Old 11-25-2013, 11:43 PM   #5476
tommyvdv
tommyvdv's Avatar
Oddometer: 416
Originally Posted by Erik RS View Post
Tommy you'll receive mail
i'm building up quite the "IOU"
thanks!
tommyvdv is offline   Reply With Quote
Old 11-27-2013, 01:05 PM   #5477
jabroka
jabroka's Avatar
Oddometer: 338
tidying up wires/connections
hey guys,
as some may know, having the TT fairing kit with twin headlights+ GPS + 12v socket, water temp gauge, etc. the wiring on the bike quickly becomes a rat's nest, with many cables coming from the battery and fuses and relays all over the bike.
So I decided to get a power distribution block, and after a lot of forum reading, the choices came down to 3 options:
Centech fuse block
Fuzeblocks unit
PDM-60
The PDM is for sure, the most tech advanced block, very small, no fueses, software configurable, waterproof etc. price is @ $200
The centech unit is a well proven block, I found no issues with this unit, no integrated relay and its the cheapest, around $60
The fuzeblocks unit is right in the middle. integrated relay (for switched applications) medium sized and uses mini fuses. price is about $90
At first, I was all about the PDM60, but its double the price of the fuzeblock and it seems it would be impossible (or at least very hard) to repair or "jump" in case of a failure in the middle of nowhere.
So I went for the fuzeblocks unit.
Install is very simple, 2 wires coming from the battery, 1 wire to a switched 12v feed, thats it.
It has 6 + and 6 - connections, just select if the accesories are constant fed or switched by moving the fuses.
1993 suzuki GSXR-R
2007 BMW G650X CHALLENGE
jabroka screwed with this post 11-27-2013 at 04:23 PM
jabroka is offline   Reply With Quote
Old 11-27-2013, 04:15 PM   #5478
mtncrawler
mtncrawler's Avatar
Oddometer: 1,076
Originally Posted by jabroka View Post
Centech fuse block
Fuzeblocks unit
PDM-60
So went for the fuzeblocks unit.
Thanks for the write up..
I'm just researching/considering this mod myself..
2007 BMW 650 XChallenge..
2009 BMW R1200 GSA..(Gone.. )
2004 BMW R1150 GSA (Gone.. )
"You think dogs will not be in heaven? I tell you, they will be there long before any of us." Robert Louis Stevenson
mtncrawler is offline   Reply With Quote
Old 11-27-2013, 05:10 PM   #5479
Yukon Ho!
We can go ANYWHERE!
Yukon Ho!'s Avatar
Oddometer: 152
Pdm60
I did PDM60 in 2011. Zero issues in 18 months. Love it.
Fuses = ten less things I have to carry and think about and access to swap.
Mounted the PDM right under the seat, easy to check.
To clean up the battery rats nest I like Powerlet's Termin-8. Yes I cut the fuse holder out of that too!
Yukon Ho! is offline   Reply With Quote
Old 11-27-2013, 08:36 PM   #5480
advFord
advFord's Avatar
Oddometer: 451
hey guys,
What switched wire did you tap? (location, color?)
Those who dare, risk defeat. Those who don't, ensure it.
Places Beyond: California to TDF over 8 months Ride Report
Places Beyond Website
Facebook
Instagram @PlacesBeyond My Spot
advFord is offline   Reply With Quote
Old 11-28-2013, 04:21 AM   #5481
jabroka
jabroka's Avatar
Oddometer: 338
Carrying mini fuses is not that big of an issue for me, the fuseblocks unit has place for 2 spares (more if you dont use all outputs) and so does the bike fuse box..
As for access, only 2 dzus bolts to remove the fairing.. no issues there either..
If I installed it under the seat, Id still have a lot cables going from there to the nav tower, it kind of beats the purpose I think.
Glad the PDM worked for you. its a very nice unit and in many aspects, way better than the rest, but I just felt more confident with something I can repair in the middle of nowhere.
1993 suzuki GSXR-R
Old 11-28-2013, 05:50 AM   #5482
jabroka
jabroka's Avatar
Oddometer: 338
If I remember correctly, I connected it to one of the two wires on the ignition switch wire loom.
I'm away from home now on a work trip but I'll be back in a few days, I'll check it and let you know.
1993 suzuki GSXR-R
Old 11-28-2013, 10:42 AM   #5483
NVTS
stupid hipster dufus
Oddometer: 630
Is the air shock lighter than a conventional spring/oil bath type?
NVTS screwed with this post 12-03-2013 at 04:12 AM
NVTS is offline   Reply With Quote
Old 11-28-2013, 12:25 PM   #5484
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,552
I have one. I'm about 25 miles west of DC. I had it in the flea market for $100 I think. PM me if you're interested.
Marc
07 XChallenge
Butters is offline   Reply With Quote
Old 11-29-2013, 05:57 AM   #5485
tommyvdv
tommyvdv's Avatar
Oddometer: 416
have one, using it but considering a spring.
sucks being on another continent for these kinds of things
Old 11-29-2013, 09:20 PM   #5486
LJRAT
LJR Adventure Tours
Oddometer: 59
ABS Removal
Anyone have a successful time removing the ABS from their bike?
LJRAT is offline   Reply With Quote
Old 11-29-2013, 11:35 PM   #5487
TobyG
be happy :)
TobyG's Avatar
Oddometer: 544
http://www.michaelbense.de/g650x/for...pic.php?t=3375
"a scoot (that wouldn't go more than 28mph if you dropped it out of an airplane)" ~duck
"If loud pipes saved lives, then ambulances would run straight pipes instead of lights and sirens." ~Phlemdog
This is why I always wear gloves. How you gonna wipe your butt with hands covered in bandages? ~MrBob
TobyG is online now   Reply With Quote
Old 11-30-2013, 02:16 AM   #5488
NVTS
Oddometer: 630
Another option.
Remove the front brake line, ABS sensor and short line from the master cylinder
Replace the front brake line and banjo bolt with the OEM BMW non ABS part.
Loop the smaller line from the right side distribution block back on itself.
Pull the ABS fuse, tape over the light on the dash.
For the permanent removal you'd need front and rear brake lines and the front banjo bolt at a minimum. I neutered the system on mine so I could raise the bars significantly and retain the resale value. NVTS
Old 11-30-2013, 04:35 AM   #5489
Jholmes105
GORIDE
Oddometer: 82
TT Tank
Does anybody happen to have a TT tank they want to sell? I would love to find one collecting dust in a garage that somebody wants to get rid of/ Of course it is for my G650 XChallenge!
JP
Jholmes105 is offline   Reply With Quote
Old 11-30-2013, 09:58 PM   #5490
LJRAT
LJR Adventure Tours
Oddometer: 59
Originally Posted by TobyG View Post
Mechanical completely done, then I did the full electrical conversion per this post but still having difficulty with the speedo, any way i can contact this post author?
Times are GMT -7.   It's 07:45 PM.
