to work on the bike today and it is not looking good, although it could have been much worse had I not seen the light come on or taken a chance that it was an electrical issue. Unfortunately I have no oil pressure to the engine. Judging by the fact that the oil tank is also full to the brim, my best guess is the engine oil pump has failed leaving the engine without oil and allowing the scavenger pump to pump all the oil to the tank. Having checked the manual this shouldn't be too major a job as the oil pumps are accessed behind the clutch. It could well be the plastic drive gear has failed as this would seem to be a weak point; if so they will all be replaced. Not having a clutch holding tool, and being up to my eyes in it with other stuff, I am going to hand it to the local dealer this time. I guess my shock is going to have to keep on squeaking for a few more months.
Old 01-15-2012, 03:40 PM   #3074
G-RDR
gedubya
G-RDR's Avatar
Oddometer: 44
Tt tank valves
I read posts from others on this site that you should throw those valves away and buy the Pingles, so that's what I almost did. I have brand new, unused valves that came with my new TT tank because I put the Pingles on from the start.
You will need:
2-Adapter Plates, PT# A1602C
1-Power Flo Valve PT# 2210-AH
1-Power Flo Valve PT# 4210-AH
If you order, confirm your own part numbers! I am old, drink lots of beer, have no memory capacity and am not responsible!
Pingles have 5/16" outlets, so I ran 5/16 fuel injection hose.
No reserve on this particular Pingle Valve, just on/off. Suits me fine cause my TT Tank feeds the top of the stock tank through the top vent port. (Guts removed.) The low fuel indicator works as usual.
If you want to use the strainer screens that come with the Pingles, you have to drill out the existing center hole, (about 7/16" diameter from the factory), for each side fuel valve mount to about 9/16". This is what I did with my cordless drill and a stubby step drill bit, then I finished it off with a 9/16" drill bit in my hand. THERE IS ONLY ABOUT AN INCH OF CLEARANCE TO WORK WITH INSIDE THAT HOLE, AND YOU DO NOT WANT TO DRILL THROUGH THE OTHER SIDE OF YOUR TANK! (No I didn't!) New tanks are around $800 for the complete kit. I don't know if they sell just the tank.
Your looking at about $220 dollar US for the Pingle parts plus shipping.
If you or anyone else is interested in my new TT valves that came with the tank, PM me and maybe we can work a deal. They aren't doing me any good.
I will try to attach a picture on the Pingle on my tank.
Here's the Pingle website again:
G-RDR is offline   Reply With Quote
Old 01-15-2012, 03:51 PM   #3075
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,955
Ah, Jester, what rotten luck. How many miles on that bike now?
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Times are GMT -7.   It's 05:04 AM.
