Old 11-02-2012, 04:58 AM   #4096
dantroop
dantroop's Avatar
Oddometer: 176
Nice tip, to use a piece of hose to pull the plugs. I'll have to remember that one. Thanks for the write up.
dantroop is offline   Reply With Quote
Old 11-02-2012, 08:36 AM   #4097
Mr F
I hear banjos.
Mr F's Avatar
Oddometer: 42
Anybody have their dash start cracking and falling apart yet?
Maybe someone who has ditched their stock dash would want to sell me their cover? hmm?
Mr F is offline   Reply With Quote
Old 11-07-2012, 01:15 PM   #4098
maltese
Oddometer: 35
Ohlin's questions
Just ordered an ohlins for my g650x challenge because of excessive wear on the rear shock. As I am the third owner and the bike is way out of warranty I decided to go this way and wanted to add some bling to the bike.
Everywhere I've read has said this shock will raise the seat even higher and wanted to know if there were any recommendations on getting the bike lowered. I don't want to loose much travel, and I'd like to level the bike out, so what size spacer would you recomend throwing in there? I have a 30in inseam and am used to riding bikes with a 32-34 in standover, but the X challenge is just to high.
Any help would rock!
maltese is offline   Reply With Quote
Old 11-07-2012, 03:36 PM   #4099
mcgiggle
Oddometer: 272
I've had these racks on now (with Ali subframe) 4 years, UK to India and back via Iran and Pakistan and now 15000 miles through South America with no problems but they have been beefed up around the place that is known to break.
UK-India-UK 2009/2010
Current trip Buenos Aires-NYC
http://www.facebook.com/curryhunt
mcgiggle is offline   Reply With Quote
Old 11-07-2012, 11:36 PM   #4100
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,983
If you order a shock from any of the premium shock makers you should be able to get them build it to whatever length you want.
The main difference between the height of a air shock and a regular oil/nitrogen shock is the contrast between the parked height and the ride height is nowhere near as vast. With the air shock, the bike sits super high when parked, then sags down loads when you sit on it. The bike is lower with a regular shock when parked, but may be slightly higher than the air shock with your weight on it. .... depending on what pressure you ran in the air shock.
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 11-08-2012, 12:34 AM   #4101
Perun
Oddometer: 198
Hello, McGiggle!
Can you spare some details about that box you have mounted on skidplate? Is it a factory skidplate? What kind of box is it? How did you mount it? Do you have some issues with that setup?
Perun is offline   Reply With Quote
Old 11-08-2012, 02:07 AM   #4102
Tomdog
Mapaholic
Tomdog's Avatar
Oddometer: 376
Originally Posted by Perun View Post
Hello, McGiggle!
Also more details on the subframe "beef up" would be good
1190 Adventure R
Tomdog is offline   Reply With Quote
Old 11-08-2012, 02:39 AM   #4103
Johnnyboxer
Oddometer: 1,043
On the XCh, what shock are you using??
Did you change the seat too??
So many roads...........So little time..!!!
2005 BMW R1150GS Adv - Black
2005 BMW R1150GS Adv - Silver
2007 BMW G650 XCountry - Black
Johnnyboxer is offline   Reply With Quote
Old 11-08-2012, 02:44 AM   #4104
Johnnyboxer
Oddometer: 1,043
I tried the Ohlins, specified for the bike and although the parked height was a little lower, as Walter says
However the ride height was 1-2" taller (31" inseam) and it also raised the rear of the bike and upset the steering geometry making the bike 'tuck under' in bends - yuk
I tried to adjust the preload/ride height, however the spring was way too hard for mixed road and dualsport use - it was intended for desert/Dakar racing and it wouldn't work
So................I will get a custom built Wilbers or Hyperpro sorted for me, my weight and height, plus the intended use etc
Old 11-08-2012, 03:28 AM   #4105
KintaroZ3
Oddometer: 2
G650X Challenge options
Just had a question about some aftermarket gaurds, I would like to know if it is possible to use the Large TT skid plate with the SW-MOTECH Crashbars/Engine Guards (BMW G650 Xchallenge and the OME BMW engine gaurds. I havent seen anyone do it yet , but is this over kill? any imput would be well appreciated.
JJ
KintaroZ3 is offline   Reply With Quote
Old 11-08-2012, 05:56 AM   #4106
slide
A nation in despair
Oddometer: 21,122
When I bought my Ohlins for the GS, the vendor asked me about my weight, my riding style and what I wanted improved over the stockers. He delivered exactly what I wanted.
I post this because it would then make sense that a good Ohlins vendor should be able to work your current shock to one which works perfectly for you.
Why be born again when you can just grow up?
slide is offline   Reply With Quote
Old 11-08-2012, 06:00 AM   #4107
bigdon
Oddometer: 2,631
What Slide said!
ADV Relay Rider 08 (The Texas Connection)
Ride Pooie Ride
Don't stop riding until you get to the crash , you might save it!
bigdon is offline   Reply With Quote
Old 11-08-2012, 06:09 AM   #4108
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,983
JJ
It's overkill
There's a lot of guys on this forum like barstow who race and crash these bikes, and a lot like jester who ride enduro off road loads and crash these bikes with them and a lot of guys like me who tour around the world with them, mostly off road with loads of crashes.
None of the above use engine bars. Use a good bashplate , I recommend the scheffelmeier rally not the TT one, and good hand guards , think bark busters rather than TT plastic, and the bike is crash proof.
Old 11-08-2012, 06:21 AM   #4109
Johnnyboxer
Oddometer: 1,043
The Ohlins Vendor was Touratech, is that enough info for you
Old 11-08-2012, 06:28 AM   #4110
Erik RS
Three Wheel Maniac
Erik RS's Avatar
Oddometer: 458
..... is that enough info for you
I rest my case, your honour
But really, if you buy your A-brand shock at a good dealer/vendor/service center they will always set it up/or have it set up to your specific wishes
Come over to Holland Johnny and speak to Bas at Hyperpro. He'll probably just set you up with a proper spring and all will be settled. That shock's good enough without doubt
Enough suspension specialists in the UK also without doubt, that could arrange a decent setup for your Öhlins
Three Wheel Fever forever
Xtankteam™
Proud sponsor of the Sibirsky Extreme Project
Erik RS is offline   Reply With Quote
Times are GMT -7.   It's 06:03 PM.
