05-17-2008, 10:44 PM
#16 |
Snowflakes are cold...
Oddometer: 569
I only had to rerout the vires on the left, and i probably didn't need to rerout them annyway cause they wasn't so tight.
It's a dumb question, but many of the modifications that had some minor issues on advrider hasn't been an issue at all on my bike??? Are there so big differenses on European bikes and US? |
05-19-2008, 02:09 PM
#17 |
Yeah I'm a chick
Oddometer: 3,449
I won't shoot, I promise. Guns scare me.
Anyway, I'd have to defer to Jim or someone else smarter than I to answer your questions. In terms of offering an update as to the functionality, you can check out the ride report here from this weekend: http://www.advrider.com/forums/showthread.php?t=343271 Bottom line is that I think they worked fine, but didn't make too much difference. So I am convinced that I need other things more than these. I guess they make it more comfy overall, and a touch easier for stand up riding, for long distances, but in the mostly technical stuff from this weekend, they didn't make much difference. From a strength perspective, though, they held up very well as I binned it 3 times and not one slip or problem.
[quote=Insert witty comment here] |
05-19-2008, 06:54 PM
#18 | |
Oddometer: 4,474
Counterpoint.
To each their own and a lot of good off road folks recommended, use and swear by the Rox Pivoting Risers...I am glad I listened to them. *Hope this word doesn't cause you angst and I trust you will overcome your fear of inanimate objects.
"In Wallowas" ==================== 2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!"
06-01-2009, 11:07 AM
#19 |
Geeezed lightning
Oddometer: 1,664
I just bought a set of the Rox Risers for my bike. Of course I screwed up my order and Ryan called me because I used the comment field to tell him what I wanted. Great service. He sent the link to this install. I'm mostly through doing the install and have some comments.
My bars are held down by some E-10 Torx bolts so that's the tool I need to sneak in that gap. Sears local to me doesn't have them in stock of course. My throttle cable is very snug now. I even moved the bars around some just to ease the pressure and it doesn't have room. I'm going to have to bend or remove the little wire clip near the VIN on the fork tree. Anyone else have that or am I just lucky? Mine was the first GSA12 delivered at Morton's BMW in VA so it's early production.
"The idea of putting a jet engine on a motorcycle is so stupid it appeals to me." - Jay Leno Pat aka Geeeze |
06-01-2009, 11:52 AM
#20 | |
"Cool" Aid!
Oddometer: 41,498
As for the E-10 Torx, use a 9mm, IIRC, closed end wrench to loosen and tighten them, or replace the E-Torx with allen screws like I did. Jim
06-01-2009, 11:59 AM
#21 | |
Geeezed lightning
Oddometer: 1,664
As for lifting the tank. Ugh. I've only got about 250 miles on this tank so far so it's still half full. I'll run some more out. Thanks Jim. You're helpful as always and I do want you to know I appreciate it. From just sitting on the bike in my garage (making vroom vroom noises) I can tell it's going to be an improvement. My forearms are level now and when I stand I can grip with my knees locked out. I do that on long rides to cool my butt and the seat and before I could only reach with my fingertips unless I bent my knees or leaned forward. Wish I had this in place before yesterday when I spent 7 hours riding through the Smoky Mountains. (I know y'all feel sorry for me.)
06-01-2009, 12:06 PM
#22 |
Edumacated Red Neck
This install is different than the newer GSs. Here is a link I did for my 08 GSA:
http://gsri.info/forum/technical-are...tion/#post1453 I did not reroute the cables and did not appear to be any binding.
2008 R1200 GSA (Ghostrider), HP2E , 08KLR685,FOR SALE![]() "Fuck'em. I'm a lifer. " SlowOldGuy TEXAS-ROLL THE BONES RALLY4 10/25-10/27/2013 http://www.rollthebonesrally.com/ |
06-28-2009, 11:56 AM
#23 | |
Oddometer: 29
Rox Riser Fork Tube Install
I installed Rox Risers on my 2006 GS and everything went well except when I replaced the fork tubes. I don't know if I stripped out the bolts as on both sides they turned to the torque amount and then began threading easy. I could not back the bolts off. They seem to be tight with no play in the tubes. Anyone run into this?
07-11-2009, 05:44 AM
#24 |
Bazinga!
Oddometer: 11,659
Just installed the 2" Rox Risers on my 07 GSA. Then I took them off.
I loved the extra height. I can finally comfortably reach the controls while standing. And the wiring stretch I can deal with - but I don't like the reroute of the brake and clutch lines. Without moving them, they are stretched. After moving the brake (I just unbolted the master cylinder and passed it through the space in the fork) I don't like the angle of the line. The right answer would seem to be having new lines fabricated that are 2" or 3" longer to maintain the routing in front of the fork tubes, and not stretching them. Not the thing I want to be doing a couple days before taking off on a trip. It will have to wait until I have time to take the lines off, have new ones made, and then go through the pain of bleeding the ABS.
dunno..... |
07-12-2009, 06:39 PM
#25 | |
Yeah I'm a chick
Oddometer: 3,449
Funny. They didn't bother me on my 3300 miles through Baja and 15k miles since I've put them on.
To each his own.Quote:
07-13-2009, 09:40 AM
#26 |
Eyes wide open
Oddometer: 10
Ilium Risers
I just installed ilium bar backs / risers on my r1200gsa and I really like them. Super easy install although I did have to drop the fork tube (no big deal) to reroute some cabling. Tricky part was remouting the fog light switch. Just use the old top bars of the bar mounts with the new risers. Works like a charm. www.iliumworks.com
15 years, 55 countries, just thankful I live in the USA. Definitely the best place on earth in spite of ourselves. 2007 BMW R1200GSA |
07-13-2009, 06:11 PM
#27 |
Dirt is the spice of life
Oddometer: 743
http://www.advrider.com/forums/showthread.php?t=382184
Save yourself a pile of work, you don't need to reroute the cables unless the GSA is different than the GS for hose routing. Check out my post on this topic.
The road to paradise is UN-paved! go for it! Life's too short to think twice! Charlie B. (The other Boorman) ![]() Trans-Lab 2010 - James Bay 2011 - Shenandoah to Deal's Gap 2011 |
07-17-2009, 01:49 PM
#28 | |
Viel Spass, Vato!
Oddometer: 25,812
Thanks for the pics, LTS. I just purchased risers and the front brake and clutch hydraulic cables are binding. Now I know how to solve this. I was dreading it, but this looks "easy peasy," to quote you.
07-17-2009, 02:02 PM
#29 |
Edumacated Red Neck
I did not reroute nor have several of my friends bikes that have done this. Maybe some variations in models but the ones I have seen work fine
08-16-2009, 06:30 PM
#30 |
has adventure
Oddometer: 151
tightening torque
The reprom says 40Nm tightening torque on the fork bridge mounting nuts... plus to replace the nut. Also says 28Nm tightening torque on the BMW handlebar risers... only gap at rear as viewed from sitting on bike.
brianstanfill screwed with this post 08-16-2009 at 06:42 PM |
