06-19-2012, 10:11 PM
#3661 |
Lost but laughing.
Oddometer: 4,577
That all makes sense now Walter, seeing that you have a lockable centre differential on your XCH allowing you to ride just about anywhere.
The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” George Carlin |
06-20-2012, 02:53 AM
#3662 | |
Snowflakes are cold...
Oddometer: 569
How is your tacho working with the pulse from double sparks? I have the Trailtech Voyager, but i asumed the tacho wouldn't work well, so i didn't bother to connect it..? Allso, did you wire up the indicators outside of the OEM harness? I gave up wiring a relay to the OEM harness, so i was thinking of wiring a relay connected directly to the battery. Please share a short version on how you did it before i go ape/¤#¤%#/ as i really really really hate all electronics
06-20-2012, 04:40 AM
#3663 | |
Oddometer: 1,436
I'm too lazy to go look.. Is it the same nut for front and rear? I'm cheap, but I can spring for $9.00 for these.. ![]() Thanks, Jeff
IBA#32778 2008 R1200GSA 2007 G650XChallenge No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..) |
06-20-2012, 05:17 AM
#3664 |
Oddometer: 2,060
Yes , I used the same part # on both front and rear.
ADV Relay Rider 08 (The Texas Connection) Ride Pooie Ride ![]() Don't stop riding until you get to the crash , you might save it! |
06-20-2012, 05:54 AM
#3665 |
Oddometer: 2,066
I run a T63 in the rear and a TKC on the front. At a recent cornering class, I was able to scrape my pegs a few times and never felt any give from either tire (dry conditions). Given that I'm not the most aggressive rider to begin with, I feel the TKC/T63 will handle the pavement better than I will.
That being said, I'm not sure I will stick with the same setup next time. The tires are quite a bit louder than other DS tires I've used. While I'm sure they perform much better in mud and sand, I just never seem to find myself in anything more than gravel. On gravel/fireroads, the TKC/T63 only seem marginally better than other (quieter) DS tires I have tried. So even if you're 50-50 on/offroad, if the offroad portion is only gravel/fireroads you may be better off with a more street oriented tire. I'm not saying you can go wrong with the T63s or TKCs. I think they do really well on the asphalt - you just may be giving up some quiet for offroad performance you may not need. Just something to consider.
Marc 07 XChallenge 99 VFR |
06-20-2012, 10:23 AM
#3666 |
Oddometer: 17
Fitted Lynx fairing screen very happy with fitment
now just waiting for fender to arrive ![]()
BMWPE screwed with this post 06-20-2012 at 10:25 AM Reason: pics |
06-20-2012, 12:13 PM
#3667 | |
"Moto Porn"ographer
Oddometer: 3,804
Electrician friend did the work but I assisted so I have some idea what happened. We tapped one of the 12v wires into one of the coils. I need to check which one for you tomorrow. There are three wires into each coil ... a power, an earth and the signal. Obviously the one you want is the signal wire on just one of he coils. We chose the one closest to the RHS, as it is closest to the loom. You will know it works when you fire the bike up as it should settle down to an idle of 1500 rpm. The unit above has multiple tacho modes in any case where it counts one spark for every rpm, two sparks for every rpm, 1 sprk for every 2 rpms, and countless other modes. Default is one spark per 2 rpms which works with the bike. Indicators were wired up thus ... tapped into the harness ... a wiring diagram will tell you which wires coming out of the Dash plug (which you d ont need to cut off ... never know when you want to use a stock dash again) go to the four indicators, Once you have them, you can tap into those with a new relay and the feed from the LHS handlebar control unit. I switched to LED indicators and have fitted an LED indicator relay. PS I also hate electrics
Sibirsky Extreme 2009 BOOK and DVD available HERE Moroccan Extreme 2011 DVD available HERE www.sibirskyextreme.com |
06-20-2012, 02:33 PM
#3668 | |
Wharf Rat
Oddometer: 506
06-20-2012, 05:11 PM
#3669 | |
now THAT"S a bike!
Oddometer: 274
06-20-2012, 06:56 PM
#3670 |
extreme midlifer
Oddometer: 2
Looking at buying an X-Ch
its a 2007, 6k miles, has ABS, lots of extras with it. I'd like to get an objective review on this machine. I rode dirt bikes for years, stopped due to wifely influence & raising kids... now kids are out & she's not stopping me ;^). Intent is to ride off road in the back country yet on road to get to trails for weekend camp trips.
I've looked at the F650GS my buddy recently bought, smooth for a thumper and seems meant for only occasional off road (too pretty). Also considered the Suzuki 650DR, heard its underpowered, but is light and utilitarian. Another one, the KTM EXC450, looks to be 80% dirt bike,hear its not road comfy or easily outfittable, the 900 Adventure looks to be strong but too heavy. I'm 6', 175 & in decent shape would like the lightest bike possible to suit my wants. Also sat on a 500 or so Husky & felt very dirt bike-like, exciting but not road worthy I thought, it did have a light though. Seems nothing (except maybe the X-Ch) fits the bill. Any other ideas or is this the one? Any wise advice for an unwise mid-lifer ? J Nevbro jnevbro01 screwed with this post 06-20-2012 at 08:53 PM Reason: detail removal, greed and impatience |
06-20-2012, 07:22 PM
#3671 |
Oddometer: 2,066
Well you'll obviously get biased answers from the folks in this thread, myself included.
I have been absolutely thrilled with my XChallenge. I was going to get a DR650, but new XChallenges were being sold for not much more money (I paid under $6K). Think of an XChallenge as a faster, lighter, better DR650. Not much can compete with the DR in terms of reliability and I won't say the X can. But the X is a reliable bike in its own right, IMHO. Not perfect, but I wouldn't hesitate to take mine anywhere. The only issue I have had was the bad battery which was replaced under warranty. And that was more of an Exide battery issue than a BMW issue. You don't really see any more failures since the switch to Yuasa. In the large thumper class, you have your heavy out of the box adventure bikes (KLR, F650 single), you have your dirt oriented 650s (DR, XR-L) and your more exotics (KTM). But somewhere between the DRs and KTMs are the higher performance DS bikes like the XChallenge and TE610/630. Better performance than a DR, but still with reasonable maintenance intervals and reliability records. And I personally like that balance. The airshock is a little goofy, but isn't terrible. Several people have had a cold stalling issue. But not too many reports of dramatic failures. If I had to replace my XChallenge, I would simply get another (or maybe the Husky TE if I couldn't find a decent used X).
06-20-2012, 07:39 PM
#3672 | |
Oddometer: 1,436
No weeping at all. I also tried adding gas to just the X-Tank and only about half of the main tank. There wasn't enough "pull" from the main tank to pull any from the X.. I know this sounds simple, but it's eliminated the weeping on my X..
IBA#32778 2008 R1200GSA 2007 G650XChallenge No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..) MizzouRider screwed with this post 06-21-2012 at 03:57 AM |
06-20-2012, 07:41 PM
#3673 |
Oddometer: 1,436
Thanks Don, I suspected they were the same, but I've been wrong before and now I have a lot of little stuff sitting around that I was going to return etc.. Wanted to make sure I wasn't adding to the collection..
06-20-2012, 08:17 PM
#3674 | |
Wharf Rat
Oddometer: 506
Thanks I'll experiment with less filling. |
06-20-2012, 08:18 PM
#3675 |
Wharf Rat
Oddometer: 506
