Old 05-09-2012, 05:42 PM   #3496
gumbellion
Oddometer: 391
Quick fuel question
Tomorrow after work I am planning on doing a ride thats 200km highway from gas to gas. no options in between. I will have just a travel back pack, regular gear, and a 1litre msr bottle.
Should I pack some extra gas? Usually i get 170km ish before the fuel light with normal commuting 50/50 town/hwy
slightly hilly terrain.
I dont want to pack extra gas if avoidable but dont know whats left when the light comes on.
I know better safe than sorry but if you think I will be fine I am going to give it a go.
gumbellion is offline   Reply With Quote
Old 05-09-2012, 08:37 PM   #3497
aprilian
Can I change this?
aprilian's Avatar
Oddometer: 470
110 miles of spirited riding is where I have to pull over and use the MSR bottle.
There is no such thing as bad weather, only inadequate clothing.
aprilian is offline   Reply With Quote
Old 05-09-2012, 09:04 PM   #3498
Geoffster
Fool - Born This Way
Geoffster's Avatar
Oddometer: 1,373
Over and over again I get 63+ mpg. I have to work really hard to see 57 mpg! 572.2=125.4 miles, or your 200 km -- with ~27 km to spare in the form of another litre in the tank..
Consider this before arguing with me:
You're an idiot if you argue with a fool!
http://www.flickr.com/photos/geoffster/sets/
Geoffster screwed with this post 05-10-2012 at 06:00 AM Reason: Damn Kindle Fire!
Geoffster is offline   Reply With Quote
Old 05-10-2012, 01:33 AM   #3499
Ducksbane
Quaaack!!!
Ducksbane's Avatar
Oddometer: 1,196
With the standard tank my gentle riding gets about 220km before it runs out ... with the extra 1 litre you should get another 20km ... so if you take it steady you should get there easily. I note that I usually got about 170km before the light came on.
One thought ... when these things run out their out, so if you trust yourself you should probably put the extra litre in before you need it to help cool the fuel pump.
"All that is necessary for the triumph of evil is that good men do nothing." - Edmund Bourke Irish orator, philosopher, & politician (1729 - 1797)
Ducksbane is offline   Reply With Quote
Old 05-10-2012, 01:49 AM   #3500
Johnnyboxer
Oddometer: 1,056
I have done 150 miles of riding on normal roads (not m/way) @50/60/70 mph and the stock tank didn't run out, so that's 240km's and no problema
My bum needed a rest though
So many roads...........So little time..!!!
2005 BMW R1150GS Adv - Black
2005 BMW R1150GS Adv - Silver
2007 BMW G650 XCountry - Black
Johnnyboxer is offline   Reply With Quote
Old 05-10-2012, 05:31 AM   #3501
slide
A nation in despair
Oddometer: 21,122
AFAIK, you have .4 US gallons or perhaps 1.5 liters at the light. Add the liter you are packing and if you light up at 170 km, you should be ok - easily.
I have traveled 145 miles w/o running out.
Why be born again when you can just grow up?
slide is offline   Reply With Quote
Old 05-10-2012, 05:54 AM   #3502
gumbellion
Oddometer: 391
well im going to go for it then. 100km/h or 60 mph will be the top speed since its a 80km/h limit.
Ill let you know how it goes
Im going to try and find a extra bottle today but it looks like canadian tire dosent have anything
Old 05-10-2012, 08:58 AM   #3503
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 4,022
If yer seeing the light at 170, yer gonna go dry at about 225.
I ran dry twice on my XC, so I have a pretty good idea.
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 05-10-2012, 01:39 PM   #3504
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,479
But you ride like a little old man Geoff!
tbarstow is offline   Reply With Quote
Old 05-10-2012, 03:43 PM   #3505
August West
Wharf Rat
August West's Avatar
Oddometer: 556
mileage?
So far I can get no better than 53 mpg? Not wringing it out by any means. Might I have a problem? Xch, 175lb rider.
August West is offline   Reply With Quote
Old 05-10-2012, 03:44 PM   #3506
MizzouRider
MizzouRider's Avatar
Oddometer: 1,785
Originally Posted by WildwoodMOCruiser View Post
Had a 600 mile ride this weekend. (Missouri Swinging Bridges Ride) mostly gravel roads, some muddy dirt roads and several creek crossings. Third time I've taken the XC on this ride.
On the way back yesterday, the ABS would not turn off. It started about half way back yesterday. Turned off the bike and started it again, start and stopped, neutral in and out, nothing worked. The red light would light up, then go out as soon as I started moving. It came back on as soon as I stopped. Holding down the ABS button wouldn't change anything..
I may just disconnect it.. I've put 10,000 miles on it over the last three years, 75% off the black top. So I guess I won't miss it much..
It was extremely dusty this year. Worst I've ever ridden in, and I was at the back of the group. (somebody has to ride back there)
Any suggestions appreciated.
Jeff
I hate to quote myself, but I cleaned up the bike yesterday from last weekends ride. I took the ABS sensors out and wiped them off. Checked fuses, connections. My ABS is still screwed up. The light comes on (ABS) every time I come to a stop. I can't get it to stay on, indicating the ABS is off. Had some tricky stops last weekend.
Any help/suggestions appreciated.
Jeff
IBA#32778 2008 R1200GSA 2007 G650XChallenge
No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..)
MizzouRider is offline   Reply With Quote
Old 05-11-2012, 11:57 AM   #3507
gumbellion
Oddometer: 391
I went 193.6km and used up 8.5 litres
So that works out to 4.29L/100km or 55mpg
My average speed was 105-110km/h or 65-70mph
My light was on right around the 170km mark.
someone mentioned to add the extra gas i had to keep the pump cool. If I run with low fuel regularly am I going to damage the pump? When I head back today I will take a break part way and add the litre I carry anyways but just want to check
Old 05-11-2012, 01:12 PM   #3508
rockydog
just a guy
rockydog's Avatar
Oddometer: 858
I have a request for a x owner, I need the diameter of the pin that holds on the foot pegs. also the inner width of the 2 peg brackets that hold the pegs...am in contact with a vendor who wants to see if his foot pegs with fit an x. he doesn't have access to one for measurements and neither do I... thx
Two lane roads and two bit towns
Rockydog woofs the Isles, British Isles
rockydog screwed with this post 05-11-2012 at 09:05 PM
rockydog is offline   Reply With Quote
Old 05-12-2012, 01:23 AM   #3509
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,984
I dont know the answer, but if you are looking at aftermarket pegs, you CAN NOT go past these babies ...
http://www.cyclebuy.com/shopping/fas...stway_pegs.htm
Fastway Adventure Pegs ... (top on that page) ... Used them on my Husaberg for the Andes Moto Extreme project as Fastway supplied them to us, and they are awesome - the bomb!. Has anyone investigated if fastway can make these to fit the XC???
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 05-12-2012, 01:38 AM   #3510
Rev Kiecker
Rev Kiecker's Avatar
Oddometer: 729
From the looks of it, the standard Fastaway F3's fit both the 450x and 650x. I have the F3's on my 650x.
http://www.touratech-usa.com/Store/4...d-G450X-models
So with that being said, I wouldn't see why you couldn't use the 450x kit (FW-22-3-0031) to make it work on the 650x with the Adventure pegs.
IBA #201
INTERNATIONAL TAXI DRIVER REPORTING FOR DUTY.
Rev Kiecker is offline   Reply With Quote
Times are GMT -7.   It's 03:26 AM.
