Old 01-31-2013, 07:59 PM   #4411
mikeysduck
Slow Ride to Nowhere
mikeysduck's Avatar
Oddometer: 235
(FYI: make sure you take off the air box and put some greas around the rubber grommit on the throtel body, I even pulled the grommet and put sum around the top that seals agains the airbox [found a lot of dust in there as well].)
More dust leaks! Thanks for the heads up.
The bike is mostly apart waiting for suspension parts to be returned. I'm almost finished with DESERT SCORPION'S air box mod. I need to make the thumb screws, and find a spring to hold them in place.
Thanks for the Touratech link. I'll get at least one, and seal the air box properly.
"The Constitution? I'm pretty sure the patriot act killed it, to protect our freedoms" Bart Simpson
14 R1200RT 09 KTM 450 EXCR 75 Norton 850 E-Start It's going to run. I swear! 69 Z-50A Mini Trail with Lights 03 GasGas 280 Pro 03 CRF 230
mikeysduck screwed with this post 01-31-2013 at 08:06 PM Reason: Credits for air box mod
mikeysduck is offline   Reply With Quote
Old 02-01-2013, 02:18 AM   #4412
BigHairyYorkshireman
Oddometer: 8
Thumb
Originally Posted by oothef View Post
Xchallenge front spindle dimensions: large O/D 24.92mm large I/D 20.85mm sml O/D 19.95mm sml I/D 14.00mm
Overall length 265mm length to shoulder (sml dia) 178mm
Dia taken with good vernernia, length with cheap tape
Many thanks oothef, that's great.
BigHairyYorkshireman is offline   Reply With Quote
Old 02-01-2013, 04:47 AM   #4413
Erik RS
Three Wheel Maniac
Erik RS's Avatar
Oddometer: 458
Xchallenge front spindle dimensions: ..... sml O/D 19.95mm....
If it's for manufacturing one, I personally wouldn't make it smaller than 19,97 mm. 0,03 mm play at that diameter in a bearing is max imho
Three Wheel Fever forever
Xtankteam™
Proud sponsor of the Sibirsky Extreme Project
Erik RS is offline   Reply With Quote
Old 02-02-2013, 01:34 AM   #4414
bronio
666
Oddometer: 10
Complete rear wheel for sale
Hi I've got complete rear wheel with sprocket and brake disc etc.
If some body interested I can send pictures just write me an e-mail on bronikowski.andrzej@gmail.com or private message.
bronio screwed with this post 02-02-2013 at 01:39 AM
bronio is offline   Reply With Quote
Old 02-02-2013, 04:46 AM   #4415
dajg
dajg
Oddometer: 65
rear wheel bearing spacer & circlip
does anyone know the exact length of the spacer in the centre of the rear wheel hub, between the two bearings?
both my bearings failed - one catastrophically, destroying; the bush on the left side, the circlip, the dust seal, and taking a few mm (i think) off the spacer.
i have spare bearings, and managed to get a similar dust seal, but i want to get a new spacer machined first thing monday - i'm in namibia (SW africa) and it will take up to 3 weeks to get a replacement otherwise...
lastly does anyone know the size of the circlip? seems about 40mm but i don't have anything to measure it accurately enough and the remaining pieces aren't really big enough to get a match.
thanks in advance.
dave
dajg is offline   Reply With Quote
Old 02-02-2013, 08:17 AM   #4416
Erik RS
Three Wheel Maniac
Erik RS's Avatar
Oddometer: 458
Bronio, you have mail
Xtankteam™
Old 02-02-2013, 08:20 AM   #4417
Erik RS
Three Wheel Maniac
Erik RS's Avatar
Oddometer: 458
Originally Posted by dajg;20632199...
rear wheel story..
