Old 05-20-2008, 07:53 AM   #1
Daithi OP
Destination Unknown.
Daithi's Avatar
Oddometer: 177
XCountry rear-shock into a XChallenge ? ?
I want to fit XCountry rear-shock into a XChallenge, I saw a stock air shock fail and would prefer a conventional spring shock,
I've already bought the XCountry shock and should have it early next week. Anybody know anything about how well this would
work, has anybody on here tried it ?
CCM404 & DRz1000
Daithi screwed with this post 05-20-2008 at 09:36 AM
Daithi is offline   Reply With Quote
Old 05-20-2008, 10:37 AM   #2
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
Assume that the Xco shock will be much shorter in length and in travel than the Xch one...no?
Adventurer transitioning from 4x4 to 2x1
'07 G650Xch - Under Mod-struction
DiscoDino is offline   Reply With Quote
Old 05-20-2008, 12:34 PM   #3
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
I'm willing to bet you'll like I had a nice long discussion with Gary Emig about the rear shock for the X and as I recall, he felt that the shock was to long. I upgraded to the Ohlins and it still feels too long and I'm going to have it shortened. I have the preload dialed down so much that the Spring gets loose when I leave the ground.
Anyone else get that shoved forward feeling on the X? The Airshock was terrible and off throttle, it gave me way to much steering
How much was it?
Just say'IN
crankshaft is offline   Reply With Quote
Old 05-20-2008, 12:54 PM   #4
Daithi OP
Daithi's Avatar
Oddometer: 177
I'm certain it will be, it's one of the reasons I jumped at the chance to try it.
How much was it?
Sorry crankshaft, your signiture had me staring at the screen for a while there, then I realized it was a signiture and not a message to me.
Anyhoo, €60 which I think is about $60, which is very cheap. I thinkk i know what you're saying about the forks, they dive so much and the air-shock rises so much the XC becomes the ideal platform for handlebar-flips ? I'm 17 stone so I'm no light weight and I had the air pressure really low and managed better than better riders than me did. Having the risers also helped along with very little air pressure, also I prefer having a conventional shock (spring). My worry is that the shock will bottom out in the really rough stuff because of the spring being too soft and I'm also concerned about the travel.
CCM404 & DRz1000
Daithi screwed with this post 05-20-2008 at 01:43 PM
Old 05-20-2008, 01:19 PM   #5
Johnnyboxer
Oddometer: 1,057
It will definitely fit and lower the bike, but you'll have to drop the forks in the clamps, to compensate
I know somebody who has done it
So many roads...........So little time..!!!
2005 BMW R1150GS Adv - Black
2005 BMW R1150GS Adv - Silver
2007 BMW G650 XCountry - Black
Johnnyboxer is offline   Reply With Quote
Old 05-20-2008, 01:38 PM   #6
Daithi OP
Daithi's Avatar
Oddometer: 177
Thumb
Hi Johnnyboxer,
Do you mean you know someone who has the XCountry shock in an XChallenge ?
I'm all
I had the forks lowered to compensate for the soft back end (see pic below)
But I could go another bit I suppose, do you have any info on the results on the other XChallenge ? ?
CCM404 & DRz1000
Old 05-20-2008, 02:13 PM   #7
crankshaft
crankshaft's Avatar
Oddometer: 14,005
Opps
Maybe its my crappy riding style, but I like the front end higher and maybe a bit more sag in the rear For the street its fine, but when I'm on the trails, or a dirt road I find the ruts make it handle wierd with the airshock.
Just say'IN
Old 05-20-2008, 06:59 PM   #8
gaspipe
Wandering Soul
gaspipe's Avatar
Oddometer: 11,354
Gary and I chatted about that a bit when he finished up the G650X clamps. The Ohlins shock is too long is what we'd decided. I'm not really sure Ohlins did a good job here, and has really smashed a square peg into a round hole with respect to the XCh.
With the plush Husky/Zoke Shivers up front, the Ohlins feels like a worn out log truck. I need to pull the shock from my 450EXC and take a look at how one of those WP shocks for an RFS bike might be modified to work in the XCh.
gaspipe [the original]
Hair of the dog that bit me, Lloyd...
gaspipe is offline   Reply With Quote
Old 05-21-2008, 12:49 AM   #9
Storm
Currently Between Crashes
Storm's Avatar
Oddometer: 126
In a similar sort of vein - what do you guys think about an XMoto shock on the XChallenge? Too long/stiff?
Racing
(a. & n.) from Race (v.t./i.)
The alchemy that turns base metals into heat, noise, power and motion.
Storm is offline   Reply With Quote
Old 05-21-2008, 03:29 AM   #10
Daithi OP
Daithi's Avatar
Oddometer: 177
Thumb
This morning I was in a bike shop that had the XChallenge, XMoto and the
XCounty. I didn't have a tape measure, all I had was a long cable tie, to
compare the three, but the sprung shock of the XMoto appeared to be the
same length as the XChallenge's air shock, but the XCountry's sprung shock
was definitely at least an inch shorter than the other two, the bike looked
a lot lower.
As to wheather the XMoto shock on the XChallenge would be too long, I
think they're the same length. Don't know which type of stiffness will be the
issue but there's a lot could be altered by pre-load, oil viscosity and/or varying
the damping adjuster.
Hopefully Johnnyboxer will post pics or have info on someone who's done this
already.
CCM404 & DRz1000
Old 05-21-2008, 05:09 AM   #11
crankshaft
crankshaft's Avatar
Oddometer: 14,005
a lot lower.
already.
According to Ohlins, the shock they sold me for me X challenge is the same one they offer for the X moto. They valve it a bit differently is all.
Just say'IN
Old 05-21-2008, 05:12 AM   #12
crankshaft
crankshaft's Avatar
Oddometer: 14,005
I called Ohlins and they offered to shorten the shock for me, I just need to figure out how much......
Might be an option for you intead of trying to pound yet another square peg in a round hole.
Just say'IN
Old 05-21-2008, 06:09 AM   #13
P3R
Oddometer: 98
According to the recommendations at the Öhlins website they are different in both length and stroke. Must be a little more than valving ...
Part no: BM 633
Type: S46HR1C1
Length: 343,5mm
Stroke: 72,5mm
Fits: BMW G 650 Xmoto(2007-2008)
Part no: BM 636
Type: S46HR1C1
Length: 360mm
Stroke: 89mm
Fits: BMW G 650 Xchallenge(2007-2008)
P3R is offline   Reply With Quote
Old 05-21-2008, 09:37 AM   #14
kutch
That fell off where?
kutch's Avatar
Oddometer: 583
Part no: BM 633
Type: S46HR1C1
Length: 343,5mm
Stroke: 72,5mm
Part no: BM 636
Type: S46HR1C1
Length: 360mm
Stroke: 89mm
Thats only about a .65" delta on the stroke...? Not all that much...?
"Keep your front wheel down and your head up..."
kutch is offline   Reply With Quote
Old 05-21-2008, 11:59 AM   #15
P3R
Oddometer: 98
Now that you mention it, it's exactly the same difference in length. So a 16,5 mm shorted Xchallenge-shock may very well end up being the same as the Xmoto-version. You learn something new every day ...
Times are GMT -7.   It's 06:01 AM.
