Old 04-27-2008, 01:55 PM   #1
MartinDKtm OP
MartinDKtm's Avatar
Oddometer: 222
Klx 250/300 Acerbis tank How to get all the fuel out of it mod
Ok a few people have ask me on a few forum how I did install fuel lines in the tank and a fuel pump to gell all the fuel out of that tank so heres a small sketch and picture of the pump installed. I got the idea from a guy tha was on here, or tumper Talk or Kawasakiforums...I don't remember so I don't have to become famous because of this setup I posted.
Ok I did not took any picture of the internal mod so I did draw on the instruction sheet of the acerbis tank to TRY to show you what I did...
So now some explanations...first, remove petcock, 2- unscrew petcock filter #2. Now you will find a small rigid plastic tube under the filter. In the petcock you will see a small hole beside where the rigid plastic tube is insert. Thats the reserve hole. You can try to insert a line inside in it, I had to grind the line to fit it in. Or you can try to find another rigid plastic tube and insert it or cut in half the existing one...then put the line "D" +/-2" long with a 90 degree elbow with the other end in the petcock or on the other plastic tube that cut/find somewhere...I think its better not to grind the line and find cut a part of the existing one. (I will mod mine later with a second plastic line insted than inserting the line in strait in the hole, makes too mutch restriction).
So after that you need to make the lines that will go to the bottom of the tank. You need a plastic "T" with 2 long enough piece of tubing so they can reach the bottom of the tank wings. On the last "T" connection you need to put a +/-2" long tube (line "C"). Put that assembly in the tank by the gas cap. NOW for some peoples..you got to start taking beer or pray any god that you belieive in or have a punching bag or a friend to vent off frustration...And pic the steel wire of you choice and try to push or run the lines that needs to get in the bottom of the wings as I tried to draw on the picture...Yes its possible I done it in about 15 minutes...Don't forget that gravity can be your friend.
Once this is done, the +/-2" lines from the "T" (line "C") should point towards the petcock hole. Have another beer/pray or punch...and push that line thru the petcock hole so you can catch it from outside the tank. Plug it to the 90 degree elbow that is on the petcock and install the petcock on the tank.
Its now over for the tank part. Fuel pump following ....
Offroad? Is where everythings begin!
MartinDKtm screwed with this post 04-27-2008 at 02:21 PM
MartinDKtm is offline   Reply With Quote
Old 04-27-2008, 02:09 PM   #2
MartinDKtm OP
MartinDKtm's Avatar
Oddometer: 222
Ok fuel pump part. Now its easy. I bought a Mikuni snowmobile fuel pump. And installed it on the bike...a picture is worth a thousant words so heres the pictures...
So I will only explain the tubing routing here...Petcock line goes to the pump input, the output of the pump to a online filter then to the carb. And the darker line you see is the vaccuum source for the pump...It is plugged to the nipple left on the front of the carb when you remove the anti pollution thing.
So installation done. Im still experimenting that installation and its not perfect yet. I have some bubbles running in the lines somtimes so I think my pump may be faulty, Im still not sure of the vaccuum source. I may try to plug it to the crankcase vent to get the pumping action of the piston going up and down like on a 2 stroke engine or I may also try a pump that is design to run on a four stroke intake vaccum source instead of a pump design to have big succion from a 2 stroke engine base. I also want to add a second plastic tube to the petcock instead on inserting the line in the petcock hole.
So you now have the basic idea. Refine it and post your result you may have better ideas than me...Im open to suggestions.
Martin
Old 05-15-2008, 04:46 AM   #3
MartinDKtm OP
MartinDKtm's Avatar
Oddometer: 222
The actual pump is not good. Its design for big pulse from the up and down motion of a 2 strokes pistons since its normally connected to the base. I have a 4 strokes atv vaccum pump on order that is design to run in the intake vaccuum. Ill let you know how it works.
Old 05-16-2008, 04:18 AM   #4
MartinDKtm OP
MartinDKtm's Avatar
Oddometer: 222
So I got my new pump yesterday night and installed it. Now works like a charm. I end up installing an Actic-Cat Atv mikuni pump Arctic-Cat part number 0470-758. Its design for the 4 stroke intake vaccuum source.
Old 05-16-2008, 04:48 AM   #5
a16tony
a16tony's Avatar
Oddometer: 557
Nice application. Didn't know those pumps existed.
Tony
Everett, WA.
