Old 09-25-2013, 10:22 PM   #5311
tommyvdv
tommyvdv's Avatar
Oddometer: 420
Originally Posted by LTCOliverNorth View Post
My front and rear rotors warped to the point where I needed to swap them out, happened around 8K miles.
Rear was fairly worn, very close to minimum thickness. Font was worn down too, but only to about 3/4 of minimum thickness.
after a bit of reading up I notice that the front rotor gets mentioned quite a few times. I'll mention it to the dealer when I visit for the callback freebies. 5000km, doesn't seem like a long time for a 250 euro part.
rotor surface is pretty much new. looks like a vynil but feels like a baby's bottom
TRW sells one they say will fit. anyone try that one?
tommyvdv is offline   Reply With Quote
Old 09-26-2013, 06:53 PM   #5312
Yukon Ho!
We can go ANYWHERE!
Yukon Ho!'s Avatar
Oddometer: 165
Braking Wave
Mine warped early too, ~4k mi. (No way it was rider's fault!)
I wanted a floating rotor this time, put this one:
www.bing.com/search?q=Braking+Wave+BW07FLD
Took maybe half an hour, first time doing that.
Last 4k mi have been great!
Not doing stoppies on it but not babying it at all.
Yukon Ho! is offline   Reply With Quote
Old 09-26-2013, 08:21 PM   #5313
LTCOliverNorth
Peeping Tom
LTCOliverNorth's Avatar
Oddometer: 782
Good find on the front rotor. I had an issue sourcing the rear in the proper size. Braking had a rear, but discontinued it (?). At least that's what my searches yielded at the time. I ended up taking it in the ass and going with an OEM BMW rotor from MaxBMW.
2007 BMW G650X Challenge
2005 BMW R1200GS
2002 Ural Patrol T
LTCOliverNorth is offline   Reply With Quote
Old 09-26-2013, 09:02 PM   #5314
Yukon Ho!
We can go ANYWHERE!
Yukon Ho!'s Avatar
Oddometer: 165
Scheffelmeier carries a rear one, 99 Euros (US$134.)
http://www.bashplates.de/BMW-G-650-X...ement::61.html
To my untrained eye it looks to have a lot less actual metal than the OEM one, suggesting to my untrained mind it may hold less heat and hit a braking limit, and maybe wear out faster than OEM too...??
And, why's a German company named France Equipment?
Old 09-27-2013, 12:20 AM   #5315
tommyvdv
tommyvdv's Avatar
Oddometer: 420
cant seem to open that link. so basically The expensive oem front rotor is shite?
Old 09-27-2013, 04:49 AM   #5316
Niedz
Niedz's Avatar
Oddometer: 634
when i bought my x-co it had a warped rotor, they replaced it for me. then not too long after that the new (OEM) one became warped. next time around im definitely gonna do a floating rotor.
fabrication fun, rack n roll
Niedz is offline   Reply With Quote
Old 09-27-2013, 04:58 PM   #5317
Yukon Ho!
We can go ANYWHERE!
Yukon Ho!'s Avatar
Oddometer: 165
Floating Front Rotor
Sorry, try this:
http://www.bing.com/search?q=Braking+Wave+BW07FLD
OEM one is fine, just not as forgiving as a floating one.
Old 09-28-2013, 07:03 AM   #5318
jjmead1
now THAT"S a bike!
jjmead1's Avatar
Oddometer: 562
lighting
So I lost my running headlight or low beam. Bright still works. Riding home the other night a motorist informed me that I lost my tail light, but brake lights work.
I tried my best to locate an obvious cause. Any one here have deeper places to look or maybe something that is too obvious for me to notice. I am trying very hard to not have to be raped by the dealership
jjmead1 is offline   Reply With Quote
Old 09-28-2013, 08:40 AM   #5319
beerbuzz
beerbuzz's Avatar
Oddometer: 246
Maybe its just time for bulbs? Id start checking all the fuses and grounds if bulbs are good, the timing is a little odd.
12 G650 sertao
03 DRZ400e
03 YZ250F
99 TTR225
beerbuzz is offline   Reply With Quote
Old 09-28-2013, 11:03 AM   #5320
jjmead1
now THAT"S a bike!
jjmead1's Avatar
Oddometer: 562
Replaced the bulbs. Opened up the harnesses and the previous owner removed every single non essential piece of electronics including the dash to race it as a Baja bike. It has been rewired but needless to say it is a mess.
My early thoughts are an ignition area problem as both those lights should come on with a key turn.....
So far no exposed frayed wire or easy to notice problems....just a lot of maybe it's this problems.......
jjmead1 screwed with this post 09-28-2013 at 11:20 AM
Old 09-28-2013, 06:07 PM   #5321
MJS
MJS's Avatar
Oddometer: 1,905
Does the high beam turn on/off with the handlebar switch?
The wiring is simple, power from the key to the handlebar switch to the headlight. Since your low beam and tail light are out, I'd start at the ignition switch and trace it out from there.
Since the wiring is a mess, the first thing to do is get a wiring diagram or factory manual.
"You can follow me, but it's gonna hurt"
http://www.blackswanmoto.com
MJS is offline   Reply With Quote
Old 09-28-2013, 06:42 PM   #5322
jjmead1
now THAT"S a bike!
jjmead1's Avatar
Oddometer: 562
Yea I gave up and submitted to the dealership.
I was thinking the ignition as well due to the commonality of the lights being activated with a key turn. Several ignition woes already.
Old 09-28-2013, 06:45 PM   #5323
jjmead1
now THAT"S a bike!
jjmead1's Avatar
Oddometer: 562
Anyone have experience with these lights?
Anyone mount Aux lights from the top of the Triple clamp. I was thinking of doing that and removing the turn signals and dremeling out the plastic fairing just a touch.
Old 09-29-2013, 06:02 AM   #5324
SteveDennehy
Steve
SteveDennehy's Avatar
Oddometer: 242
UniFilter PreFilter bracket
When I fitted the UniFilter PreFilter, I found, as has been reported here a few times, that the supplied bracket does not fit. It's easy enough to modify, but I prefer stuff that actually fits.
So I sketched out a bracket, and got one cut out of aluminium.
Everything lines up.
Sandblast, paint, and I'll be happy.
I contacted UniFilter, and they has no idea that there was an issue with the bracket. They now have my sketch, and hopefully will use it to modify their design.
You can download the DXF from http://www.wilddog.za.net/forum/inde...209#msg2597209 (I can't figure out how to attach it to this post). You are welcome to use it to cut your own. I used 3mm aluminium, which is probably too thick.
SteveDennehy screwed with this post 09-29-2013 at 01:33 PM
SteveDennehy is offline   Reply With Quote
Old 09-29-2013, 12:14 PM   #5325
motorrat
Oddometer: 88
I used longarmed steering damper clamps with a Ram ball.
motorrat is offline   Reply With Quote
Times are GMT -7.   It's 10:37 AM.
