Old 07-17-2013, 05:15 AM   #4966
Niedz
Niedz's Avatar
Oddometer: 614
what shifter is that? looks like the stock one almost.
fabrication fun, rack n roll
Niedz is offline   Reply With Quote
Old 07-17-2013, 07:46 AM   #4967
mcgarrett
mcgarrett's Avatar
Oddometer: 150
Tim,
Thanks for the tool box pics. How was the installation?
Trans Lab 2013 Ride Report
http://advrider.com/forums/showthread.php?t=903321
mcgarrett is offline   Reply With Quote
Old 07-17-2013, 09:06 AM   #4968
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,359
Originally Posted by mcgarrett View Post
Tim,
It bolts right on. The front is attached with brackets that require replacing the two lower engine mount bolts (included) instead of 2 - 6mm bolts into the frame.
tbarstow is offline   Reply With Quote
Old 07-17-2013, 09:07 AM   #4969
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,359
The shifter is an aluminum Moose Racing WR450 shifter.
Old 07-18-2013, 01:55 AM   #4970
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,976
Originally Posted by tbarstow View Post
Goodie Box:
I thought your sandwiches were in there
What footpegs are you using mate?
*** New Sibirsky Extreme Trail DVD Trailer HERE ***
Moroccan Extreme 2011 DVD available HERE
World Motorcycle Altitude Record video HERE
Sibirsky Extreme - The Home of Adventure Motorcycling in Siberia and Mongolia - On Facebook
Colebatch is offline   Reply With Quote
Old 07-18-2013, 01:59 AM   #4971
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,359
The oil bottle is the sandwich place holder.
Those are the Fastway Evo pegs. You have to machine the spacer to make them fit correctly.
Old 07-21-2013, 07:52 AM   #4972
tommyvdv
tommyvdv's Avatar
Oddometer: 416
4800 euro's for a 2008 with ABS only 5000km on it. good deal or not?
oh and there's extra set of excel SM wheels included in that deal.
new the bike was just under 10k I believe.
thanks!
tommyvdv is offline   Reply With Quote
Old 07-24-2013, 02:52 PM   #4973
1derer
Sh*t Where am I?
Oddometer: 224
Kind of begs the question what is considered high miles for a Xchallenge? I have been looking at the X for sometime now as they are getting harder to find and wonder the service that can be expected from the engine or other spinning parts??
1derer is offline   Reply With Quote
Old 07-24-2013, 03:16 PM   #4974
slide
A nation in despair
Oddometer: 21,122
Tough to say due to different usage patterns, but the engine is almost identical to the one used in the F650 for many years. I"ve heard of those going over 80,000 miles w/o a rebuild.
Why be born again when you can just grow up?
slide is offline   Reply With Quote
Old 07-24-2013, 04:12 PM   #4975
MTBiker78
ENDURO Wanabee
MTBiker78's Avatar
Oddometer: 184
Mine Xchallenge has 48.000km on the clock. Ridden quite hard. For last 5 years just one major failure - sprag clutch - after aprox 10.000 km. thats all.
a lot of mud sand and water riding causes that Im replacing all the bearings once at one-two years (wheels, steering, rear suspension).
Regards
Lucas
I have a new challange ..... X-Challenge ....
www.vimeo.com/mtbiker
http://picasaweb.google.com/lukasz.lechowicz/XChallenge
MTBiker78 is offline   Reply With Quote
Old 07-24-2013, 05:00 PM   #4976
mcgarrett
mcgarrett's Avatar
Oddometer: 150
Any thoughts on trying to rehab a gas cap that won't seal properly vs. just buying a new one? That seems to be what's causing my off-and-on issues with the X-Tank feeding into the main. Everything else checks out ok.
Old 07-24-2013, 09:43 PM   #4977
jjmead1
now THAT"S a bike!
jjmead1's Avatar
Oddometer: 558
A guy in the X Country thread tried a few different seals. Head over there and search, as I recall it was with mediocre results but i could be wrong.
Actually I think it was Neidz first post on top of this page.....
jjmead1 is offline   Reply With Quote
Old 07-24-2013, 11:37 PM   #4978
Square1
Square1's Avatar
Oddometer: 113
I took the gas cap apart , made another thin gasket out of some material I had around.
Added the gasket under the OEM gasket, also used a new o ring on the tank lock lock cylinder.
The gas cap closes now tight and gives a good seal to for the Aux tank to work.
Check also the connection of the TTtank fuel line to the bikes tank.
I have seen some problems with that on a friends bike.
M
Square1 is offline   Reply With Quote
Old 07-24-2013, 11:40 PM   #4979
Square1
Square1's Avatar
Oddometer: 113
Just saw that you have the X tank.
You need a hoseclamp where the fuelline connects to the OEM tank vent.
The supplied cabletie will nor seal properly.
M
Old 07-25-2013, 12:10 AM   #4980
Colebatch
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,976
I have 140,000 km on mine , about 2/3 off road, and feel the engine has just about had enough. I also think alloy frame parts, (lower frame legs and swingarm) have wear. I think for gentlemanly use, mostly commuting or onroad, the bike should not be much different to the F650 GS that came before it, which could get to 200,000 km.
I could do a full engine rebuild but feel its wiser to buy a low mileage X-moto and swap my aftermarket over to it. Then all bushings and fittings are like new as well.
Times are GMT -7.   It's 05:54 PM.
