Old 04-26-2012, 04:11 PM   #3451
cdavisrosco
Oddometer: 124
Both are 10mm hex. (You can get it out with an extension and a H10 socket or a long T-handle)
Originally Posted by orlando_orange View Post
hey everyone i'm changing over the bouncy castle shock for a wilbers and my workshop manual has gone walkabout... so can anyone tell me what the hell head is on the hidden end of the lower shock bolt? and how have people got it out? also while i'm asking, what size hex is the top bolt?
cheers
cdavisrosco is offline   Reply With Quote
Old 04-26-2012, 04:18 PM   #3452
Mtrain
free range
Mtrain's Avatar
Oddometer: 440
Originally Posted by Johnnyboxer View Post
G650X Alloy Subframe M6 threads Rear Rack/Grab Handle Mounts - one of mine has stripped the threads in the alloy subframe
Can someone tell me how to repair?
Is it a M6 RivNut in the box alloy frame?
Or a threaded M6 sleeve?
So is a Helicoil or RivNut the best way to repair and strengthen the stripped thread in the subframe?
Anyone repaired one?
Yeah Ive repaired mine with helicoil thread repairs and it is better than new.
The OEM threaded inserts are welded in so either have to be re tapped or helicoiled.
Mtrain is offline   Reply With Quote
Old 04-27-2012, 01:14 AM   #3453
orlando_orange
deslyxic tepyr
orlando_orange's Avatar
Oddometer: 694
Nice one cheers for that
...waiting for a new bike...
orlando_orange is offline   Reply With Quote
Old 04-27-2012, 03:02 AM   #3454
Johnnyboxer
Oddometer: 1,036
Many thanks, I will do all 4 then with helicoils then to make them stronger
Just wanted to make sure they weren't RivNuts before I strip it down
So many roads...........So little time..!!!
2005 BMW R1150GS Adv - Black
2005 BMW R1150GS Adv - Silver
2007 BMW G650 XCountry - Black
Johnnyboxer is offline   Reply With Quote
Old 04-27-2012, 04:01 AM   #3455
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 6,298
Can they be drilled through to allow the use of nuts and bolts?
2007 BMW GSA for sale.
joenuclear is offline   Reply With Quote
Old 04-27-2012, 09:11 AM   #3456
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,783
Probably not gonna want to do that. We're talking about the alu subframe here. Not if you plan on loading up the subframe with luggage or a pillion rider.
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 04-27-2012, 11:02 PM   #3457
markwoodlief
markwoodlief's Avatar
Oddometer: 3,615
Originally Posted by Tomdog View Post
I want to disable the side stand switch. Been back to page one but switch mod isn't mentioned.
Pulling switch lead from loom disables motor.
I see three wires (red, white, Brown) but what do I do with which?
best reason to disable it, so it doesnt disable you in the woods... I broke mine to pieces last weekend during a particular gnarly section of trail and it left me stranded. I eventually figured out what the issue was, burned the wires and twisted 2 of them together till my fuel pump kicked in again, then i was off.
carnage below..
markwoodlief is offline   Reply With Quote
Old 04-28-2012, 07:33 AM   #3458
slide
A nation in despair
Oddometer: 21,122
BMW used to have the proper answer for the ride off with the sidestand down issue which was to use an auto retracting side stand (spring loaded).
This isn't much of an issue on a bike used wholly on pavement but it can be on a dirt bike. The side stand can deploy during rough riding thus causing the engine to shut off which can be darned inconvenient.
Why be born again when you can just grow up?
slide is offline   Reply With Quote
Old 04-28-2012, 07:48 AM   #3459
plumber mike
Highdive Deepened
plumber mike's Avatar
Oddometer: 3,778
I connected all three wires together. No issues since
2002 Yamaha PW80 don't break it dad!
1996 Honda XR250R just right.
plumber mike is offline   Reply With Quote
Old 04-29-2012, 03:00 AM   #3460
Tomdog
Mapaholic
Tomdog's Avatar
Oddometer: 362
carnage below..
You did a nice job on that switch!!
I ended up removing my switch from the side stand and re locating it so just visible under the seat on left side.
This way the switch is A/ out of harms way, B/ can be easily and quickly re instated back to the stand, C/ I now have a de facto immobiliser.
Notice the white dot? line the location lug next to it for immobilisation.
1190 Adventure R
Tomdog is offline   Reply With Quote
Old 04-29-2012, 06:29 AM   #3461
DyrWolf
DyrWolf's Avatar
Oddometer: 95
Shock
Day 28 of waiting for my new shock. Replacement shocks are custom made so dont wait for yours to blow before ordering a new one. This is fine at home but not on a trip. I have the bad PMS( parked Motorcycle Syndrome)
DyrWolf is offline   Reply With Quote
Old 04-29-2012, 03:30 PM   #3462
Pine Sol
Pine Sol's Avatar
Oddometer: 499
C/ I now have a de facto immobiliser. Notice the white dot? line the location lug next to it for immobilisation.
once had my bike stolen.... i like this idea, low tech....
thank you
Pine Sol is offline   Reply With Quote
Old 05-01-2012, 11:24 AM   #3463
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,983
Yes - and I recommend it.
I did that when I had the Alu subframe for 65,000 km ... it already has a hole in one side of the box section for the bolt ... just drill through and put a hole in the other side too. Use a steel nylock nut ... and nice big washers to spread the load and to avoid squeezing the walls of the alu box section together.
I had no access to helicoils when I was on the road (thus drilling thru), and I am not sure Helicoils will last that much longer than normal thread ... the helicoil still has to grip the soft aluminium with its own threads ... and those aluminium threads will rip out at some point - only it will make a bloody big hole when it rips out. the bigger threads of the helicoil will help a bit .. but I tapped out M6 bolts to M8 then M10 ... they all ripped out under stress .. so there is no reason the helicoils wont rip out as well.
But .... bolting right through the box section to allow the use of steel nuts was the only way I stopped the problem of how to bolt stuff to the aluminium subframe once and for all.
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 05-01-2012, 11:49 AM   #3464
okto
Oddometer: 13
can someone tell me what this part is?
okto is offline   Reply With Quote
Old 05-01-2012, 12:43 PM   #3465
August West
Wharf Rat
August West's Avatar
Oddometer: 552
Looks like the doohickey that holds the charcoal canister to the sub-frame.
August West is offline   Reply With Quote
Times are GMT -7.   It's 12:52 PM.
