Old 04-12-2013, 12:37 PM   #1051
Powderaddict
Oddometer: 178
Originally Posted by Dblarrow View Post
I have a 250 with the Cycle Works 330 kit. Absolutely different bike. My son has a normal 250 and the 330 is so much more. Mileage is still really good also. I took my 650 and my daughter rode the 330 to Alaska and she kept up quite easily. Cruising around at 55 and the occasional 70 is not problem, maybe just put a bigger sprocket up front.
Thanks for the info.
Would a larger front sprocket have a significant impact on off-road ability?
current:2009 KLX250s, 1975 Honda CB200t (project)
Powderaddict is offline   Reply With Quote
Old 04-12-2013, 01:30 PM   #1052
XDragRacer
Oddometer: 3,217
Yes, IMHO, although the increased displacement must provide increased torque, perhaps adequate off-road for a higher gear.
Reverse-engineering your query, I found switching to a 14-tooth countershaft sprocket on my stock-engined KLR250 improved things off-road, plenty.
Yet, I can keep up with the Interstate express lane traffic, if I'm willing to flog the little beast some!
XDragRacer is offline   Reply With Quote
Old 04-12-2013, 01:57 PM   #1053
Powderaddict
Oddometer: 178
Thanks.
Maybe I'll keep 2 sprockets handy if I get it, one for more road oriented rides, and one for off road rides.
Old 04-13-2013, 10:52 AM   #1054
Dblarrow
Dblarrow's Avatar
Oddometer: 121
Thanks.
Obvious answer is to play around and it depends on what is off road.
I picked up a 16 tooth only to find out it already had a 16 tooth on it. I had been running up and down and through the woods already. I can imagine that with a 14 tooth you could probably crawl along pretty good. For me off road is old abandoned logging roads and cutting corners through the woods and have no problems with the 16. I am however considering the 15 just for fun.
2006 KLR 650
1989 KLR 250 With a 330 big bore by CWR (WOW!!)
"Not by might nor by power, but by My spirit" says the LORD.
Dblarrow is offline   Reply With Quote
Old 04-13-2013, 05:47 PM   #1055
1994klr250
1994klr250's Avatar
Oddometer: 700
Dblarrow I see you have the 330 kit on your klr250. How do you like that big bore kit? I've been thinking of going that route when my klr needs a rebuild.
2300 miles on a 250 all for a sticker http://www.advrider.com/forums/showthread.php?t=616239
Fall ride on a KLR250 http://www.advrider.com/forums/showthread.php?t=754065
1994 KLR250, 2009 F800GS, 2006 KLX351
1994klr250 is online now   Reply With Quote
Old 04-13-2013, 06:20 PM   #1056
Dblarrow
Dblarrow's Avatar
Oddometer: 121
As I say in my sig line WOW! There is such a big difference between the 250 and the 330 it is like having a different bike. I have never ridden a real 350ish bike so can't compare to that, but this kit on this bike is a great upgrade.
2006 KLR 650
Old 04-15-2013, 01:24 AM   #1057
tkata
Oddometer: 9
New with KLR 250
Hi everybody! I'm new here and i've already read some very informative posts. I got my KLR 250 trwo weeks ago, she's a 1995 model, the barby. The general condition isn't bad at all although there is some rast on the frame. I don't know much about technical matters but i'm trying...Well, she's got 1 or 2 things i think i'd better check asap. Let me explain:
1. The bike starts with 1-2 kicks, that's fine, but she wouldn't keep the idle. When on the road sometimes the engine stops when i pull the clutch. Also, when she gets a bit hot the idle goes up to 3.000 rpm and stays there until i pull over for some minutes.
2. I don't think the fan works and i'm a bit worried about the cooling of my engine. I'm not sure if the water pump works as well. The heat indicator doesn't seem to work either.
The guy that sold me the bike said he cleaned the carburator (not sure about the tunning though) and done the valves.
There are some other minor issues but i'll check them, i think these two are the critical ones. So, according to your experience what should i do before i started visiting the dealers arround?
