Old 05-10-2008, 05:21 AM   #1
FUTURE OP
Left right out
FUTURE's Avatar
Oddometer: 742
Gear Shift shaft seal oil leak....
I have an oil leak from the gear shift shaft seal. It is spraying oil onto the centre stand and the frame below the gear shift. Part #9 in the below pic. How easy is it to replace this seal? Or should I just run some gasket goo around the seal and shaft to stop the flow?
Me WnRn blog.....http://rossmz.blogspot.com/
"el Lobo" 2002 1200 Bandit... For sale
1971 Honda CL450 being brat'ed/cafe raced.
2009 Triumph Speedmaster.
FUTURE is offline   Reply With Quote
Old 05-10-2008, 05:33 AM   #2
mcma111
mcma111's Avatar
Oddometer: 12,902
Seal Replacement
Nope, Gooping sealant on the leak isn't gonna cut it. It's an easy fix really. Clean the area first. Solvent on a rag, tooth brush, a can of parts wash or so. Get a pointed type of tool hopefully that is bent at the end. Stick it in the seal and work it out of there. A little on this side and then across from the start and just work around and massage it right out of there. Yeah the seal is pushed it there but it's not like it's welded in there. After you get it out and you have a new one in your hand apply some oil on the seal and slide it on the shaft. You really want to push it straight in. Find something that is slightly smaller than the outside diameter of the seal and deep enough that it will go over the shaft. Tap tap tap till it stops going in. It should look just like the one that you just took out except this one isn't leaking. Take it slow and good luck...
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
mcma111 screwed with this post 05-11-2008 at 05:59 AM
Old 05-10-2008, 05:45 AM   #3
FUTURE OP
Left right out
FUTURE's Avatar
Oddometer: 742
So so easy. Thank you. I love how easy it is to work on a BMW.
Old 05-10-2008, 12:02 PM   #4
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
a socket works well tapping it in. make sure you clean out the area between removal of the old and insertion of the new.
datchew is offline   Reply With Quote
Old 05-10-2008, 05:58 PM   #5
Rubber Cow
GS Dork
Rubber Cow's Avatar
Oddometer: 5,345
-Lay the bike on it's side
-Remove the shift lever linkage and arm
-Pull old seal out with cheapo dental tool with hooked end.
-Lubricate new seal and slide in place with the help of the proper socket
-Instal shifter bits and linkage
-Right bike
-Ride
"He had that rare weird electricity about him--that extremely wild and heavy presence that you only see in a person who has abandoned all hope of ever behaving"normally"."
HST-RIP
"Woof, woof woof woof ...woof woof!!!!!!!!!"
Cricket the Dog-RIP
Rubber Cow is offline   Reply With Quote
Old 05-10-2008, 06:51 PM   #6
FUTURE OP
Left right out
FUTURE's Avatar
Oddometer: 742
Again thanks heaps guys for the help.
Old 05-10-2008, 07:42 PM   #7
Boojum
I Miss the PartyBoss
Boojum's Avatar
Oddometer: 5,967
I am actually doing the same thing to my R90 this weekend.
Thanks for the reassurance.
Boojum!
"I aint no ruff guy, aint no tuff guy. Don't get out much, and don't dress up fly".......
Boojum is offline   Reply With Quote
Old 05-10-2008, 09:07 PM   #8
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Boojum!
Ya, but your version will be something like....
Originally Posted by Rubber Cow
-Clean bike meticulously
-Make sure you didn't get any goop on the bike
-Wipe bike with a diaper
-Right bike
-Prepare bike for full wash, wax, and detail
-Ride
Booj... if the compound does cleaning and detailing that can make my GS look as clean as your GS, I might have to give you some business.
Old 12-21-2009, 11:30 PM   #9
SamH
90S on the bench
SamH's Avatar
Oddometer: 436
Figured I'd revive this post instead of starting another.
A couple of months ago my R90 shifter seal was leaking so I replaced it. It seemed like a really loose fit on the shaft at the time but it stopped the leak. Now it's started up again.
Could the shaft be worn?
SamH is offline   Reply With Quote
Old 12-23-2009, 05:14 AM   #10
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,708
Try dressing the bit you pull out (selector lever) with some fine wet & dry sandpaper.
If it doesn't fix it the change seal interval may be extended.
Rucksta is offline   Reply With Quote
Old 02-28-2010, 09:43 PM   #11
TonyT1200
TonyT1200's Avatar
Oddometer: 67
I got this issue on my XR80R. Thanks for the info. Time to fix the leak!
TonyT1200 is offline   Reply With Quote
Times are GMT -7.   It's 07:24 AM.
