Old 07-09-2012, 09:38 PM   #3751
pampaX
pampaX's Avatar
Oddometer: 423
Originally Posted by tbarstow View Post
The ignition switch has broken connections at the solder joints.
Before you fix that, you need to find out where the short circuit is that blew the 15 amp fuse.
The bike holds 3 quarts of oil. You have to fill the oil tank, then start the bike, let it run, then add another quart.
+1 on the diagnostic (same happened to me not long ego)
My G650X Challenge, Bike build thread on
http://www.advrider.com/forums/showt...7#post15320987
pampaX is offline   Reply With Quote
Old 07-11-2012, 10:46 AM   #3752
Atompilot
Atompilot's Avatar
Oddometer: 4
X Challenge for sale
As I am getting out of motorcycling I am selling my X Challenge, it is listed on eBay. Thanks to all for all the invaluable info shared on this forum. Cheers.
Atompilot is offline   Reply With Quote
Old 07-11-2012, 06:23 PM   #3753
tigrebleau
tigrebleau's Avatar
Oddometer: 663
The manual says the bike holds 2.6 qts. Elsewhere in this forum, problems are reported with adding too much oil.
"To them, the bike is just garage clutter. To us, it's a loaded Beretta, a half-million in cash, and a forged passport under the floorboards." - Dan Walsh
tigrebleau is offline   Reply With Quote
Old 07-11-2012, 07:22 PM   #3754
jjmead1
now THAT"S a bike!
jjmead1's Avatar
Oddometer: 565
A simple Turkey Baster can solve the problem of adding too much oil. I often add more than 2.6 and less than 3. Depends on how proper you lose the oil in the first place. So many grey areas in this bike it seems.
jjmead1 is offline   Reply With Quote
Old 07-12-2012, 07:35 AM   #3755
on2
on2's Avatar
Oddometer: 18
So tbarstow, did you replace the whole ignition since they don't sell separate pieces? I popped off the cap on the round side of the ignition to inspect those two solder points and they aren't broken off or anything. Or is it more internal closer to the key side of the ignition? Oh I should also mention that this is the third ignition so its fairly new (bike was stolen twice!).
on2 is offline   Reply With Quote
Old 07-12-2012, 07:40 AM   #3756
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,123
That part should have warranty if it is new, and if it is faulty.
What do you all think of the updated XChallenge Husqvarna Terra?
http://blog.motorcycle.com/2012/07/1...kes-announced/
http://blog.motorcycle.com/wp-conten...50-terra-2.jpg
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz screwed with this post 07-12-2012 at 07:49 AM
Cruz is offline   Reply With Quote
Old 07-12-2012, 08:15 AM   #3757
Geoffster
Fool - Born This Way
Geoffster's Avatar
Oddometer: 1,373
I think I will have an option to a G650GS when my X-Country takes a giant crap. (Probably the wiring harness, etc.)
No one makes a perfect bike. The owner has to make it perfect.
Consider this before arguing with me:
You're an idiot if you argue with a fool!
http://www.flickr.com/photos/geoffster/sets/
Geoffster is offline   Reply With Quote
Old 07-12-2012, 08:25 AM   #3758
slide
A nation in despair
Oddometer: 21,122
There is a thread here about the fork failure (leading lugs broke off) on a current production 650GS. I am leery of buying a new bike I need to also buy a new front end for.
Why be born again when you can just grow up?
slide is offline   Reply With Quote
Old 07-12-2012, 08:57 AM   #3759
Erik RS
Three Wheel Maniac
Erik RS's Avatar
Oddometer: 458
At almost more than 24 kgs heavier and with a travel of 190mm? The XChallenge is not a hardcore offroad but usuable. I'd rather compare the Terra with the XCo then
Three Wheel Fever forever
Xtankteam™
Proud sponsor of the Sibirsky Extreme Project
Erik RS is offline   Reply With Quote
Old 07-12-2012, 09:14 AM   #3760
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,453
I had mine replaced under warranty twice. You could resolder it easily and do a better job than BMW did.
tbarstow is offline   Reply With Quote
Old 07-12-2012, 10:22 AM   #3761
Kicksave
wannabeema
Kicksave's Avatar
Oddometer: 169
I'm looking really hard at the Terra myself. I like the HP boost and the 46mm inverted forks. I'll keep you posted.
Kevin LB BMW
Regret is a useless emotion. Choose wisely the first time. Own your bad choices. And move the hell on.
Kicksave is offline   Reply With Quote
Old 07-12-2012, 10:25 AM   #3762
Kicksave
wannabeema
Kicksave's Avatar
Oddometer: 169
The Husky won't share the same front end as a G650 GS.
Old 07-12-2012, 10:27 AM   #3763
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,123
Yeah, I have it positioned a bit between the two X bikes.
Can you see a conversionto a single pipe and new X Tank being made?
xronly
Old 07-12-2012, 11:23 AM   #3764
Happycamper
Have bikes, will travel
Happycamper's Avatar
Oddometer: 626
Talking
Definately! I am not sure why they went with the added weight/cost of two stainless cans. Think of the diet from switching to one can of a lighter material.
Happycamper
2009 F800GS
2014 KTM 690 Enduro R
Happycamper is offline   Reply With Quote
Old 07-12-2012, 03:09 PM   #3765
Erik RS
Three Wheel Maniac
Erik RS's Avatar
Oddometer: 458
....Can you see a conversionto a single pipe and new X Tank being made?
Sure, if there's a market Thinking out loud for myself: in the airhead days BMW's were always "Lego" for grown up kids, meaning a lot could be swapped between the various models and types. They would not have gone so far to use the same rear subframe for the GS and the Terra would they? Because that would definitely enlarge the market for this kind of part.
Xtankteam™
Times are GMT -7.   It's 01:03 PM.
