Old 02-21-2013, 06:17 PM   #4501
Travlr
Oddometer: 77
Originally Posted by Royal Tiger View Post
Picture request
Want to drain the coolant. Is the bolt ahead (towards the front of the bike) of the oil drain the coolant drain? If so would someone be so kind to take a picture and circle anything I need to remove? Like any hoses or anything as well? Thank you in advance.
Remove #1, fluid will drain from motor.
Remove expansion tank lid and then tank. #2,#3
Remove hose off bottom of rad #4.
If you see this you have gone to far.
Travlr is offline   Reply With Quote
Old 02-21-2013, 06:21 PM   #4502
Royal Tiger
Pz VI B, Sd Kfz 182
Royal Tiger's Avatar
Oddometer: 1,379
Thank you!
What is that other drain in your first pic below the #1 in front if the oil drain?
2013 Yamaha XT250 * 2012 Kawasaki Ninja 250 {SOLD} * 2007 BMW G650X XChallenge {SOLD} * 2005 BMW R1200ST {maybe FOR SALE} * 2003 Yamaha PW80 {FOR SALE}
Royal Tiger is offline   Reply With Quote
Old 02-21-2013, 06:35 PM   #4503
Travlr
Oddometer: 77
Thank you!
The bolt that is slightly obstructed (in the picture only) is one of the bolts to remove the left crank case cover. I think that is the one you are asking about.
The bolt at the right end of the "U" shape is to insert the crank TDC position lock pin. Whick leads to the last photo...
Old 02-21-2013, 07:48 PM   #4504
Royal Tiger
Pz VI B, Sd Kfz 182
Oddometer: 1,379
The bolt next to the "K15" in the pic is the oil drain. The one right next to it on the bottom of the motor.
Old 02-21-2013, 08:09 PM   #4505
Travlr
Oddometer: 77
oh that one.
That is the oil line that runs from the scavenger/suction pump to the oil tank. maybe we should switch to pm's.
Old 02-22-2013, 12:43 AM   #4506
werner747
Oddometer: 29
Cool2 Thanks
Hi,
Has anyone had problems with the standard LED tail light? Mine seems to be dead! When the bike is switched on, voltage to the plug that connects to the tail light is 0.3v, when applying the brake, it jumps to 11,5 v, but the light never comes on? So I don't know if this is a bad LED tail light, or something in the wiring.
All fuses are fine.
BMW wants more than an arm and a leg for a new tail light! Has any one fitted any other brands?
Any help will be appreciated.
Thanks for all the advise! Seems like one wire is bad, got volts to read correctly now, but the light is still dead. Will search ebay for alternatives.
werner747 is offline   Reply With Quote
Old 02-22-2013, 06:17 PM   #4507
on2
on2's Avatar
Oddometer: 13
Hammerhead
Gonna be parting out my old girl. Starting small first. Im selling my Hammerhead Designs gold tip (lol) and is +20 size shift lever on eBay but the rest I will be putting on here after i find it all.
http://www.ebay.com/itm/Hammerhead-D...880707&vxp=mtr
on2 is offline   Reply With Quote
Old 02-22-2013, 11:32 PM   #4508
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,538
Originally Posted by Yukon Ho! View Post
+1
These DoubleTake mirrors are Neduro's amazing indestructible totally adjustable mirrors. He said they were the only mirror to start and finish the 2012 Dakar, on his bike of course. Nuff said. Support an Adv brother and get the best off road mirror ever made.
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400 ~~~
FindMeSpot ~~~ Spotwalla Baja Trip ~~~ Neduro Did Dakar!
snooker is offline   Reply With Quote
Old 02-23-2013, 08:08 AM   #4509
The Jester
The Jester's Avatar
Oddometer: 828
Originally Posted by oothef View Post
Rear spindle overall length 300mm, small dia. length 295mm
I'm looking for a plain bush to replace the (collapsed) swinging arm needle roller bearing on the exhaust side, 25mm id, 32mm od, anyone know of a supplier, before I get one turned up?
Not sure where you are but I sourced all the parts to replace my swingarm bearings from simplybearings.co.UK using dimensions taken from the BMW parts fiches on the maxbmw website.
Life is not a rehearsal!
The Jester is offline   Reply With Quote
Old 02-23-2013, 11:56 AM   #4510
oothef
Grownup
Oddometer: 32
Thanks Jester, I've used simply bearings, but I fancied trying a plain bush instead of the needle rollers, the left hand had collapsed, BSL got me one, just fitted it, put a grease nipple in, I'll see how it performs when I get it back on it's wheels.....
oothef is offline   Reply With Quote
Old 02-24-2013, 03:18 AM   #4511
noisytoys
Oddometer: 44
Touratech does a double LED fo G650X, they`ll take just an arm for it
Originally Posted by werner747 View Post
Hi,
All fuses are fine.
noisytoys is offline   Reply With Quote
Old 02-24-2013, 03:20 PM   #4512
gumbellion
Oddometer: 379
Originally Posted by tbarstow View Post
Take a file to the throttle tube, as the locking pattern that BMW put on there for the OEM grips will screw up how the grip heater sticks.
Pull the locator pins from the controls.
+1
When you're done, make sure everthing is OK when the bars go from lock to lock.
it might be a dumb questions but how do I remove the brass locator pins from the switches on the handlebars? I was going to just give a hard tug with pliers but dont want to end up wrecking the kill/abs or the other multi switch
New black bars look sharp, but cant be used yet
gumbellion is offline   Reply With Quote
Old 02-24-2013, 03:22 PM   #4513
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,301
That works just fine. Pull them with pliers.
tbarstow is offline   Reply With Quote
Old 02-24-2013, 11:26 PM   #4514
The Jester
The Jester's Avatar
Oddometer: 828
If they don't come out easily, heat them for a few seconds with a soldering iron and they will just drop out.
Old 02-26-2013, 11:26 PM   #4515
Gas Can
Gas Can
Gas Can's Avatar
Oddometer: 41
Thanks to all the inmates that gave advice over the last few years. It really helped me pick the best mods for my X Challenge. Real sad to have to sell it but Im having money issues. Its for sale in San Diego and here in the
Flea Market. http://www.advrider.com/forums/showthread.php?t=866382
Gas Can is offline   Reply With Quote
Times are GMT -7.   It's 03:31 AM.
