Old 02-19-2013, 04:12 PM   #4486
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,652
Somebody was selling a pair of OEM ones in the Flea Market a couple days ago. They had already sold one, but they can be used on either side. I was going to text you, but didn't know whether or not you liked those ones on your bike.
Edit - I have Aprilia Tuono mirrors on the Strom (common replacement to combat buffeting). Not sure if they'll fit the X, but I'm thinking they will. We can try them out if you want, but they may be too short to get a good view past your shoulders.
Marc
07 XChallenge
Butters is offline   Reply With Quote
Old 02-19-2013, 04:27 PM   #4487
mcgarrett
mcgarrett's Avatar
Oddometer: 164
Marc,
We can give them a try when I borrow your torque wrench.
I've also seen some mention of using KTM folding mirrors.
Michael
mcgarrett is offline   Reply With Quote
Old 02-19-2013, 04:30 PM   #4488
gsstampeder
gsstampeder's Avatar
Oddometer: 1,082
I use these on mine and they work great
pricey, but good mirros with lots of adjustments and sturdy as hell.
I called to be sure they'd work and ended up getting the KTM ones....
5 weeks in Baja
gsstampeder is offline   Reply With Quote
Old 02-19-2013, 04:40 PM   #4489
mcgarrett
mcgarrett's Avatar
Oddometer: 164
These might be a possibility as well:
http://www.sierrabmwonline.com/produ...40-0760-p-2240
Old 02-19-2013, 04:49 PM   #4490
Yukon Ho!
We can go ANYWHERE!
Yukon Ho!'s Avatar
Oddometer: 166
Originally Posted by mcgarrett View Post
Any suggestions for replacement mirrors? PO traded the bike in without any, and the dealership put on some generic cheap ones that I don't really like.
http://www.doubletakemirror.com/ -- love 'em.
Yukon Ho! is offline   Reply With Quote
Old 02-19-2013, 04:57 PM   #4491
xaman
Oddometer: 583
I got mine from Henri (I've bought these for multiple bikes and like them a lot):
http://www.advrider.com/forums/showthread.php?t=357336
Not the best pictures, but gives you an idea:
xaman is offline   Reply With Quote
Old 02-19-2013, 06:36 PM   #4492
BigHairyYorkshireman
Oddometer: 8
Originally Posted by wah64apache View Post
I'll take you up on that Yorkshire Man. If you would check if they have or can get a top end Athena, or similar quality top end gasket kit for an 07 XChallenge ans how much it will cost and time to get it I appreciate it about 5 or 6 pints worth the next time I'm in Jolly Ole. Cheers, Frank
Hi. Checked with Motorworks and they can only supply the BMW parts, as per their website, or any combination of gaskets shown there. If that's any use to you, let me know. Athena response was that they don't do a top end kit for the 07 XChallenge. Cheers, Pat
BigHairyYorkshireman is offline   Reply With Quote
Old 02-20-2013, 03:34 PM   #4493
mcgarrett
mcgarrett's Avatar
Oddometer: 164
Thanks for the suggestions everyone.
Old 02-21-2013, 12:04 AM   #4494
werner747
Oddometer: 30
Eek LED Tail light?
Hi,
Has anyone had problems with the standard LED tail light? Mine seems to be dead! When the bike is switched on, voltage to the plug that connects to the tail light is 0.3v, when applying the brake, it jumps to 11,5 v, but the light never comes on? So I don't know if this is a bad LED tail light, or something in the wiring.
All fuses are fine.
BMW wants more than an arm and a leg for a new tail light! Has any one fitted any other brands?
Any help will be appreciated.
werner747 is offline   Reply With Quote
Old 02-21-2013, 05:44 AM   #4495
Royal Tiger
Sd Kfz 182
Royal Tiger's Avatar
Oddometer: 1,469
Touratech sells a LED tail light for the XChallenge. I don't recall how much it costs though.
Current- '15 Yamaha WR250R (mine) * '13 Yamaha XT250 (her's) * '05 BMW R1200ST (ours)
Past- 2x aprilia, 2x BMW, 1x Ducati, 5x Kawasaki, 2x Yamaha
Royal Tiger is offline   Reply With Quote
Old 02-21-2013, 07:38 AM   #4496
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,482
Look here.
TT is ~$90 less than BMW.
tbarstow is offline   Reply With Quote
Old 02-21-2013, 10:55 AM   #4497
The Jester
The Jester's Avatar
Oddometer: 860
Originally Posted by werner747 View Post
Hi,
All fuses are fine.
Could well be a fractured wire. I have had a few go, including the power wire to the tail light at the connector. If it is the led there are plenty of 12v high output less on eBay. It wouldn't be too hard to knock something up.
Life is not a rehearsal!
The Jester is offline   Reply With Quote
Old 02-21-2013, 02:22 PM   #4498
pampaX
pampaX's Avatar
Oddometer: 428
I have several wire issues on the rear wiring loom (as well as elsewhere). So I would take it out and inspect it. If I recall its relatively easy to remove the plug is under the seat and there are a few zip-ties.
My G650X Challenge, Bike build thread on
http://www.advrider.com/forums/showt...7#post15320987
pampaX is offline   Reply With Quote
Old 02-21-2013, 04:31 PM   #4499
Oddometer: 8
Thumb Plain bushed ?
Originally Posted by oothef View Post
Rear spindle overall length 300mm, small dia. length 295mm
I'm looking for a plain bush to replace the (collapsed) swinging arm needle roller bearing on the exhaust side, 25mm id, 32mm od, anyone know of a supplier, before I get one turned up?
Thanks oothef. The outfit who are making the spindle crash bungs for me could also make a bush for you, either from phosphor bronze or Acetal (a bit like nylon but with a high oil content so works as a bearing) but would need to know a length, which material and your zip/postcode to quote a price.
Old 02-21-2013, 04:41 PM   #4500
Royal Tiger
Sd Kfz 182
Oddometer: 1,469
Picture request
Want to drain the coolant. Is the bolt ahead (towards the front of the bike) of the oil drain the coolant drain? If so would someone be so kind to take a picture and circle anything I need to remove? Like any hoses or anything as well? Thank you in advance.
Times are GMT -7.   It's 04:03 AM.
