Old 01-18-2013, 12:01 AM   #4381
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,589
Thanks for the battery pics Butters. I don't think you will regret the EarthX.
XCountry Web Site ~~~ My Spot Location ~~~ Spot Baja Trip ~~~ Neduro Did Dakar!
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400
snooker is offline   Reply With Quote
Old 01-18-2013, 12:46 AM   #4382
Johnnyboxer
Oddometer: 1,044
I went for a MotoBatt, which is a direct equivalent of the OEM Yuasa, but with better specs and less than half the price @ 47 delivered from M&P, next day delivery
Fits snugger than than a snug thing, perfect fit for the XChallenge and better than the Yuasa in reality
Nifty option is the spare set of terminals, great for accessories etc
Once fitted, she fired up first turn of the starter - despite being stood for 2 months
Battery registered 14.1 volts straight out of the box, that'll do for me
So many roads...........So little time..!!!
2005 BMW R1150GS Adv - Black
2005 BMW R1150GS Adv - Silver
2007 BMW G650 XCountry - Black
Johnnyboxer is offline   Reply With Quote
Old 01-18-2013, 03:43 AM   #4383
Timpo
NORTH WALES TRF.
Timpo's Avatar
Oddometer: 2,108
Motobatt here too, no problem.
The Rave Generator......
Timpo is offline   Reply With Quote
Old 01-18-2013, 05:14 AM   #4384
Johnnyboxer
Oddometer: 1,044
Thanks for the tip, good choice
Old 01-18-2013, 07:05 AM   #4385
tee bee
Oddometer: 200
fuel filter
Without going right through this thread.
I need to replace my fuel filter,we all know mahle will not supply the filter direct to us and a complete pump system is 220.50.
Has anyone managed to fit a different filter ? The pump still works fine,but even replacing that,its only around 65.
The k100 and lada filters look like they could be made to fit, has anyone else tried this.?
Cheers
Terry
tee bee is offline   Reply With Quote
Old 01-18-2013, 07:11 AM   #4386
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,456
Cheers
Terry
Yes. Use Google to search ADV or look in the Bike Specific Index thread.
tbarstow is online now   Reply With Quote
Old 01-18-2013, 08:40 AM   #4387
hedd
Oddometer: 40
Butters, with the upcoming cold mornings could you report back how the cold starts are? Like you, my bikes are ridden in the winter and I am hoping that the battery is good enough no matter the temp (in the DC area).
15 FE 350 S
07 G650 XChallenge
00 VFR 800
08 Hypermotard 1100S
hedd is offline   Reply With Quote
Old 01-18-2013, 03:03 PM   #4388
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,629
I was definitely concerned about that. I rode in this morning and it was 36F when I left and was in the 20s overnight. I keep the bike in the garage, however, so it was probably stored in the 40s. It fired up like a new battery. I really don't ride much below 30 degrees. Worst case that I would personally see would be if I was somewhere I had to store the bike outside down into the teens. I think I will be fine, but it sounds like the warmup routine is pretty simple should I ever actually need it.
That being said, the battery I got was not a direct replacement, it was the biggest one I could fit in the space. Because of this, in addition to the increase in Ah, it is also listed at 230CCA, whereas the stock Yuasa is listed at 190 and the Odyssey is listed at 100CCA. So lets say it actually takes 100CCA to turn over the engine, my 230CCA battery may have only been putting out half that at 36F, but it was still plenty to turn over the bike.
Now if you wanted to save weight and bought the EarthX ETX12B, which is closer to a direct replacement, it only puts out 135CCA. So there is a lot less margin for error there if you lose CCAs due to the cold.
At least that's my theory.
Marc
07 XChallenge
Butters is offline   Reply With Quote
Old 01-26-2013, 04:36 AM   #4389
tee bee
Oddometer: 200
After a few simple mods, i have fitted the fuel filter from the bmw k75, Mahle kl145.
At a saving of 205, thanks bmw......
Old 01-26-2013, 04:42 AM   #4390
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,629
Awesome! Pics? Writeup?
Marc
07 XChallenge
Old 01-26-2013, 04:45 AM   #4391
tee bee
Oddometer: 200
Blimey, now you,ve put me on the spot. i,ve never posted any pics.i,ll try....
Old 01-26-2013, 06:40 AM   #4392
mikeysduck
Slow Ride to Nowhere
mikeysduck's Avatar
Oddometer: 236
Air Filter Hiflo?
Can anyone comment on Hiflo air filters for the X bikes? I pulled the air box covers, on my new to me X Challenge, a new looking stock paper filter. Great! Not really. I removed the filter and found the inside of the air box coated in fine dust. I greased the sealing surface hoping that will help. I need a better filter.
Is the Hiflo foam or paper?
I found this comparison Uni vs Twin Air. Are either of these still available? They do not readily pop up on a google search. It looks like they both retail for $50 to $100. The Hiflo is available for $10 to $20.
http://www.advrider.com/forums/showthread.php?t=508841
"The Constitution? I'm pretty sure the patriot act killed it, to protect our freedoms" Bart Simpson
14 R1200RT 09 KTM 450 EXCR 75 Norton 850 E-Start It's going to run. I swear! 69 Z-50A Mini Trail with Lights 03 GasGas 280 Pro 03 CRF 230
mikeysduck screwed with this post 01-26-2013 at 07:04 AM Reason: spelling
mikeysduck is offline   Reply With Quote
Old 01-26-2013, 07:42 AM   #4393
Geoffster
Fool - Born This Way
Geoffster's Avatar
Oddometer: 1,373
My X-Country's fuel light failed to come on last week, and I ran out of gas. Never before, and not since.
Ambient temps were in the low 30s when it malfunctioned.
Anyone else have low-temp transient failure(s)?
Consider this before arguing with me:
You're an idiot if you argue with a fool!
http://www.flickr.com/photos/geoffster/sets/
Geoffster is offline   Reply With Quote
Old 01-26-2013, 08:09 AM   #4394
mcftw
hxc n33b
mcftw's Avatar
Oddometer: 454
The only problem I've had close to that is the light not coming back on after I turn the bike off. It doesn't get under 40 here very often so I guess I won't be too helpful.
"Open up your mind and think like me." Jason Mraz
mcftw is offline   Reply With Quote
Old 01-26-2013, 11:05 AM   #4395
Royal Tiger
Sd Kfz 182
Royal Tiger's Avatar
Oddometer: 1,415
Now you are just showing off!
Current- '13 Yamaha XT250 * '05 BMW R1200ST * {Searching for my next DS}
Past- 2x aprilia, 2x BMW, 1x Ducati, 5x Kawasaki, 2x Yamaha
Royal Tiger is offline   Reply With Quote
Times are GMT -7.   It's 09:45 PM.
