Old 03-15-2011, 06:01 PM   #61
deeve
DumbA$$
deeve's Avatar
Oddometer: 1,209
Thanks! I'll keep and eye for them on the FM and maybe grab them up.
DAVE
2010 KTM 990 Adventure-Nuclear Fusion Powered
deeve is offline   Reply With Quote
Old 04-01-2011, 04:38 PM   #62
bigdog1807
Miles Craven
Oddometer: 135
Rox risers on GS
I see these are popular on the GS as local dealer also confirms. Wondering what other's experiences are with them regarding stability. I'd hate to be off-roading and have them rotate at any point. Feedback appreciated.
bigdog1807 is offline   Reply With Quote
Old 04-01-2011, 10:09 PM   #63
longtallsally OP
Yeah I'm a chick
longtallsally's Avatar
Oddometer: 4,403
Mine never have except for a parking lot tip over a couple years ago- and that was barely noticeable. I've been down in the dirt over a dozen times since I put them on and never once have they moved.
[quote=Insert witty comment here]
longtallsally is offline   Reply With Quote
Old 10-31-2011, 04:18 PM   #64
Farkleberry
Farkleberry's Avatar
Oddometer: 183
Another happy Rox Riser installer. I did end up re-routing some of my lines and this post was really helpful. Thanks for the pictorial assist!
Farkleberry is offline   Reply With Quote
Old 02-20-2012, 06:49 PM   #65
Callisto224
Callisto224's Avatar
Oddometer: 1,045
Rox Riser Install
Just installed my Rox Risers that came from Santa!
I have a 2009 12GS and didn't re-route any wires or cables. Lock to lock and no problem with idle. I did cut 1 cable tie that held the clutch line near the steering head but I could have probably gotten away with not doing this. It does seem like the front brake line is a little tight when the handlebars are turned all the way to the left but I think it will be fine. Also, I keep the original handlebar clamp bolts and was able to get a torque wrench on the large front bolts and used a 8mm wrench on the back and just made them tight (well, as tight as I could with a short little 8mm wrench!)
Now I just need a little warm weather to try them out!
Callisto224
2009 1200GS
Callisto224 is offline   Reply With Quote
Old 02-21-2012, 06:39 AM   #66
objectuser
objectuser's Avatar
Oddometer: 242
I'm a bit surprised it's as complicated as it is. I've installed them on a couple of bikes and it's a trivial matter, never involving moving around other parts.
Is this relative complexity still the case on the later models?
objectuser is offline   Reply With Quote
Old 04-03-2012, 01:04 PM   #67
AwolArn
Ride-Fly-Boat-Fish
AwolArn's Avatar
Oddometer: 79
LTS Thanks for the detailed info. I put my Rox Risers on my 07 GSA today. The only thing I have to add is this:
Mark the handle bars where they attach to the original clamps BEFORE you take the handle bars off! I didn't and spent an extra 30 mins trying to measure, eyeball, SWAG them back to center when I put them in the ROX Risers.
My only concern is the front brake line still seems tight. I dropped the fork tube as you suggested ("Easy-Peasy for sure) for the left side and moved the front brake line behind it. It seems the best compromise because it was really tight on the front side. Long term solution will be to get a new brake line that is a little longer and put it on but that is a project for another day. i'm putting all the panels on and going riding.
I have RawHyde school in 2 weeks and am getting Road Runner ready.
Road Runner: 07 GSA...first bike since my 82 KLX 250
71 Piaggio Moped
AwolArn is offline   Reply With Quote
Old 05-08-2012, 11:11 PM   #68
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Question: I'm 6'6" and super long arms, did anybody move the riser a bit forward from the top position?
All pcitures I see here the risers seem to be moving the handlebar closer the body
tallguy-09 is offline   Reply With Quote
Old 05-08-2012, 11:47 PM   #69
EddMc
are we there yet
EddMc's Avatar
Oddometer: 288
I'm 6'4" I have mine pushed forward about an inch, the rox risers are actually straight up and down. My only issue is that I can't have the windshield in the furthest back position the handle bars touch but just barely.
Trying to get lost.
2007 R1200GS
1997 XR400R
EddMc is offline   Reply With Quote
Old 05-09-2012, 09:40 AM   #70
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Did you have to re-route throttle or brake lines?
Old 05-09-2012, 11:41 AM   #71
dialdn
dialdn's Avatar
Oddometer: 669
I installed mine so the riser came out at about 45 degress (6'2"). I wanted reasonable level arms when sitting and better access when standing. Just had to move throttle cable under the bar which was pretty easy.
D
2009 BMW GS Adventure
Follow me on Twitter (@BeemerOttawa)
dialdn is offline   Reply With Quote
Old 05-09-2012, 02:31 PM   #72
Jhall1957
Oddometer: 41
I have a pair ordered for my 2010 GSA. What is the deal with having to drop the forks and all? I thought it would be a easy install. I can't imagine the cables being too short. I'm not tall (5'11") but want the bars up for standing.
Someone please explain the extra steps to me.
Jhall1957 is offline   Reply With Quote
Old 05-10-2012, 09:03 AM   #73
hardpackrider
hardpackrider's Avatar
Oddometer: 155
thanks all, i appreciate the info on these risers, i'm 6'1, and have to really hunch over when standing... so will be getting a set before my end-of-June trip. I must say that Jim's videos (http://jimvonbaden.com/) explain this install (and almost anything else you'd want/need to do to/kno about your GS) completely. After watching his DVD's, it really helps de-mystify this install. He shows how to drop the forks, re-route the lines, and re assemble. what a great, detailed resource his DVD's are. Not a better deal out there. Get them all, you won't regret it.
via Tapatalk
2012 GSA - xxx-black ________--- ____ -- .... .. . - . . .
Every man dies. Not every man really lives. William Wallace
I'm working on that Bill... it's why I'm here. hardpackrider
hardpackrider is offline   Reply With Quote
Old 05-13-2012, 12:49 AM   #74
hardpackrider
Oddometer: 155
okay, just finished ROX install on 2012 GSA. what worked for me.. had to drop clutch side forks and put cables under (towards rear of bike), did not have to drop front brake side..
did have to pay close attention to throttle cable... dealt with it with cable (zip) ties..
no binding at this time...
hope this helps others.. again this thread, and Jim's DVD were very helpful to me..
best
hardpackrider
via Tapatalk
Old 05-13-2012, 06:49 AM   #75
objectuser
objectuser's Avatar
Oddometer: 242
The pictures are great, thanks!
I still don't understand why the fork tube needs to be dropped. What is that doing?
Times are GMT -7.   It's 11:04 PM.