Thanks a lot! Happy to be here!
tkata is offline   Reply With Quote
Old 04-15-2013, 04:51 PM   #1058
Brash1
Adventurer/Goof-off
Brash1's Avatar
Oddometer: 52
Problem solved
My hard starting klr Barbie is a one kicker now! After all the carb cleaning, it turns out I hadn't cleared the starter jet:( Thanks for the helpful tips guys! This forum has been a real money saver for me.
2003 YZ450F
1988 KLR250
Brash1 is offline   Reply With Quote
Old 04-15-2013, 08:59 PM   #1059
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
I've had the same issue. The pilot jet is so small that the teeniest speck will throw the carb out of whack.
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is online now   Reply With Quote
Old 04-16-2013, 12:09 AM   #1060
XDragRacer
Oddometer: 3,217
# 1, hard to diagnose remotely; could be a thermally-expanding crack somewhere admitting excessive intake air; one of MANY possibilities.
#2, easy to check the fan circuitry. GROUND the thermal switch lead (connects to a thermal switch located toward the bottom of the radiator); this connection should activate the fan relay and in turn the fan.
Don't have my KLR250 wiring diagram handy; can't recall whether the KLR250 has a separate fan fuse or not; If the fan doesn't spin up when its thermal switch lead is grounded, I'd first check the fan fuse, if any. The thermal switch lead should have + 12 VDC present at all times, ignition ON or OFF.
Your bike, but . . . I'd be more comfortable with a functioning temperature gauge; any necessary repair parts should be available from Kawasaki, or a motorcycle "dismantler" (junk yard).
Old 04-16-2013, 05:25 AM   #1061
8gv
Oddometer: 2,478
tkata:
When my fan stopped working I found a loose ground wire under the tank. The circuit includes the fan and a thermo switch. Follow the wires with the tank off. You may find the loose one ALMOST grounded to the frame. Tighten it up and it may work.
As for the revving:
Check the throttle cable routing and make sure turning the bars or cycling the front suspension doesn't pull on a cable. Verify the cables are adjusted correctly with the ends seated in their adjusters and about 2mm of play at the twist grip.
Then...
Check the integrity of the diaphragm on the top of your carb. It may have some dry rot cracking that's leaking air. I believe this could cause a lean condition and inconsistent rpms.
Make the fan work and the revving problem might go away.
8gv screwed with this post 04-16-2013 at 05:30 AM
8gv is offline   Reply With Quote
Old 04-16-2013, 05:18 PM   #1062
DrMoto
Oddometer: 26
I've read that the (larger) klr650 front brake disk will bolt up to our front hub. Has anyone made a bracket to move the caliper out to allow use of the 650 disk? Would seem like a cheap route to a bit more stopping power, rather than replacing triple tree/forks/hub/etc.
'00 KLR250
'07 FJR1300
DrMoto is offline   Reply With Quote
Old 04-17-2013, 12:26 AM   #1063
tkata
Oddometer: 9
8gv & xDragRacer thank you for the tips.
It seems i have some work to do then...I'm sure i'll return with some more questions.
Thanks again!
Old 04-17-2013, 04:35 AM   #1064
XDragRacer
Oddometer: 3,217
If a KLR650 disk will fit, then . . . so will an EBC 320 mm disk! Caliper brackets should be of similar complexity and difficulty, i.e., 650 stock to EBC oversize.
Yet, wouldn't get too optimistic about any improvement in stopping distance; the main advantage to a larger aftermarket disk, in my experience (EBC 320 on Generation 1 KLR650) is in increased modulation capability, improved brake control. I could lock up the tire with the stock setup.
Another brake system improvement to consider; steel-braided brake line. The instant response of the caliper to the brake lever feels reassuring, and . . . the faster response means fewer feet traveled before the, "Whoa!" starts, IMHO.
Old 04-17-2013, 08:52 AM   #1065
8gv
Oddometer: 2,478
X,
Have you a recommendation for the brake line? I might be looking for one.
Times are GMT -7.   It's 09:46 AM.
