Old 01-30-2004, 07:05 PM   #1
Bicycle Phil OP
Bicycle Phil's Avatar
Oddometer: 691
DR 650 backfire
I just test rode a 2001 DR 650, 5700mi, with a Supertrapp pipe and the carb has been jetted. With the bike in gear, clutch let out, and decelerating(throttle off) the bike was backfiring. Not a loud backfire. Your basic pup pup pup. Is this a potential problem, can it be tuned to eliminate the backfire? Otherwise all other functions of the bike seemed to be in order. Comments and suggestions from those who know are appreciated.
Bicycle Phil is offline   Reply With Quote
Old 01-30-2004, 07:24 PM   #2
Rocket Ron
Oddometer: 206
The only time my 98 DR 650 ever backfired was when the power source coil was going out. Easy fix but don't buy the wiring harness from Suzuki. The coil can be found by it's self. I found mine at Ricky Stater, in El Cajon, Ca. He Told me that a Yamaha coil also works. (Forget which model. )
I have never changed the pipe on my bike so I can't coment about any back fires that may be coming from the pipe.
Rocket Ron is offline   Reply With Quote
Old 01-30-2004, 10:08 PM   #3
P7HVN
P7HVN's Avatar
Oddometer: 136
That's pretty common on big singles with aftermarket pipes. Can be reduced by jetting changes.
P7HVN is offline   Reply With Quote
Old 02-01-2004, 05:25 PM   #4
Burren Rider
Aussie Adventurer
Burren Rider's Avatar
Oddometer: 1,819
The backfiring on deccelaration is a fair sign that the bike is running a tad rich (which is infinately better than it running lean). If this is the case then I wouldn't think it is too much of a problem.
Burren Rider is offline   Reply With Quote
Old 02-01-2004, 05:43 PM   #5
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,613
Not an issue at all. According to Mikuni's own website, this is normal for tuned engines.
See section #4
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 02-01-2004, 07:56 PM   #6
Bicycle Phil OP
Oddometer: 691
DR 650 backfire
Thanks for the responses and info.
Old 02-02-2004, 01:49 AM   #7
Possu
de-nOObed!
Possu's Avatar
Oddometer: 5,218
I am under the impression that backfiring when decelerating was due to running lean, not rich?
This happened occasionally with my DR600. Try screwing the pilot mixture screw out in 1/8 turn increments. If the pilot mixture is on the engine side of the carb , then it's controlling fuel, screwing it out will increase fuel & vice versa.
Adjusting this screw is only for throttle reponse from a closed throttle , up to about 1/4 throttle max. After that, it's down to needle height & then main jet from 3/4 to full throttle.
BTW, if adjusting the mixture screw, it may be worth your while to remove it first & then grease it prior to replacing it. I've had Suzuki's in the past where it's seized in place. As they're normally recessed in to the underside of the carb body, they're difficult to unseize & it's easy to do damage. Watch out for the spring.
If you remove it, first screw it in slowly, counting the number of turns until it stops - do not screw it tight. When you replace it, screw it home gently, then screw it out to the original setting plus 1/8 turn. Keep adjusting until it backfires no more.
Also check your air filter - my DR used to backfire through the carb sometimes, burning a hole in the air filter!
Steve
Possu is offline   Reply With Quote
Old 02-02-2004, 10:29 PM   #8
murgatroid42
Great Adventurer
Oddometer: 4,185
Stock Honda XR650L's like mine (the air-cooled engine), notoriously backfire, pup pup pup, as you call it. It's considered a "feature", not a problem.
murgatroid42 is offline   Reply With Quote
Old 09-23-2007, 04:02 AM   #9
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,427
I have the exact problem on my Dr600 ,
Turning the mixture screw makes an off idle change but not much.
It seems to me my bike only pings in 4th and 5th when riding 2 up ..
would raising the needle a notch cure this ?
Steve
stevh0 is offline   Reply With Quote
Old 09-23-2007, 11:11 AM   #10
CaptTurbo
CaptTurbo's Avatar
Oddometer: 1,099
I agree with Possu Steve. Popping on decell is a lean condition. Play with the mixture screw and see if you can reduce the problem. I don't think it's a big deal to worry about in any event unless it's more the a mild pop you're hearing.
"No Man's life, liberty or property is safe while the legislature is in session." --American lawyer, editor, politician, Judge Gideon Tucker (1826-1899)
CaptTurbo is offline   Reply With Quote
Old 09-23-2007, 11:17 AM   #11
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,427
I will hear a decent backfire - but only sometimes on the compression kickback .
The scenario goes like this .
The bike starts when hot usually 1st or second kick with no throttle and then it would idle .
if i go ride and get to an intersection where i would have to sit for a couple of seconds, it would only sometimes have a mild pop and die .. but then 1 or 2 kicks and it runs again ..
im really starting to dislike the bike ...
Old 09-23-2007, 11:18 AM   #12
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,427
is the std mufler not prone to backfiring a little .. or the little soft pup pup ..
i hate the std mufler so much...ewww :(
Old 09-23-2007, 11:25 AM   #13
CaptTurbo
CaptTurbo's Avatar
Oddometer: 1,099
I (for the moment) still have a bone stock '07 with the snorkle removed. The stock setup does have some gentle popping on engine braking. I'm at sea level and believe that this is normal. I just bought a second hand DJ kit and was planning to fatten the jetting to the DJ 150 and darned if that jet isn't the one that was missing from the kit. I'll be trying the DJ155 and hope that it will work with the stock pipe.
Old 09-23-2007, 11:30 AM   #14
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,427
how about just drilling out the jets myself?
Old 09-23-2007, 11:31 AM   #15
racer 07
Lock & Load
Oddometer: 691
Phil
As said above, back the mixture screw out 1/4 turn at a time and it will go away. Usually Super Traps wind up with the static idle a little rich.
racer 07 is offline   Reply With Quote
Times are GMT -7.   It's 09:45 PM.
