Old 05-19-2012, 12:43 PM   #3541
kito
Oddometer: 278
is it possible to take these fans apart and put new bearings and bushes in ?
kito is offline   Reply With Quote
Old 05-19-2012, 12:53 PM   #3542
FinnDuro
Winter wonderlanding
FinnDuro's Avatar
Oddometer: 379
Originally Posted by kito View Post
i have just taken the fan off and it is verry stiff to turn by hand so i think that is the problem . you would have though it would have blown the fuse though when it tryed to power up and could not turn . i am going to leave my bike here and go to french guiana tomorow for a new visa maybe i can find a fan there . does anyone know anything else that uses the same fan ?
The fan BMW uses is made by SPAL. Many other brands use their fans, too. But, I'm not 100% if the OEM one is just one of Spal's generic models - really depends on how the mounting frame is or is not customised. The fan may be a bitch to remove from its mounting frame.
From the outlook, the Spal generic 5.5 inch models look much alike the bmw's. Maybe you could fix them somehow into the existing mounting holes.
http://www.universalpartsinc.com/HP_...%20ACCESSORIES
OEM part number is 17117706673 (and costs a whopping $225 or so).
Stable: BMW R 80 GS -90, KTM 690 Enduro R -12 // finnduro.com
FinnDuro is offline   Reply With Quote
Old 05-19-2012, 02:00 PM   #3543
slide
A nation in despair
Oddometer: 21,122
Local folks there have had to, out of necessity, learned to fix things we in the first world just toss and replace. It may be worth finding a handy man around if you can't source the fan motor itself.
Why be born again when you can just grow up?
slide is offline   Reply With Quote
Old 05-19-2012, 03:54 PM   #3544
kito
Oddometer: 278
i have opened the fan .it looks like SPAL are using a crappy quality bearing inside the moter . the bearing is seized solid . this has caused the plastic that holds the brushes to melt . all in all looks like a cheep crap part that they are charging a lot of money for.
Old 05-19-2012, 04:26 PM   #3545
SMDrew
Oddometer: 16
So on my Xmoto (I kno, wrong thread, but same motor, so... yeah) I knurled the edges a bit more than I'd like on the stock oil drain plug. A trip to the shop, and within a week (and out ~$20) I had the new drain plug. But what's this? Is this right? They've made a modification!
SMDrew screwed with this post 05-20-2012 at 07:34 AM
SMDrew is offline   Reply With Quote
Old 05-19-2012, 06:44 PM   #3546
Pine Sol
Pine Sol's Avatar
Oddometer: 502
Siphon:
hello,
im hooking up a siphon for an extra fuel tank. i assumed it was from the white thing (the larger white thing in the photo) here in the photo, but it doesnt seem to be sucking as fast (or not at all) as i think it should be.
am i using the correct suction thing?
Pine Sol is offline   Reply With Quote
Old 05-19-2012, 07:58 PM   #3547
mbfj40
Oddometer: 169
That's the correct one. Make sure your factory cap is sealing well or you'll lose the "suction" you need to pull from the aux tank. You won't "see" much movement of fluids sitting in the driveway. My aux tank holds 1.5 gallons and in 75 or so miles it's empty...
Here's a pic of my hose hook up...
mike
mbfj40 is offline   Reply With Quote
Old 05-19-2012, 08:26 PM   #3548
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
Also, you need to dismantle the inner valve of that white thingy so the suction happens better/stronger...since doing that, I haven't had issues at all!
Adventurer transitioning from 4x4 to 2x1
'07 G650Xch - Under Mod-struction
DiscoDino is offline   Reply With Quote
Old 05-19-2012, 11:12 PM   #3549
Pine Sol
Pine Sol's Avatar
Oddometer: 502
wow, what a difference that makes..... just pulled it apart, and i think that is where my problem exsisted....
Pine Sol screwed with this post 05-20-2012 at 12:43 AM
Old 05-20-2012, 04:01 AM   #3550
Mtrain
free range
Mtrain's Avatar
Oddometer: 440
Thats the first time I have heard of any one having to do that , with xtanks any way. Mine sucks fine and so does all the others I know of.
Mtrain is offline   Reply With Quote
Old 05-20-2012, 07:36 AM   #3551
slide
A nation in despair
Oddometer: 21,122
You have a bit less magnet area and have lost the little sump area for the engine's swarf. I'd say not a biggie.
Old 05-20-2012, 07:40 AM   #3552
Geoffster
Fool - Born This Way
Geoffster's Avatar
Oddometer: 1,373
I want one! You've kept the magnet and lost the part that bangs on rocks (with certain bashplates).
Consider this before arguing with me:
You're an idiot if you argue with a fool!
http://www.flickr.com/photos/geoffster/sets/
Geoffster is offline   Reply With Quote
Old 05-20-2012, 08:49 AM   #3553
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,873
Sure looks a lot like the Touratech version that costs $22.
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 05-20-2012, 10:18 AM   #3554
Geoffster
Geoffster's Avatar
Oddometer: 1,373
The Tour$tech doesn't have a magnet -- which makes the new-and-improved BMW part a .
Old 05-20-2012, 01:23 PM   #3555
SMDrew
Oddometer: 16
I forgot to mention, that's the PN of the new plug in the first pic (7 708 604). The fiche doesn't reflect the change (the poor-resolution image in the fiche appears to display the hex head, and not the newer low profile plug).
Times are GMT -7.   It's 12:41 PM.