03 DRZ400S
a16tony is offline   Reply With Quote
Old 05-22-2008, 04:51 AM   #6
MartinDKtm OP
MartinDKtm's Avatar
Oddometer: 222
FOr the one who wants to know...I did test the range yesterday on the road. I had put road tires on it with a winshield and did a 535 miles (700 kilometer) trip yesterday. I did 165 miles (266 kilo) before engine stall. Then switched to the reseve and went on road back back again for another 48 miles (77 kilo) befor getting to a dead stop. I had bring some spare fuel to refuel...So I did a total of 213 miles (343 kilo) on a tank. Speed was steady at 68-74 mph (110-120km/h) at 6000-6500 rpm. Bike has a 300 barrel with wiseco piston, fmf Q4 with power bomb, n1tc, 132 main, 35 pilot.
Old 07-04-2008, 01:19 PM   #7
DaveRMS
(formerly GSNorCal)
DaveRMS's Avatar
Oddometer: 832
2009 KLX250s with Acerbis Tank
If you are looking for 2009 model issues, see this thread.
Rally Management Services is the source for Dakar-proven rally parts, bike builds, assistance, and training.
Rally Navigator - Roadbook Navigation powered by Google Earth. Create. Print. Share.
DaveRMS is offline   Reply With Quote
Old 11-11-2008, 08:36 PM   #8
redpillar
redpillar's Avatar
Oddometer: 794
Thanks for the great idea, I bought the other pump and mounted it this way, I paid about 35 bucks for it. Part number is: Arctic-Cat part number 0470-758. I made a couple of different couplings for the outlet of the tank, to try to clear the choke knob. I also fed the fuel lines into the tank from the outlet hole, up and over between the holes in the side of the tank. It only took a about fifteen minutes and some mucking about to get them in. Here is a shot of the first coupling.
This one worked the best.
The line on the lower right goes to the vacuum port on the front of the carb. The left hand fuel line is from the tank fitting via the stock petcock and the upper right line with the inline filter goes to the carb inlet.
Another shot with the plastic tank mounted
Another with the choke problem solved, I used a silicone gasket maker to seal the aluminium plate to the tank outlet.
Here is a shot of the shadow of the fuel line inside the tank.
And another looking inside the filler hole at the tee.
redpillar screwed with this post 12-28-2008 at 11:32 AM
redpillar is offline   Reply With Quote
Old 05-17-2009, 08:37 PM   #9
redpillar
redpillar's Avatar
Oddometer: 794
I have had a chance to run a few tankfulls through the bike and have easily got 300 KM out of a tank with about 4 inches left in the wings, I would say I could go another 20 to 30 KM before the tank runs dry. Mostly pavement but not being gentle on the throttle.
Old 05-26-2009, 05:44 PM   #10
slvrblt
slvrblt's Avatar
Oddometer: 15
What size fuel line did you use?
Bruce
2006 F650 GS
2004 R1150R Edition 80
slvrblt is offline   Reply With Quote
Old 06-05-2009, 10:37 AM   #11
redpillar
redpillar's Avatar
Oddometer: 794
I think it is 3/16 inside diameter but not sure. I bought some and it was too small. I wanted something I could see through to ensure fuel flow.
Old 09-07-2009, 04:32 PM   #12
mic_detonator
ride
mic_detonator's Avatar
Oddometer: 781
stripped bolt?
I tried today to get the two bolt holding the tank in place. And to my suprise the left one is stripped. Must have been the time i took it off an\d put it back on while doing the rebuild. any ideas it HAS to be the brass thread in the tank. I cannot seem to get around the rubber grommets though .
pm me if any one has any ideas! time to go ride, Hey at least it runs now could be worse.
mic_detonator is offline   Reply With Quote
Old 11-11-2009, 05:19 PM   #13
redpillar
redpillar's Avatar
Oddometer: 794
Sorry....A little late on the answer but, I took the metal washer/inserts out of the rubber grommets on the frame, this gave me a bigger diameter hole to work with and I was able to get the bolts in place. I guess you could retap the threads in your tank with a bottoming tap to fix your problem.
Old 06-23-2010, 11:08 AM   #14
Tom Blum
Tom Blum's Avatar
Oddometer: 128
Send a message via AIM to Tom Blum
hi folks!
I bought a 2006 KLX250S last fall.
I'm late to the party, but I have recently installed an acerbis tank and am installing the arctic cat fuel pump.
things are going great, but I'm a bit unsure of the vacuum source. I don't "speak" carburetor like some of you and hate to jump in and get killed by my own ignorance.
Could someone post a picture or a link to the carb with the emissions stuff removed and the vacuum port in clear sight?
Tom
Tom Blum is offline   Reply With Quote
Old 06-24-2010, 10:29 PM   #15
redpillar
redpillar's Avatar
Oddometer: 794
If you look at the seventh picture in this thread, you will see the carb on it's side, the vacuum port is foremost in the picture. It has a black cap on it in this instance.
http://www.kawasakiforums.com/forum/...ead.php?t=8886
Times are GMT -7.   It's 04:54 PM.
