Old 01-30-2004, 01:21 PM   #1
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Supertrapp IDS2 on '03 KTM Adventure
To those that are interested, I recently installed a Supertrapp IDS2 “quiet core” muffler on my ’03 Adventure.
Part number 611-96002 is, according to Supertrapp, actually intended for pre ’99 LC4, but by drilling a new hole approximately 7/16” above the existing hole on the “S” pipe mount, (that, or find a longer rubber mounting bracket) you can easily install it on a later bike with the stock turn signals. If no turn signals are present, no additional hole is necessary.
I currently have 8 discs installed. Jetting with the OEM BST40 carb has been changed from the stock 152.5 MJ to a 157.5 MJ in warm weather and 160 MJ in cold. The needle clip was moved down 1 from the 3rd to the 4th notch from the top. I drilled the vacuum piston ports out to .125” (1/8”).
I made a airbox side cover from 1.5MM carbon fiber plate with a port size of approximately 4 sq. inches. The bike runs quite well, sounds better than stock, but is not so loud as to attract unwanted attention on the street. Acceleration and throttle response are improved, both over stock, and with the IDS2 alone with no jetting or air box changes. Vibration is minimal and possibly slightly less than the stock bike. All impressions are based on riding at sea level to 1,000 above.
I have felt no reason to alter the low speed air or fuel jets, or the low speed fuel mix screw at this time.
For those having trouble finding main jets, they are the same as those used on the 42 HSR Mikuni sold as a performance carb for Harley-Davidsons. In other words, almost any Harley dealer or custom shop should have some.
At this point I feel that I can recommend the IDS2 for installation on a '03 640 Adventure. I will continue to make modifications and report any results.
Last note, that stainless is hard as hell, so drill slow, push hard and use drilling lubricant.
Regards,
Chris
So... how's tricks?
creeper screwed with this post 04-27-2005 at 08:29 AM
creeper is offline   Reply With Quote
Old 01-30-2004, 01:24 PM   #2
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Back side image.
So... how's tricks?
Old 01-30-2004, 01:29 PM   #3
R-dubb
Dubbious Adventurer
R-dubb's Avatar
Oddometer: 4,893
I like Supertrapps. One for my KLX just came today to replace the old, rusty, nasty sounding Arrow that was on the bike.
Best feature is spark arrestor... Being able to tune the pipe is nice too! I paid $240; how much for yours?
R-dubb
R-dubb is offline   Reply With Quote
Old 01-30-2004, 01:38 PM   #4
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Said R-dubb:
R-dubb
I'm a dealer... so lets just say, less than what you paid. But not by much, $240 is a very good price if what you got is an actual IDS2 with a "quiet core".
Creeper
So... how's tricks?
creeper screwed with this post 02-09-2004 at 03:45 PM
Old 01-31-2004, 10:12 PM   #5
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Here is a view of the front muffler/connector pipe hanger.
So... how's tricks?
Old 01-31-2004, 10:13 PM   #6
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
And a view of the carbon fiber air box cover. I am in the process of making yet another air box cover using 5 UNI filter pop-in air filter vents.
So... how's tricks?
Old 01-31-2004, 10:40 PM   #7
HighwayChile
greetings from Wa state
HighwayChile's Avatar
Oddometer: 4,400
All right, is this a new bike? or do you have underlings cleaning it? since its so frigin' wet , OK I am jealous of how clean it is. Thanks for the post, join in for the search for the mex/canada trail, we may need Washington help, I am going to work on some N. cascade ( in spring ). BTW on an LC4, or transalp, or quota
HighwayChile is offline   Reply With Quote
Old 01-31-2004, 11:30 PM   #8
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Said HighwayChile:
I'm one of those sick individuals that takes as much pleasure in wrenching and cleaning as I do riding. Sorry, I don't mean to set a bad example.
Creeper
So... how's tricks?
Old 02-01-2004, 11:13 AM   #9
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,735
Said creeper:
Creeper
you're setting a good example, but be prepared for the ribbing. i strip mine all the time to clean it... its all good!
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 02-01-2004, 06:05 PM   #10
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Said Loadedagain:
I can see things falling of better when they are clean, like me for example.
Now if we could just get Scotty to hustle it up with that low mount fender... I'd have a new thing to buy and polish!
Creeper
So... how's tricks?
Old 02-01-2004, 06:12 PM   #11
Flanny
Flanny-it-up!
Flanny's Avatar
Location: Ottawa, Ontario, Canada, the World, the Universe
Oddometer: 2,738
Good grief...not another clean-bike poster...
That's it...I'm only posting pictures of my bike dirty form now on...this clean bike business is just getting too trendy for me...
Flanny is offline   Reply With Quote
Old 02-01-2004, 08:23 PM   #12
Loadedagain
making chips
Oddometer: 26,735
Said Flanny:
flanny likes dirty girls. i like mine to look clean til you get them home
Old 02-01-2004, 10:19 PM   #13
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
I start out with a simple install info for a IDS2 and look what happens... dirty girls and clean bike abuse.
The horror of it all.
Flanny, if your bike gets all dirty, will Loadedagain lust after it and want to take candid photos of it in a short skirt?
Creeper
So... how's tricks?
Old 03-02-2004, 07:24 PM   #14
HighwayChile
Oddometer: 4,400
ahh, BC , true paradise....
Old 03-02-2004, 07:44 PM   #15
dagwood
dagwood's Avatar
Oddometer: 35,427
They always kick me out when I break out the camera.
dagwood is offline   Reply With Quote
Times are GMT -7.   It's 04:08 PM.
