Old 06-16-2013, 09:08 AM   #4831
Pine Sol
Pine Sol's Avatar
Oddometer: 499
combination, between a simple throttle lock and throttle rocker.
i have tried single spring and double spring, but never found much difference, so i just have both.
the only real noticeable problem that i have for long hours in the saddle, is that i find that the handle bars (grips), the end angle is such that i develop a pain inside my wrist from holding the throttle open. as if the bars need to be more straight, rather then the bent/ turned angle that they are, so much, that i am going to find a straighter set of handle bars
Pine Sol is offline   Reply With Quote
Old 06-16-2013, 03:42 PM   #4832
mcgarrett
mcgarrett's Avatar
Oddometer: 162
Bashplate toolbox
I'm hoping to hear from folks who have installed a bashplate toolbox (pros, cons, type, etc.). It's doubtful I'd be able to get one before my Trans Lab adventure kicks off next Saturday, but it could be a good long-term storage solution for my tool roll and flat repair kit. Thanks.
Michael
mcgarrett is offline   Reply With Quote
Old 06-16-2013, 04:15 PM   #4833
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,453
Michael
I put one of the DIY KLR tool tubes up front. It works great! Just remember to add a tether to the tube caps.
tbarstow is offline   Reply With Quote
Old 06-16-2013, 06:47 PM   #4834
mcgarrett
mcgarrett's Avatar
Oddometer: 162
Any tips for mounting it?
Trans Lab 2013 Ride Report
http://advrider.com/forums/showthread.php?t=903321
Old 06-16-2013, 07:24 PM   #4835
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,453
I just use long hose clamps to attach it to the bashplate. I would use 2 test plugs instead of gluing one end cap on if I made another one.
Old 06-16-2013, 08:21 PM   #4836
Square1
Square1's Avatar
Oddometer: 132
New front rim
Hello
I'm in need of a new front wheel rim.
I looked at Woodys site and they recommend a 1.85 wide rim instead of the standard 2.25 (?).
I ride 50 street/ 50 dirt with a Great Divide Ride coming up.
What is your experience with that set up?
Also is this a common tire size or will I be limited in my choices?
Thank you
M
Square1 is offline   Reply With Quote
Old 06-16-2013, 10:03 PM   #4837
Perun
Oddometer: 198
Actually, OEM front is 1.60. I think same tyre sizes cover 1.60 and 1.85...
Perun is offline   Reply With Quote
Old 06-17-2013, 12:43 AM   #4838
john_aero
john_aero's Avatar
Oddometer: 1,173
Anyone here who did the wp conversion have the rest of the legs laying around that dont need.
set i sent look to have gotten dented in post so he is looking for the chrome leg in top condition
or even the full forks without the lower cast section
PM me please if have some laying around as like get the issue sorted as fast as i can
ideally set in Europe region be better to save postage costs
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 06-17-2013, 01:35 AM   #4839
SteveDennehy
Steve
SteveDennehy's Avatar
Oddometer: 246
Originally Posted by gumbellion View Post
What are you guys using for a throttle rocker type device for long rides? I am going to remove the one return spring but would still like to find something so I can rest my hand a bit while on the hwy.
Suggestions and how you like it would be good
I fitted a Kaoko Throttle lock, together with OEM handguards, and it works brilliantly.
Have a look at http://www.wilddog.za.net/forum/inde...topic=125234.0
SteveDennehy is offline   Reply With Quote
Old 06-17-2013, 07:10 AM   #4840
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,453
Originally Posted by Square1 View Post
Hello
Thank you
M
Use the Woody's recommendations. This setup works great. Go for the superspokes as well. I've had a Woody's wheel on my front for years now.
You won't be limited in your tire choices.
Old 06-17-2013, 07:38 AM   #4841
jjmead1
now THAT"S a bike!
jjmead1's Avatar
Oddometer: 564
yup ^^^ that. I live down the street from them, listened to their choices and haven't looked back.
jjmead1 is offline   Reply With Quote
Old 06-17-2013, 10:56 PM   #4842
Square1
Square1's Avatar
Oddometer: 132
New front Rim
Thank you guys,
the rim sizes were from Woodys website, since then someone from Woodys contacted me and recommended the 1.60x21 Excel with larger spokes and superlaced.
I m a little concerned if ithat will change the way it handles on the Highway>
M
Old 06-18-2013, 04:02 AM   #4843
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,984
Thank you guys,
M
I run a 1.6 inch Excel A60 front rim and have no issues. Changing from the stock 1.85 size to 1.60 doesnt change the handling.
Are they selling you the A60 or the regular "signature series" rim?
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 06-18-2013, 08:25 PM   #4844
Square1
Square1's Avatar
Oddometer: 132
New Front Rim
Thanks for your reply on the 1.60 rim vs. the 1.85.
The guy at Woodys did not specify which Excel rim, only that it cost $ 139 and allready has the larger nipple holes for the larger spokes and is ready for their superlace pattern.
I will follow up on that!
Can I still use the 90/90x21 tire size with the narrower 1.60 rim?
Getting ready for ten days on the continental Divide Trail !!!
M
Old 06-18-2013, 08:33 PM   #4845
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,453
M
Your tire sizes don't change.
Times are GMT -7.   It's 04:14 AM.
