Old 07-02-2012, 10:24 PM   #3721
dirty boar
OZ BOAR
dirty boar's Avatar
Oddometer: 276
Got oil leaking out of the water pump weeping hole
Whats this mean?
does this happen often?
Dale
dirty boar is offline   Reply With Quote
Old 07-02-2012, 10:26 PM   #3722
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,422
Whats this mean?
Dale
You probably have had a water pump seal failure. Does your oil look foamy in the oil tank?
tbarstow is offline   Reply With Quote
Old 07-02-2012, 10:50 PM   #3723
The Jester
The Jester's Avatar
Oddometer: 838
Sounds about right. Not seen one reported for the X bikes on here yet but I understand that several have been reported for the earlier F650GS single bikes. Have a look on f650.com
Life is not a rehearsal!
The Jester is offline   Reply With Quote
Old 07-03-2012, 12:42 AM   #3724
Erik RS
Three Wheel Maniac
Erik RS's Avatar
Oddometer: 457
Originally Posted by Pine Sol View Post
..... the rear sub-frame is from the xco (sourced from ErikRS).....
Correction here, sorry. Your rear subframe is the TT one
Problem with the XCo steel subframe are the welded-on passenger pegs. They interfere with the rack's lower mounts.
Three Wheel Fever forever
Xtankteam™
Proud sponsor of the Sibirsky Extreme Project
Erik RS is offline   Reply With Quote
Old 07-03-2012, 01:16 AM   #3725
dirty boar
OZ BOAR
dirty boar's Avatar
Oddometer: 276
no .
Dale
Old 07-03-2012, 01:21 AM   #3726
dirty boar
OZ BOAR
dirty boar's Avatar
Oddometer: 276
Did have some warranty work done on the engine cover( replaced) that side couple of months ago.
Dale
Old 07-03-2012, 01:25 AM   #3727
Erik RS
Three Wheel Maniac
Erik RS's Avatar
Oddometer: 457
With the seal gone, there is still hardly any risk of water in the oil. Rotax did the engineering properly. One seal for the waterside and another one for the oilside. The room/chamber in between has a hole in the bottom to the outside world
Xtankteam™
Old 07-03-2012, 01:28 AM   #3728
dirty boar
OZ BOAR
dirty boar's Avatar
Oddometer: 276
so the oilside seal has gone.
thanks Erik RS
Dale
Old 07-03-2012, 01:53 AM   #3729
Erik RS
Three Wheel Maniac
Erik RS's Avatar
Oddometer: 457
If the oil is really coming from that spillage hole, you're probably right. Normally it's the water seal that goes first, so it might be advisable to change that one also when you're there.
Xtankteam™
Old 07-03-2012, 02:07 AM   #3730
dirty boar
OZ BOAR
dirty boar's Avatar
Oddometer: 276
ok
dale
Old 07-03-2012, 04:40 AM   #3731
Mtrain
free range
Mtrain's Avatar
Oddometer: 440
I have recently had the same however I think it was the water side that went. It took me a bit to work out whether it was coolant or oil that had dripped on the ground. seems to have stopped now but the seals are going to get changed any way.
45000ks on the clock.
The older 650s used to do seals after 40-50k
Mtrain is offline   Reply With Quote
Old 07-03-2012, 09:40 AM   #3732
The Jester
The Jester's Avatar
Oddometer: 838
35000 miles so mine must be due.
Old 07-03-2012, 10:44 AM   #3733
Pine Sol
Pine Sol's Avatar
Oddometer: 499
reply, corrected
Pine Sol is offline   Reply With Quote
Old 07-03-2012, 10:50 AM   #3734
Erik RS
Three Wheel Maniac
Erik RS's Avatar
Oddometer: 457
Great to see you made it to/on the road Ed. Keep the dirty side down and keep in touch.
Any updates or shortcomings in the set-up, you got my address Some of the stuff was hardly beyond prototyping.
Ride free mate and enjoy
Xtankteam™
Old 07-03-2012, 11:16 AM   #3735
Pine Sol
Pine Sol's Avatar
Oddometer: 499
not your stuff, but the saddle bags that i made to fit your racks, were the prototyping... you can see from the links i just sent you...
Times are GMT -7.   It's 09:55 PM.
