Old 12-19-2012, 05:31 PM   #841
8gv
Oddometer: 2,479
Kicking...
What I do, YMMV:
1) Make sure the carb mixture screw is adjusted right!
2) With kick stand down, stand on pegs, stiff leg on kicker, drop your weight on it.
3) Go ride!
If you can't rest it on the stand:
1) Push kicker down with bent knee until compression is felt. Quickly extend leg as you climb up on kicker. It may take more than one of these if the first try sucked.
8gv screwed with this post 12-19-2012 at 08:01 PM
8gv is offline   Reply With Quote
Old 12-19-2012, 06:35 PM   #842
dan-o
Oddometer: 81
again,thanks for the input, I will find the manuals and into the valve adjustment. According to the owners manual the oil was changed at 500 and 3500 miles, as I stated before the bike doesn't appear to have been abused at all. I was just suprised the cam chain adjustment was so close to the end.
As far as kick starting it, guess I gotta beef up a little
dan-o is offline   Reply With Quote
Old 12-20-2012, 05:38 AM   #843
stevemd
stevemd's Avatar
Oddometer: 81
Same here though with 15k on the kick lever it is pretty loose, might need replacing.
stevemd is offline   Reply With Quote
Old 12-20-2012, 10:10 AM   #844
dan-o
Oddometer: 81
can it be replaced without a total tear down of the engine?
Old 12-20-2012, 03:21 PM   #845
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
What can wear/need replacing with the kickstarter assembly?
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is online now   Reply With Quote
Old 12-20-2012, 04:55 PM   #846
dan-o
Oddometer: 81
I think he was thinking cam chain
Old 12-22-2012, 02:53 PM   #847
beeper
Badger tickler
beeper's Avatar
Oddometer: 780
Took a pleasure ride today. The little KLR is quite capable.
'12 F800GS
'00 Bandit 1200
beeper is offline   Reply With Quote
Old 12-22-2012, 04:54 PM   #848
HandKPhil
HandKPhil's Avatar
Oddometer: 503
Winter exploration
Nice looking ride. They are fun little exploration machines, aren't they? Both of my KLR250's are sleeping (minus their batteries) in my garage at the moment, but I did take my new '99 DR350SE out for an icy blast today. It hit about 30 degrees here, but it was sunny for a couple of hours so I decided to ride.
HandKPhil
HandKPhil is offline   Reply With Quote
Old 12-22-2012, 04:59 PM   #849
XDragRacer
Oddometer: 3,224
Originally Posted by HandKPhil View Post
Both of my KLR250's are sleeping (minus their batteries) in my garage at the moment, . . .
Don't need no stinkin' batteries to run 'em, if I read the wiring diagram correctly.
Looks like an independent exciter coil on the stator powers the CDI, totally separate from the battery charging and storage circuit.
XDragRacer is offline   Reply With Quote
Old 12-22-2012, 05:25 PM   #850
gasolinetom
Mechanic
gasolinetom's Avatar
Oddometer: 21
ive left my parking light on a time or two and totally drained the batt. still starts just fine. just an extra kick or two. the battery is just for the lights, i hear.
gasolinetom is offline   Reply With Quote
Old 12-22-2012, 06:49 PM   #851
newcastleadam
Artful Tagger
Oddometer: 3,455
Yup, they'll start and run with no batteries. Believe lights and signals will work as well.
Adam
Old 12-22-2012, 07:46 PM   #852
gasolinetom
Mechanic
Oddometer: 21
i removed signals a long time ago
Old 12-23-2012, 04:26 PM   #853
bigfishs
Oddometer: 46
Very nice Did you have the bike professionallly painted? Also, what is the cargo rack and bag you have on there? Also, arent you fecking freezing riding that thing?
bigfishs is offline   Reply With Quote
Old 12-23-2012, 05:10 PM   #854
beeper
Badger tickler
beeper's Avatar
Oddometer: 780
The PO rattle canned it flat black, looks good enough and easy to touch up. The cargo rack was on an old Honda CB200 that I cut down and modified to fit, then coated it with truck bedliner. The bag is an inexpensive Bilt from Cycle Gear.
With my homemade wind defelectors, windshield, heated grips and winter gear I'm comfortable in freezing temps..to a point. If it's 15 degrees or less the bike stays parked.
'12 F800GS
'00 Bandit 1200
Old 12-23-2012, 09:26 PM   #855
8gv
Oddometer: 2,479
They grow 'em tough in WI.
Times are GMT -7.   It's 05:04 AM.
