Old 07-01-2013, 09:57 AM   #4891
an13
Oddometer: 36
Only special tools needed to split the engine are special socket for removing right hand side frame mounting spacer and puller bolt/nut for pulling out flywheel. Camshaft locking bolt is easy to fabricate.
F650 maintence DVD is mainly valid for G650 also, especially you can see how engine works http://faq.f650.com/dvd/
Also read the official REPROM and try to find out best method for yourself, combining both sources for instructions.
One notable thing learned from that F650 DVD is that you don't need to take off cylinder head from cylinder, just remove cylinder from engine and slide it out carefully until you can remove piston from connecting rod. Piston with it's rings can then be left inside removed cylinder.
When putting cases back together, make sure you have all the shims/spacers in correct position, if there is extra shim for example inside the case in clutch axle when it needs to be outside the case, cases won't close, I tried that.
an13 screwed with this post 07-01-2013 at 10:06 AM
an13 is offline   Reply With Quote
Old 07-02-2013, 12:38 AM   #4893
john_aero
john_aero's Avatar
Oddometer: 1,166
try and re load images with wilbers isnstalled. for some reason wouldnt load earlier. so tried again here and on other g650x thread
cant get headder stop pushing against shock
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 07-02-2013, 02:40 AM   #4894
LTCOliverNorth
Peeping Tom
LTCOliverNorth's Avatar
Oddometer: 777
Originally Posted by tele-steve View Post
My X had a catastrophic failure somewhere in the transmission. I was 8 days and 2000 miles into a backcountry ride headed towards home last week when the motor rpms spike and I thought I busted my chain.
Looking down, I see chain is still intact, but the bike wont go anywhere. I can flip through the gears, and all I can do is make the grinding noise in the case go faster. Even when in neutral and coasting (which I had to for about 6 miles), the sound is a bit brutal.
There is no way to find out the problem until I can get the engine out of the bike and crack the case. Has anyone done this themselves? Any special tools I might need to buy? I imagine the dealer is going to hit me for at least $3k if I take it to them, so I'm looking to get elbow deep myself.
Any advice would be greatly appreciated.
-tele
Did you check the front sprocket spines to see if they stripped out? I had the exact same experience and the cause was an aftermarket front sprocket's spines giving out and the grinding noise was my driveshaft spinning free in the Center of the sprocket.
You have two options at this point. If the drive shaft spines are in good enough shape still, replace with an OEM sprocket and use Loctite 660 (aftermarket sprocket's have too much play causing the spines to eventually shear off). If your drive shaft spines are destroyed then you'll have to replace the drive shaft, or just weld a new sprocket to the driveshaft. You'll screw up the drive shaft in doing so, but at least you'll be able to go through one more front sprocket before having to replace the drive shaft.
The cost to have the drive shaft replaced by the dealer should run you about $800+
2007 BMW G650X Challenge
2005 BMW R1200GS
2002 Ural Patrol T
LTCOliverNorth is offline   Reply With Quote
Old 07-02-2013, 07:46 AM   #4895
tele-steve
ya' mon
tele-steve's Avatar
Oddometer: 266
Thanks for the heads up. The bike is currently in a friends garage in Salt Lake City and I wont have time to drive out and pick it up for another couple of weeks.
tele-steve is offline   Reply With Quote
Old 07-02-2013, 11:15 AM   #4896
Mr F
I hear banjos.
Mr F's Avatar
Oddometer: 42
-tele
Sent you a PM
Mr F is offline   Reply With Quote
Old 07-02-2013, 01:27 PM   #4897
LTCOliverNorth
Peeping Tom
Oddometer: 777
Keep us posted, I'm curious to know if it was another driveshaft/spline stripping issue.
2005 BMW R1200GS
2002 Ural Patrol T
Old 07-03-2013, 07:35 AM   #4898
jjmead1
now THAT"S a bike!
jjmead1's Avatar
Oddometer: 558
With increasing frequency I am having starting issues. It is when I first start the bike. The bike is garage kept, temperatures are 60 degrees F. Start bike and it fires fine, runs ten seconds stops. Repeat. After three or four attempts at starting I use the throttle to keep it running, this is not always successful either. I am also noticing a gas smell at red lights. I do not notice this smell when I start the bike or when it sits. I also get a bit of back fire when throttling down from speed. Otherwise the bike is running great, getting about 70 MPG very consistently ( I live at 5,500 feet and run premium )
I assume the bike is running rich and the issue is the throttle position sensor? I am hoping it is not a fuel pump issue. But I am admittedly terrible at diagnosis.
Any help would be greatly appreciated.
jjmead1 is offline   Reply With Quote
Old 07-03-2013, 08:11 AM   #4899
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,372
I would start with checking your battery. If you measure less than 13 volts between the terminals, it is time to replace it. The next step would he cleaning the fuel injector and checking for an exhaust leak. Follow up with a valve check/adjustment.
tbarstow is offline   Reply With Quote
Old 07-03-2013, 08:27 AM   #4900
jjmead1
now THAT"S a bike!
jjmead1's Avatar
Oddometer: 558
Thanks for the prompt response.
Old 07-03-2013, 08:41 AM   #4901
khpossum
poster
Oddometer: 473
Check http://www.advrider.com/forums/showt...=483596&page=1 , especially post 18 and 26
Cleaning the idle air controller is what did it for me.
KP
khpossum is offline   Reply With Quote
Old 07-03-2013, 09:13 AM   #4902
jabroka
jabroka's Avatar
Oddometer: 338
Hey guys.. maybe someone can point me in the right direction.
I'll be receiving the TT rallye fairing kit in a few weeks.
I searched all the known to me threads ( this one, + g650x farkles + the merged threadfest) and couldn't find anything on the cable extension to relocate the gauges with the TT kit.
I know I can split each cable and solder a few inches of new one, but I was wondering if there is any tidier solution to it, for example, getting the same socket/plug the gauges and wiring has and make a plug&play extension..
1993 suzuki GSXR-R
2007 BMW G650X CHALLENGE
jabroka is offline   Reply With Quote
Old 07-05-2013, 04:25 PM   #4903
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,558
.... until I can get the engine out of the bike and crack the case. Has anyone done this themselves? Any special tools I might need to buy? I imagine the dealer is going to hit me for at least $3k if I take it to them, so I'm looking to get elbow deep myself.
-tele
Tim? don't you have pics or your ordeal? I can't remember if you did it yourself...
XCountry Web Site ~~~ My Spot Location ~~~ Spot Baja Trip ~~~ Neduro Did Dakar!
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400
snooker is offline   Reply With Quote
Old 07-05-2013, 04:46 PM   #4904
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,372
I am still fighting BMW on this one.
It doesn't appear to be that bad of a job to do if you have the time and space.
Old 07-06-2013, 02:21 PM   #4905
SteveDennehy
Steve
SteveDennehy's Avatar
Oddometer: 238
Not to dampen your obvious enthusiasm, but I wouldn't hold my breath waiting for the TT fairing to arrive. I ordered mine in April and am still waiting, with no delivery date in sight yet. I am just a tiny bit frustrated with Touratech right now.....
SteveDennehy is offline   Reply With Quote
Times are GMT -7.   It's 04:15 AM.
