Old 06-14-2012, 07:22 AM   #91
longtallsally OP
Yeah I'm a chick
longtallsally's Avatar
Oddometer: 4,466
Mine (the one I started the thread with) is a 2007. Let's just say, I've "used" mine and no issues at all- other than being more comfy.
[quote=Insert witty comment here]
longtallsally is offline   Reply With Quote
Old 06-28-2012, 03:12 AM   #92
2712
Oddometer: 374
Mine just arrived with the mail!
72 euro's shipped from the usa, i had to pay 29 euro's import tax.
Don't steal, the gouvernment hates competition!
2712 is offline   Reply With Quote
Old 07-31-2012, 07:53 PM   #93
lilmonkey
lilmonkey's Avatar
Oddometer: 237
I want to replace the E bolts with standard bolts...what do I need?
(2) M10 x90
(2) M8 x 30
Is that right? What thread pitch? I need to order online, so I want to make sure I get the right thing.
2012 BMW R 1200 GS "Rallye Edition"
Previous:
2010 BMW F650GS 1989 Honda Transalp 1989 Honda Hawk NT650 1980 Honda Hawk CB400
lilmonkey is offline   Reply With Quote
Old 08-20-2012, 05:23 PM   #94
Marc - Australia
Marc - Australia's Avatar
Oddometer: 289
Sorry guys to dig this out again,
but I am looking up the ROX risers for a friend and his 2011 ADV.
May I ask which size of the risers you got?
Thanks, appreciate your help!
Marc
Originally Posted by tallguy-09 View Post
Works great.
my beema's history -
Marc - Australia is offline   Reply With Quote
Old 08-21-2012, 08:46 PM   #95
Ride4Coffee
Ride4Coffee's Avatar
Oddometer: 210
Go VFR direct to ROX
Call or write Ryan at ROX. He's sharp, and will explain the options for that specific bike:
Ryan Jensen
RoxSpeedFX Inc.
218-326-1794
tech@roxspeedfx.com
Marc
Ride4Coffee is offline   Reply With Quote
Old 08-25-2012, 05:47 PM   #96
Ride4Coffee
Oddometer: 210
install complete. couple questions
Finished the install today, rerouted every cable, and had to tighten all bolts several times. of course, I don't own a torque wrench yet (but it's coming).
I am wondering how hard I should try to pounce the bars to test them.
Also, if you look at the front brake cable in the op, it runs the neck of the forks. Will it rub through the coated, braided cable?
Aside from those thoughts, I'm pleased with the install. Next step is to replace the e-torx bolts. Anyone know what size Allen bolts to get (my searches came up with different answers)? (same question as lilmonkey above)
Long story short, this tutorial made the job much easier than if I struck out on my own. Thanks again!
R4c
Old 10-01-2012, 09:38 PM   #97
ACD
old nOOb
ACD's Avatar
Oddometer: 280
Marc
I got the 2" riser for my GS. I am 1.80m tall and I had to bend my back or my knees a little bit, while standing on the pegs, to comfortably hold the handlebar, so I knew 2" would be more than enough. Regular spacers would suffice, to be honest, but I wanted the flexibility ROX risers give you. Highly recommend it. After I bought it I noticed they carry a 1.5", that one would do as well. Perhaps you will have more space to work on the bolts with the taller one. More than 2" and you will have problems with you cables.
ACD screwed with this post 10-01-2012 at 09:41 PM Reason: quoted the wrong guy
ACD is offline   Reply With Quote
Old 11-15-2012, 10:47 AM   #98
Merlin III
Mean SOB
Merlin III's Avatar
Oddometer: 1,754
Frustrated
After spending many hours reading all the threads on ADV, I purchased the 2" Rox risers. I did a dry run leaving the cables in front of the forks to test out the concept. When I noticed that the cables were tight, as everyone here indicated they would be, I preceded to remove the fork caps to drop the forks in order to re-route the cables and brake lines.
What I found was that the nuts were somewhat corroded and apparently bonded to the studs. I was unable to get them off without the bolt starting to feel like it was starting to round off. Fearing mission creep and a trip to my BMW dealer in my future, I gave up.
Are there any secrets to getting off corroded nuts without destroying the stud and it's associated parts? I thought about trying to heat up the nut, but there are too many wires in the area that possibly could be damaged in the process.
"I have approximate answers and possible beliefs and different degrees of certainty about different things, but I am not absolutely sure about anything." Richard Feynman, Cal Tech Scientist
Merlin III is offline   Reply With Quote
Old 11-16-2012, 10:24 AM   #99
hardpackrider
hardpackrider's Avatar
Oddometer: 156
thanks Tex (throttle link) helped !
2012 GSA - xxx-black ________--- ____ -- .... .. . - . . .
Every man dies. Not every man really lives. William Wallace
I'm working on that Bill... it's why I'm here. hardpackrider
hardpackrider is offline   Reply With Quote
Old 11-16-2012, 11:15 AM   #100
johnny80s
johnny80s's Avatar
Oddometer: 267
Put a little liquid wrench on the bolts and let them sit for an hour.
johnny80s is offline   Reply With Quote
Old 11-16-2012, 12:59 PM   #101
go gonzo
The Mustard of Pants
go gonzo's Avatar
Oddometer: 192
KROIL!!!!!! Best stuff ever made.
go gonzo is offline   Reply With Quote
Old 11-16-2012, 02:08 PM   #102
Merlin III
Mean SOB
Merlin III's Avatar
Oddometer: 1,754
Thanks. Admittedly I am not the most experienced person using a wrench. The Ratchet I am using is only, by estimate, 6-7 inches long. Generally speaking, Should I get a much longer ratchet or wrench for this process which is much longer to generate the 40 Lbs of torque that presumably it was put on with, or possibly a breaker bar? The thing that scares me here is that those studs and the seal that they are part of cost 109 dollars apiece so I don't want to destroy them in the process.
Merlin III screwed with this post 11-16-2012 at 04:20 PM
Old 11-16-2012, 10:10 PM   #103
gr8grins
Oddometer: 191
Do I need new brake lines?
I have a 2012 GSA and would like to install a set of these. Will I need a new (longer) brake line?
Thanks in advance for the help!
grins
gr8grins is offline   Reply With Quote
Old 11-28-2012, 01:30 PM   #104
Merlin III
Mean SOB
Merlin III's Avatar
Oddometer: 1,754
grins
Apparently not.
http://www.myspace.com/video/vid/315...mp=vid_OEV_P_P
Old 11-28-2012, 03:00 PM   #105
AviatorTroy
AviatorTroy's Avatar
Oddometer: 1,650
Kroil is great. Believe it or not, the penetrating oil that has performed the best in many tests is a 50-50 mix of ATF and acetone.
AviatorTroy is online now   Reply With Quote
Times are GMT -7.   It's 07:24 PM.