Sh*t, just did all the wheel bearings for a friend an hour ago. Saw it too late
Hope somebody else comes with the ansswers. Good luck
For the circlip, just find yourself a circlip for the the same size as the appropriate seal. Circlips are normalised for internal hole diameters asfaik
Xtankteam™
Old 02-02-2013, 09:48 AM   #4418
bronio
666
Oddometer: 10
Erik, You have an answer
Old 02-02-2013, 12:18 PM   #4419
oothef
Grownup
Oddometer: 32
My bearings are back in, sorry.
oothef is offline   Reply With Quote
Old 02-03-2013, 01:22 PM   #4420
maltese
Oddometer: 35
Just wanted to give you guys I will be putting up some g650x parts for sale soon. I'm out in the Sf bay area and will have a set of g650x challenge fork, front wheel + disk brake, lower triple and front brakes. I wanted to let you guys know here since this is our area. PM me with any questions.
Also I will need to get some photos up with my ktm front end on there
maltese is offline   Reply With Quote
Old 02-03-2013, 03:23 PM   #4421
Royal Tiger
Pz VI B, Sd Kfz 182
Royal Tiger's Avatar
Oddometer: 1,385
Tucker Rocky lists front wheel bearings for the G650X XChallenge from All Ballz, but nothing for the rear. Looking at the chart on page 1 they are the same. Correct? I want to change them both just to be safe.
2013 Yamaha XT250 * 2005 BMW R1200ST
Long list of former rides.
Royal Tiger is offline   Reply With Quote
Old 02-03-2013, 10:52 PM   #4422
The Jester
The Jester's Avatar
Oddometer: 846
Front and rear bearings are both 6004. Worth changing the seals if they are worn; not sure whether they are the same though. Cush hub bearings are different. Strangely, although I have replace both sets of wheel bearings several times I have never had an issue with the cush hub bearings in over 40k miles
I've done it now.
Life is not a rehearsal!
The Jester screwed with this post 02-04-2013 at 11:30 AM
The Jester is offline   Reply With Quote
Old 02-04-2013, 05:08 AM   #4423
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,983
Cush hubs are 2 x 6005 ... easy to change
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 02-04-2013, 11:41 AM   #4424
The Jester
The Jester's Avatar
Oddometer: 846
Thanks, I thought they were but wasn't 100% sure. I'll have to order a set now since I've set myself up for them failing.
Had the clutch cable snap today. Not fun trying to push the bike uphill across a junction fast enough to jump on and kick it into 1st without it stalling.
Old 02-04-2013, 08:20 PM   #4425
mtncrawler
mtncrawler's Avatar
Oddometer: 1,144
New to the 650X world..
Hello all,
Well, I finally pulled the trigger on a new-to-me 650X, low miles, non-ABS, and very stock (well a few farkles). I pick it up this weekend.
So my trip dreams for the bike are wide and far - so are the list of mods that are awash in my pea-like brain. I've read several of the "adventurizing" threads, farkle threads, used search, used Google search, and maybe I've missed some information on what I'm sure will be a long list of questions.
This whole alternator thing..I've read several threads regarding the alternator output on the X compared to, say, the Dakar. (280 .vs. 400W). Lots of threads on batteries too. There seemed to be lots of threads talking about an expensive OEM replacement Alt with proper BMW warning due to the mass changes, mentions of third party replacement stators, and various projects loading up electrical's on the X's alternator as stock. Many of these threads are of various vintage and it sounds like some may have tried alternator upgrades of some sort.
What I can't seem to find are any threads/reports of those that HAVE made the alternator changes/mods (regardless of which mod) and how it worked out (or didn't).
Are most folks just running the stock alternator? I wonder with lighting, battery, electrical accessory advancements over the last few years whether the 280W is really still a limiting issue when "adventurizing" the X? For me, thinking heated hand grips, aux lighting, GPS power..maybe an accessory plug for heated vest.
I read the index page and caught the link to Electrical questions, that suggests a company called Electrosport makes an upgrade - if I remember correctly - Colebatch mentioned in one of his threads of possibly upgrading to one at some point. but I may have missed any threads talking about results.
ADVRider is an awesome resource - hoping some of you X-veterans feel like schooling a newb, as I learn the ways of the 650X!
2007 BMW 650 XChallenge..
2009 BMW R1200 GSA..(Gone.. )
2004 BMW R1150 GSA (Gone.. )
"You think dogs will not be in heaven? I tell you, they will be there long before any of us." Robert Louis Stevenson
mtncrawler is offline   Reply With Quote
Times are GMT -7.   It's 08:48 AM.
