Old 03-19-2013, 03:24 PM   #76
meat popsicle OP
Ignostic
meat popsicle's Avatar
Oddometer: 14,247
Originally Posted by gunnerbuck View Post
When you were refilling did some oil get into the cartridge assembly down through the tube? If so it will come back up and actually leak out of the rebound dial for a while when the forks are assembled..
That was my thought too.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 03-22-2013, 05:46 AM   #77
ssbogger
Oddometer: 14
No, I don't think so. If oil went down that tube wouldn't it come back out of that tube?
The oil is actually leaking from exactly where the red arrow points to; between the aluminum nut and black plastic.
ssbogger is offline   Reply With Quote
Old 03-23-2013, 09:51 AM   #78
meat popsicle OP
Ignostic
Oddometer: 14,247
Maybe something in the assembly is loose, allowing fluid to infiltrate and make its way up there. Thing is that's inside the forks, so I don't know if that is by design or indicating a problem. Best ask a fork tuner who knows WP good.
Old 03-23-2013, 05:57 PM   #79
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,296
If oil is coming out there then it is just getting pressurized up from down below when you pump the damper rod down... What is happening is that the plastic guide bushing is hollow when you push it down into the oil the pressure escapes between that and the nut giving a bit of weepage... I would consider it normal and nothing to worry about...
gunnerbuck is offline   Reply With Quote
Old 04-01-2013, 03:16 PM   #80
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,296
Oil seals
What are the better oil seals out there now?
The best I have used were the Athena fork seals, they have never failed, in fact the ones on my original bike have been in there for five years without leaking, the only reason I took them out was to replace all the fork bushings... The sad part is that they are no longer readily available...
With no Athena seals available for my rebuild, I tried a set of moose seals {despite the warnings not to use them because they were junk}... In no time the left fork was leaking so I figured I must of messed up the seal and installed another new Moose seal... About 500 miles later that one started to leak too so I threw in an SKF seal into the left fork... Then after a 300 mile ride the Moose seal in the right fork gave out, so in goes and SKF seal to replace it... Now today the SKF seal in the left fork gave out I have 4 more of these seals kicking around but there is no way I'm going to use another one in these forks... So in goes my 5 yr old used Athena seal, I'll report back when it fails...
Oh, by the way, I can find no defect, dings or jaggers with the fork tubes, sliders or seal seat and the forks never leaked a drop prior to the rebuild... The rebound needle was sticky so I cleaned it up and replaced the O-Ring but that was all I could find wrong during the rebuild... I also dropped the oil level 5 mm in each leg to add more air spring cushioning and reduce chamber pressure shock to no avail...
I noticed that the garter springs around the top lip of the SKF seal are quite a bit smaller than those on one of the old NOK seals I had from prior... Maybe they just can't take the pressure...
Old 04-01-2013, 10:08 PM   #81
meat popsicle OP
Ignostic
Oddometer: 14,247
I recall reading that the stock seals are better than other choices (although Athena was not mentioned). I had a pair of Synergy seals, which Scuderia West put on the middle of last year, and after two real rides (long weekends in and about Mendocino NF and Death Valley) they are already leaking... the tubes appear cherry, but I could check them carefully too.
EDIT: I see there are more than one species of Synergy Seals for each model of forks, so maybe one is better than the other... I don't recall which I had, as they were given to me years ago.
I have lots of maintenance to do on my bike now - not a crash but several things became apparent on the last ride.
meat popsicle screwed with this post 04-03-2013 at 07:40 AM
Old 04-01-2013, 10:13 PM   #82
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,764
It is my understanding that skf seals are now the stock seals.
Old 09-21-2014, 11:20 AM   #83
Reset1
640-24-7
Reset1's Avatar
Oddometer: 72
hope it helps
i found this on youtube..
https://www.youtube.com/watch?v=WC0UDDbQcKY
'05 KTM 640 ADV
there is only one kind of adventure, the lc4 kind!!
Reset1 is offline   Reply With Quote
Old 09-21-2014, 10:34 PM   #84
bmwktmbill
Traveler
Oddometer: 5,218
Originally Posted by Reset1 View Post
Thanks Reset.
Everything helps.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 09-23-2014, 01:41 PM   #85
meat popsicle OP
Ignostic
Oddometer: 14,247
I know what a pirate's parrot feels like now. Weird perspective, but handy (or handless) for solo video work like this.
Did it match my guide or do I need to watch it and figure out what needs to be changed?
Old 02-26-2015, 12:36 PM   #86
meat popsicle OP
Ignostic
Oddometer: 14,247
Fork alignment notes
The discussion was longer than others in the Index thread appreciated but I think I have a clue of what's needed to align your forks during installation or after a mild crash. And some techniques for when you have had a harder crash (potential damage) or your just not sure they are working well and want to check things out.
Standard "bounce" method recommended by fork mfgs., bike mfgs., tuners, and almost every veteran user:
http://www.advrider.com/forums/showt...86958&page=434
Equal spring pressure modification via warewolf further down that page, as well as the methods offered by several tuners. Photo of the 2003 manual method here:
http://www.advrider.com/forums/showt...86958&page=435
Stiction (misalignment impeding free compression/decompression) - boon booni found a spec from Race Tech but notes this is a general guideline:
http://www.advrider.com/forums/showt...86958&page=438
http://www.advrider.com/forums/showt...86958&page=437
If you have a problem Derek outlined the max overlap method here:
http://www.advrider.com/forums/showt...86958&page=433
X-plane vs. y-plane alignment here and elsewhere:
http://www.advrider.com/forums/showt...86958&page=436
And thankfully the Peanut Gallery graciously stepped in to moderate our discussion; that begins here:
http://www.advrider.com/forums/showt...86958&page=444
More than enough for anyone in and around those pages.
Old 02-26-2015, 04:59 PM   #87
bmwktmbill
Traveler
Oddometer: 5,218
I had a set of BMW forks that look perfect but ate seals.
Got them rechromed and polished at a shop like this.
http://www.garrod.com/
They have worked perfectly since and it was worth the hassle based on the price of new.
Just polishing tubes if there is a shop near surely couldn't hurt.
b
Bill Shockley
Old 02-27-2015, 05:24 AM   #88
meat popsicle OP
Ignostic
Oddometer: 14,247
Thanks for sharing the tip Bill,
it makes me wonder if I should be polishing the fork sliders as a maintenance item.
If creeper was still hanging out here he tell me I'm gonna go blind doing it. Loadedagain would say it kills kittens. Miss those guys.
Old 02-27-2015, 10:44 AM   #89
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,764
You'll get harry palms from polishing your slider too often.
Old 02-27-2015, 06:57 PM   #90
rz35027
rz35027's Avatar
Oddometer: 240
Have you tried shortening the garter springs? They should unscrew somewhere in their circumference, cut 5(?)mm off the female end and screw them back together, reinstall.
It works like a charm on my 50mm conventional forks (stiction is not an issue) YMMV...
rz35027 is offline   Reply With Quote
Times are GMT -7.   It's 09:37 AM.
