Old 03-27-2013, 02:48 PM   #4591
benjero
Oddometer: 10
The plastic housing, unfortunately. A leaky hose would be an easy fix...
Originally Posted by tbarstow View Post
What is leaking? The hose connection or the plastic housing?
benjero is offline   Reply With Quote
Old 03-27-2013, 02:56 PM   #4592
benjero
Oddometer: 10
The plastic housing doesn't seem to sit completely flush with the reservoir it's attached to. Not sure if this is correct, but it's as far as it goes in, and it stays attached when I slide in the metal pin to lock it. Could somebody take a look/picture at theirs for comparison please?
Old 03-28-2013, 06:47 AM   #4593
jjmead1
now THAT"S a bike!
jjmead1's Avatar
Oddometer: 554
I had a plastic leak on my radiator fromt he bike taking too many "naps". The only solution I could come up with was molding JB weld over the crack several times and forming it to the shape I needed. Took about three days of "molding" and curing but it has never leaked again, even with the bike taking several dirt naps to test my mold job.
Not the same area as yours but just an out of the box way of fixing a total PITA leak/crack.
jjmead1 is offline   Reply With Quote
Old 03-28-2013, 09:26 AM   #4594
LangKat
LangKat's Avatar
Oddometer: 68
Anyone else ever try to remove their seat and find it stuck? Seems like the latching mechanism is broken.
Any idea how to get there with the seat stuck on?
LangKat is offline   Reply With Quote
Old 03-28-2013, 09:51 AM   #4595
slide
A nation in despair
Oddometer: 21,122
Bad one. Have you tried undoing the latch while pressing down on the rear of the saddle? It may just be a bit stuck.
Why be born again when you can just grow up?
slide is offline   Reply With Quote
Old 03-28-2013, 10:26 AM   #4596
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,300
You can always take the inner rear fender off and get to parts of the mechanism that way.
tbarstow is offline   Reply With Quote
Old 03-28-2013, 11:03 AM   #4597
LangKat
LangKat's Avatar
Oddometer: 68
I tried pushing the saddle while turning the key. As well as wiggling, hitting, prying with a screwdriver and angry shouts. Nothing worked.
Will try removing the inner rear fender tomorrow. It was too dark here already to try earlier.
Old 03-30-2013, 08:24 AM   #4598
jjmead1
now THAT"S a bike!
jjmead1's Avatar
Oddometer: 554
Removed my fender area and cut it out so I would never have the issue again. key does not work, but you just give the old bike a nice reach around and it'll unlock every time.....
No surprise to find a fair amount of dirt now shows up under the seat.
Old 03-30-2013, 12:57 PM   #4599
mcgarrett
mcgarrett's Avatar
Oddometer: 150
Hyperpro plus TT Subframe
Does anyone have a Hyperpro shock with oil reservoir mounted to a Touratech subframe? The local shop is having difficulty with the install, specifically with the oil reservoir not mounting onto the subframe. There's also an issue with the angle of the hose. Frustrating.
mcgarrett is offline   Reply With Quote
Old 03-31-2013, 11:29 AM   #4600
MizzouRider
MizzouRider's Avatar
Oddometer: 1,759
Trying to decide if its worth it to put the progressive springs in the front shocks..
Any pro or con opinions would be welcome, and who makes them? HyperPro? I think TT sells the HyperPro also. Any others?
Anyone have a set they want to git rid if, if you gave up and replaced the front forks?
IBA#32778 2008 R1200GSA 2007 G650XChallenge
No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..)
MizzouRider is offline   Reply With Quote
Old 03-31-2013, 12:47 PM   #4601
mtncrawler
mtncrawler's Avatar
Oddometer: 1,076
PM on the way..
2007 BMW 650 XChallenge..
2009 BMW R1200 GSA..(Gone.. )
2004 BMW R1150 GSA (Gone.. )
"You think dogs will not be in heaven? I tell you, they will be there long before any of us." Robert Louis Stevenson
mtncrawler is offline   Reply With Quote
Old 03-31-2013, 02:28 PM   #4602
pampaX
pampaX's Avatar
Oddometer: 416
Rear disk rotor
Hi guys does anybody know which other bikes have same rear disk rotors?
I found very scarce info and replacements on the net. Lots of front ones but no rears.
Found:
Dealer can get original with 3 months delay I assume they need to extract the metal out of the mine first.
My G650X Challenge, Bike build thread on
http://www.advrider.com/forums/showt...7#post15320987
pampaX is offline   Reply With Quote
Old 03-31-2013, 02:51 PM   #4603
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,300
Found:
I have looked before and nobody makes a G650X rear rotor replacement. The catalogs may say that it exists, but I have shipped them all back because they do not fit.
Old 03-31-2013, 05:15 PM   #4604
ced40
ced40's Avatar
Oddometer: 48
Idle problem
Hello amigos. Happy to have my old XC challenge back. Sold it a couple of years ago and I got it back this week. However it has an idle problem when its cold. I know somewhere here we have something related to this and before I start taking it apart I need some help with this problem. I just do not remember where I saw this issue. Thanks in advance for your help.
CED
ced40 is offline   Reply With Quote
Old 03-31-2013, 07:08 PM   #4605
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,552
Some people have had issues when their idle air controller (IAC) gets gunked up. It's on the right side behind the side panel. It's held on with two Phillips screws. Obviously there are a number of cold idle issues, but that was a popular fix. Resetting the throttle position was another fix.
Marc
07 XChallenge
Butters is offline   Reply With Quote
Times are GMT -7.   It's 02:56 AM.
