Old 05-06-2013, 05:52 AM   #4726
hedd
Oddometer: 40
Originally Posted by Butters View Post
Hedd can verify, but I think it is a KTM fender attached with a bracket from schefflemeister. Although I seem to recall the KTM fender is two piece, so maybe it is a different fender. but the bracket is definitely from Stefan's shop (hedd told me today when I was eyeing it!)
here's the link: http://www.bashplates.de/BMW-G-650-X...lenge::56.html
Yes, that's the one. I like the looks better and more importantly, it fixes the water spray issue with the stock fender; when riding in the rain, water doesn't spray over the front fender on to the rider.
15 FE 350 S
07 G650 XChallenge
00 VFR 800
08 Hypermotard 1100S
hedd is offline   Reply With Quote
Old 05-06-2013, 11:32 AM   #4727
jabroka
jabroka's Avatar
Oddometer: 338
early christmas!
cant wait to fit them all
1993 suzuki GSXR-R
2007 BMW G650X CHALLENGE
jabroka is offline   Reply With Quote
Old 05-06-2013, 12:10 PM   #4728
Antti
Antti's Avatar
Oddometer: 186
Is that red one Uni filter prefilter kit?
R1100GS, 690 Enduro, R80G/S project bike.
Antti is offline   Reply With Quote
Old 05-07-2013, 01:07 PM   #4729
jabroka
jabroka's Avatar
Oddometer: 338
exactly.. + bigger injector + 14th sprocket and low seat..
1993 suzuki GSXR-R
Old 05-07-2013, 07:16 PM   #4730
mbfj40
Oddometer: 170
I can't seem to find one of the pre-filters here in the states with out paying almost $60 in shipping from UNI Australia.
UNI-NU-7311
mbfj40 is offline   Reply With Quote
Old 05-07-2013, 08:22 PM   #4731
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,453
UNI-NU-7311
That is correct. I even went into the Unifilter shop in Orange, CA, and they had no idea what it was and were not receptive to trying to get one.
I just run a few pieces of Unifilter foam over the Unifilter. I also have noticed that the Unifilter doesn't really fit the opening for the air box correctly. You need to use a lot of grease to seal it up.
tbarstow is offline   Reply With Quote
Old 05-08-2013, 03:45 PM   #4732
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,589
+1
The sheet of Uni filter foam really traps most of the dirt. Mine looks like this now:
more notes HERE
XCountry Web Site ~~~ My Spot Location ~~~ Spot Baja Trip ~~~ Neduro Did Dakar!
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400
snooker is offline   Reply With Quote
Old 05-09-2013, 05:33 AM   #4733
jjmead1
now THAT"S a bike!
jjmead1's Avatar
Oddometer: 564
Originally Posted by jjmead1 View Post
Lately I have been noticing a lot more gas smell when the bike is running. It also seems to stall out. Oddly if it is wicked cold out and has not been running for hours it starts with no stalling. It is not stalling while riding just after starting and smells like it is running ' rich" .
Any ideas? TIA
No canister, and the ignition has been re soldered. No leaks that are visible and no leaks from the gas cap area.
The smell is only noticeable when running, fuel filter? bad plugs?
anyone?
jjmead1 is offline   Reply With Quote
Old 05-09-2013, 05:33 AM   #4734
jabroka
jabroka's Avatar
Oddometer: 338
I paid about $40 of shipping for both filters from AU to Houston,TX. I've been quite busy this week so I didn't have time to work on the bike. I,ll probably will have some free time on sunday, I'll take some pics of the pre-filter fitted and post them.
1993 suzuki GSXR-R
Old 05-09-2013, 07:52 AM   #4735
aprilian
Can I change this?
aprilian's Avatar
Oddometer: 466
anyone?
Temp sensor in radiator would be worth checking. It sounds like it is running on the enriched map all the time as if the bike thinks it is still cold.
There is no such thing as bad weather, only inadequate clothing.
aprilian is offline   Reply With Quote
Old 05-09-2013, 08:09 AM   #4736
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,453
anyone?
Maybe a bad Oxygen sensor?
Old 05-09-2013, 07:42 PM   #4737
eaglescan
Borrego rocks
eaglescan's Avatar
Oddometer: 86
clock
anyone have an idea: Took my XC out today and when I turned the key on, bike started Ok, but my clock was reading all 0.00 and both trip meters had reset to 0 also. The main odometer still had the mileage reading.
eaglescan is offline   Reply With Quote
Old 05-09-2013, 08:45 PM   #4738
snooker
snooker's Avatar
Oddometer: 1,589
That is a symptom of power going below a minimum battery voltage, like one of the terminals got disconnected, or blown fuse or the voltage drooped to far for one of many reasons (drain, semi-short, etc).
The starter is on a separate fuse circuit probably which is why the bike can still start, so I'm guessing the battery is fine and it is a fuse. The circuits are described in the manual.
Old 05-09-2013, 08:48 PM   #4739
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,322
Do you have HID headlight?
Rob Swartzwelder, Southern AZ
I'm not real fast, but I do have a dog named Dakar!
97 M900, 07 G650 XChallenge,11 KTM 990 ADV R
2011 North up the CDR
Sierra Vista AZ to Paonia CO and Back through Moab UT
AZ-Twin is offline   Reply With Quote
Old 05-09-2013, 09:54 PM   #4740
eaglescan
Borrego rocks
eaglescan's Avatar
Oddometer: 86
thanks snooker, will be checking battery connection, etc.
AZ, No HID , still stock lights and they are OK.
I was able to set the clock with the bike off, and trip meters all started to work as I rode.
I have a new BMS-C about 7000 km ago.
Times are GMT -7.   It's 05:15 AM.
