Old 01-07-2013, 07:37 AM   #871
redneckdan
Hold my beer & watch this
Oddometer: 584
I just got done rebuilding the forks on my wifes 250. For future record the damper rods use a 9/16" nut as a holder tool, the klr650 uses a 5/8" nut. I was bale to find the 650 info on the internet but not for the 250. I had to jamb a piece of 1x1 down the damper and use the air impact to spin the bolt out.
klr650 damper rod holer 5/8" nut
klr250 damper rod holder 9/16" nut
Fly Rods, Kids and a KLR
redneckdan is offline   Reply With Quote
Old 01-10-2013, 09:22 AM   #872
dfye55
dfye55's Avatar
Oddometer: 272
prep for ride out west
I need bash plate for the Utah backcountry discovery route http://www.backcountrydiscoveryroutes.com/UTBDR this summer. I see the Ricochet and a TCI,. The TCI includes side guards. Are side guards overkill? I'm an older conservative rider, but I have dropped the bike several times riding enduro routes.
Richochet http://utahsportcycle.com/store/klr250pic.htm
tci http://www.motorcyclegear.com/parts/...r250_1987.html
Thoughts, other recommendations?
Don '05 KLR 250 & '04 DR 200
dfye55 is offline   Reply With Quote
Old 01-10-2013, 12:11 PM   #873
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
For the KLR250 damper rod you can also use the back of a 13/16" spark plug socket (also the Super Sherpa).
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 01-10-2013, 12:25 PM   #874
XDragRacer
Oddometer: 3,218
The "ears" of the Utah Sport Cycle/Richochet (I think they're the same) bash plate do a good job of protecting the water pump housing and plumbing, in my experience:
Hogged out the oil drain hole for better flow path, avoiding bash plate when draining oil.
XDragRacer is offline   Reply With Quote
Old 01-10-2013, 12:30 PM   #875
dfye55
dfye55's Avatar
Oddometer: 272
Love the rocks eye view, thx
Sent from mobile
Old 01-10-2013, 02:50 PM   #876
XDragRacer
Oddometer: 3,218
You're most welcome!
TCI makes good products; I think I may have one of their stone guards:
I notice the Utah Sport Cycle/Richochet guard sells for $ 84.95; the TCI number for $ 224.95 (on sale); your bike, your call! IMHO, either product would be o.k; your preference and pocketbook remain key in your decision.
Old 01-10-2013, 03:52 PM   #877
8gv
Oddometer: 2,478
I installed a Ricochet brand bash plate on mine (after I stoved in the case). It works better than expected because so far I have zero crashes on it. I have dragged it over several logs and rocks though.
I did takes steps to mitigate the ringing noise that reflects off the plate back up at me. I cut some auto heater hose and wrapped it around the frame where the bash plate might touch it
8gv screwed with this post 01-10-2013 at 04:30 PM
8gv is offline   Reply With Quote
Old 01-11-2013, 06:27 PM   #878
skypilot
I Roam therefor I am
skypilot's Avatar
Oddometer: 707
I have had a Ricochet plate on my 08 KLR650 since it was a few months old. I have landed on it hard enough to destroy the engine several times. Works great still although it could use a hammer and a flat bit of pavement to flatten it out. Best money I ever spent
skypilot is offline   Reply With Quote
Old 01-12-2013, 04:47 AM   #879
Grinnin
Forever N00b
Oddometer: 2,894
Originally Posted by DrMoto View Post
Got a couple of 1.5W lights from superbrightleds.com (PLM series) . . . . They look a bit yellow from off-axis; more white head-on.
I am copying you shamelessly. I bought these for my KLR because I saw your post.
First surprise: superbrightleds.com charges only $2.99 shipping on $11.90 of product. This is great in an era of deceptively low prices and huge shipping charges.
Second surprise: The housings are aluminum. I don't know what waterproofness standard IP65 is, but I'll take a dip.
The light is bright and wide. The cone of white light is about 90-degrees (45-degrees each side of cenerline) then there's a narrow but distinct yellow halo around the edge. Your photo above is of this halo.
I'm even going to copy your mounting location although I'm handicapped by having only the 650 KLR. (I found your post by kinda thinking that a 250 would be nice.)
"The belief that there is only one truth, and that oneself is in possession of it, is the root of all evil in the world."-- Max Born, Nobel Physicist
Grinnin is online now   Reply With Quote
Old 01-13-2013, 12:51 PM   #880
newcastleadam
Artful Tagger
Oddometer: 3,455
Still putting together my as yet non-running 250 and a friend noticed two tapped holes on the swingarm. He convinced me I should put a mudguard there, and we fabbed one up.
Although it is Euro-spec (Belgian), seems to fit well
Adam
Old 01-13-2013, 02:23 PM   #881
8gv
Oddometer: 2,478
Nice mud guard. What's left to make the bike run?
I'll likely be flying over Gainesville this week on my way to St Pete. If you see a minimalist (2 seat) plane fly over, it's me.
Old 01-13-2013, 03:18 PM   #882
newcastleadam
Artful Tagger
Oddometer: 3,455
Dude, most of the planes out of and into Gville have rubber bands
Turning into a medium-term project, hoping the end is in sight. Newest issue is the low compression. Needs a ring job, dug into it more and the piston is a 1 over (0.5mm) plus an icky cylinder and valves. Going to take the piston and cylinder to a machine shop and get them spec'd, then either go with new rings or a 1.0mm over piston.
It's fun getting a project bike that's been through 3 hands of "experts"; missing pieces, bits that are in the wrong places, and stuff that's plain wrong. Then there's the natural decay of a bike that remembers when the Mets won the series
Adam
Old 01-13-2013, 04:21 PM   #883
XDragRacer
Oddometer: 3,218
Your proposed course is probably better, but . . . ain't there a 300 cc option with another Kawasaki model piston and pin?
An aftermarket specialist speed shop specializes in Mojaves and KLR250s (http://www.cycleworksracing.net/mojave.htm); sells several kit options from .020 and .040 oversize pistons to combos from 280 cc to 345 cc,.
No personal experience with the firm or its products, but intrigued!
Old 01-13-2013, 05:06 PM   #884
newcastleadam
Artful Tagger
Oddometer: 3,455
Was also intrigued with Cycleworks with my first KLR250 project, the scope on this one keeps increased with each system as problems surfaced. At this point want to get it running and enjoy it, then look at making it go faster. I believe you can resleeve it with KSF300 Bayou stuff, but cost comes into it at some point. At some point
Started out as a $150 project, starting to get closer to $750. That's the bad. Good news is I'm running out of problems to diagnose and systems to go through. Of course, it ain't running yet so...
Adam
Old 01-13-2013, 07:02 PM   #885
Voidrider
Oddometer: 992
A couple years ago I picked up a very "basket case" KLR 250 for $200. The big selling factor for me was that it actually had a good title, and I figured I could work on it piecemeal as money came in to allow progress. It is missing a LOT...including the upper engine and carbs, most of the plastic, gauges..but I I figured this would be great to customize. Hell, maybe even put a Ninja 250 into it and make a "Mini - Super Rio" or American made KLE 250...
But then life happened and other projects demanded attention.
I am hoping to get going on it this year, probably first get the manuals and tear down and go through what I have on hand, and research options as I rebuild it. I will be going through this thread for tips and hints for sure!
Voidrider is offline   Reply With Quote
Times are GMT -7.   It's 12:45 PM.
