Old 07-10-2013, 06:52 AM   #4936
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,443
Originally Posted by tommyvdv View Post
This may already be in this, but.
Has anyone tried/succeeded in installing these on their Xch:
(http://highwaydirtbikes.com/HDB_Shop/)
Yes. Had them for a bit, found the mirrors to be useless and the guard bar to top bar clamp setup put the bars in a really goofy "rolled way back" position.
tbarstow is online now   Reply With Quote
Old 07-10-2013, 11:24 AM   #4937
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,589
Oh, it never occurred to me the HDB setup forces you to rotate the bars to a specific position but I guess that makes sense. But damn they look strong!
XCountry Web Site ~~~ My Spot Location ~~~ Spot Baja Trip ~~~ Neduro Did Dakar!
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400
snooker is offline   Reply With Quote
Old 07-10-2013, 11:36 AM   #4938
snooker
snooker's Avatar
Oddometer: 1,589
Originally Posted by 4Rider View Post
Matt-
Proscreen does make a unit that fits the X-Country headlight configuration (I'm assuming you are interested for your X-Co). I ordered two units, one for the X-Challenge, the "Dakar" model, and one for the X-Country. Both fit up easily, and both seem to work well. Here is the page for the X-Co model:
http://www.parabrisascurtain.com/sho...-x-country.htm
If you want a photo of the screen on the X-Co let me know. I'll try to get out to take one today and post it.
The shipping from Argentina took about 29 days. I did talk to the owner about more expedited shipping, but he didn't have anything faster to the U.S.
Mark
Ok thanks and to you too Butters. I am happy with my (out of production) Sportech windscreen but wanted to document this for others on my webpage, since a good windscreen is hard to find it seems.
Having said that, the ProScreen is ACRYLIC and not the safest like polycarbonate. It says High Impact Acrylic and I'm not an expert but...
It may be worth repeating... or not but... See this video by National Cycle (which may not be comparing the exact same high impact acrylic) but....
... I just think about riding 80 mph and an object hitting your windshield, shattering it and sending it towards your neck....
Old 07-10-2013, 11:52 AM   #4939
hensh
Oddometer: 3
g650 x country fork dust seals
Evening,
I have recently purchased a 2007 g650 and noticed that the fork dust seals are cracked and there is a build up of rust around them.
Can they be replaced by just removing the front axle mounts at the base of the forks or do I have to remove the whole leg?
Any comments appreciated
hensh is offline   Reply With Quote
Old 07-10-2013, 11:59 AM   #4940
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,443
They are strong, but you bend the center clamp ears if you crash.
Old 07-10-2013, 12:03 PM   #4941
jabroka
jabroka's Avatar
Oddometer: 338
Originally Posted by hensh View Post
Evening,
Not 100% sure on the Xco.. but on the Xchal the Reprom says you have to remove the fork to change the seals.
1993 suzuki GSXR-R
2007 BMW G650X CHALLENGE
jabroka is offline   Reply With Quote
Old 07-10-2013, 02:05 PM   #4942
hensh
Oddometer: 3
dust seals
Its only the dust seals I wish to replace not the oil seals
Old 07-10-2013, 02:24 PM   #4943
jabroka
jabroka's Avatar
Oddometer: 338
As far as I know its the same procedure.. you've to remove the fork leg to get to the dust seals/oil seals.
1993 suzuki GSXR-R
jabroka screwed with this post 07-10-2013 at 03:54 PM
Old 07-10-2013, 08:12 PM   #4944
jjmead1
now THAT"S a bike!
jjmead1's Avatar
Oddometer: 563
You are taking the legs off the bike for sure. might as well do a fork oil change as well plus any other work. I did both legs at about two hours time...having never done it before. I had a bit of help but did most of the work. My guess is the bushing is bad as well so might want to pick those up before you go in. Mine was just leaking and not cracked and the bushing was toasted.
jjmead1 is offline   Reply With Quote
Old 07-11-2013, 07:47 AM   #4945
hensh
Oddometer: 3
dust seals
I thought by removing the bolt at the base of the fork leg would allow the axle mount to slide off and therefore allow replacement of the dust seal without removing the leg or stripping the leg down.
Old 07-11-2013, 06:48 PM   #4946
mcgarrett
mcgarrett's Avatar
Oddometer: 160
If anyone has the Scheffelmeier rally bash plate with tool box, I'd greatly appreciate hearing your feedback on this product. Thanks.
Trans Lab 2013 Ride Report
http://advrider.com/forums/showthread.php?t=903321
mcgarrett is offline   Reply With Quote
Old 07-11-2013, 07:35 PM   #4947
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,443
The fit and finish are good. I haven't had the opportunity to really go ride with it offroad.
Old 07-11-2013, 08:13 PM   #4948
jjmead1
now THAT"S a bike!
jjmead1's Avatar
Oddometer: 563
http://www.youtube.com/watch?v=W2G-b66F3es
different fork, ours is way simpler, but this is basically what you are gettin into and will relatively show you the innards of most upside down forks.
Obviously things are not ALL going to match up but use the search feature on YOUTUBE and watch a few videos they should all basically show you several slight variations on the basic steps.
Again I'd say plan on changing the bushing its cheap and the hard part is being done anyway.
Old 07-12-2013, 04:29 AM   #4949
mcgarrett
mcgarrett's Avatar
Oddometer: 160
Thanks Tim. Any thoughts on the design? Does the tool box stick out that much?
Old 07-12-2013, 06:02 AM   #4950
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,443
No more than a tool tube. You gain corner space, so it holds more than a tool tube. I need to make a roll for my tools, as playing tool tetris could get annoying.
Times are GMT -7.   It's 02:29 PM.
