Old 05-22-2008, 05:30 AM   #16
kixtand
kixtand's Avatar
Oddometer: 2,163
Many thanks for the replies and insight. I am in the process of putting together a /5 race bike myself, so anything you can share is much appreciated.
What size valves and carbs are you running?
Thanks again--
kix
Bacon...
it makes everything better.
kixtand is offline   Reply With Quote
Old 05-22-2008, 05:46 AM   #17
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,760
Originally Posted by pommie john
Kixstand is correct about the reason for raising the engine. Cornering clearance. I did try it with the engine in the normal position and it definately turned into corners better, but I kept hitting the rocker covers on the ground so we had to raise it.
I later got hold of some Mahle race pistons which are 16mm shorter than standard ones. You then machine 16mm of the cylinders and end up with an engine that is 32mm narrower. I never have clearance problems now, and could probably go back to the original engine position if I could be bothered.
Mahle piston
Photobucket
Sorry for the possibly stupid questions, but do you shorten the head studs, pushrods, and conrods, as well?
Does it change the angle of the pushrods?
I guess I am curious about your compression ratio
Do you run with a starter?
OR Is it a total loss electrical?
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 05-22-2008, 06:49 AM   #18
Alfons
Oddometer: 102
Congratulations, pommie john!
may I humbly ask which exhaust system you are running? To me that looks like Supertrapp silencers. If so, which type is that?
greetings from Germany
Alfons
Alfons is offline   Reply With Quote
Old 05-22-2008, 04:59 PM   #19
pommie john OP
pommie john's Avatar
Oddometer: 1,454
Not stupid questions at all. We shorten the studs and pushrods but not the conrods.
Yes it does change the angle of the pushrods so the pushrod tubes have to be bent a little to make them line up with the cam follower tunnels.
The changed angle of the pushrods is a problem because they are not pushing in a straight line they seem to flex. I am thinking of getting some seibenrock pushrods to try.
Compression is not too radical at about 10.5:1
pommie john is offline   Reply With Quote
Old 05-22-2008, 05:01 PM   #20
pommie john OP
Oddometer: 1,454
Alfons
You're right they are Supertrapp. The downpipes were made specially for me, but the supertrapps are just the normal ones with a racing outlet. They are about 480mm long if that helps.
Old 05-22-2008, 05:13 PM   #21
wildbillhatchbac
Adv Supermoto rider
wildbillhatchbac's Avatar
Oddometer: 282
awesome bike, i'd like a R75 project in the future . . . when my wallet is deeper i think
73 honda CB350 cafe racer build thread . . sold
08 yamaha WR250X . blue, like it should be
wildbillhatchbac is offline   Reply With Quote
Old 05-22-2008, 05:16 PM   #22
pommie john OP
Oddometer: 1,454
Thanks again--
kix
I'm glad to see another airhead is heading for the racetrack.
I'd have to say that a heck of a lot of work went into the engine.
It was prepared by Cray Engineering in the UK. They did the original work to the engine but I do the rebuilds when necessary.
The basic rule is "Use the latest bits that BMW make."
Use the latest flywheel and clutch, which means later gearbox input shaft etc.
Use the latest rockers, the ones with the plastic cushion and DON"T LIGHTEN OR POLISH them.
If you want to rev the hell out of it, enlarge the oil pick up from the sump so it doesn't cavitate.
If you run an early model crankcase ( before they modified the breather arrangement in '81 I think) they have trouble breathing. The pistons come together and go apart 8000 times per minute, so crankcase volume changes by one litre 8000 time per minute. We put on a sump extension and dropped the oil level to match ( longer pick-up tube too) which increased the crankcase volume. I also have the later reed valve breather not the rubber flappy thing.
Don't go too big on valves 44 or 45 is big enough and 38 or 40 on the exhaust.
carbs are 40mm delortos. Still got the pumps in them. Everyone tells me to take them out, but they work, so I've left them.
If I were to start again I probably wouldn't go for the shorter pistons. I think the alignment problems of the pushrods causes too much pushrod flex.
My bike was featured in Fast Classics magazine Aug/Sept issue 1996. I wrote the tech stuff and there's no BS in it. If you can find a copy it will get you headed in the right direction.
John
pommie john screwed with this post 05-22-2008 at 06:55 PM
Old 08-15-2008, 07:16 PM   #23
pommie john OP
Oddometer: 1,454
The rebuild is finished.
I'm just waiting for a new set of Avons and I'll be out on the track again.
Photobucket
Old 08-15-2008, 07:31 PM   #24
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Since no one else has inquired, I feel compelled, what front end is that?
Robert
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 08-15-2008, 07:49 PM   #25
pommie john OP
Oddometer: 1,454
Robert
Marzocchi forks with Brembo calipers running on a Honda 750/4 front wheel and discs! ( a few spacers had to made to order).
Old 08-16-2008, 09:25 AM   #26
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
I recognized the calipers but couldn't place the forks.
SWEEET!
Robert
www.wirewerkes.com
Old 08-16-2008, 02:23 PM   #27
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,937
Oh Sweet Jeebus, that bike is nice!!
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al is offline   Reply With Quote
Old 08-16-2008, 02:48 PM   #28
Bloodweiser
honestly
Bloodweiser's Avatar
Oddometer: 2,617
holy shit.
Bloodweiser is offline   Reply With Quote
Old 08-17-2008, 01:15 AM   #29
Nick Makwell
Bavarian Murder Weapon
Nick Makwell's Avatar
Oddometer: 672
Looks fantastic John
When are you taking here out next - the Paperclip (Ipswich Motorway) or somewhere else?
Could you PM me or reply on this board when you are, I'd love to take a look (and hear as well)
Just sold my R1200GS, and my R65 project is coming along, I now have two K100 front ends to play with...and all the other crap.
again - looks great - what tank is that?
_________________
1981 BMW R65 - "Seven"
Nick Makwell is offline   Reply With Quote
Old 08-17-2008, 01:26 AM   #30
pommie john OP
Oddometer: 1,454
I'll be taking it to the paperclip to run it in the week after next. Then I have entered a race at Phillip Island. I haven't heard whether my entry has been accepted yet. I should hear this week.
The tank was made to measure by a guy called John Pearson in the UK. I took him the frame with the seat fitted and a sketch of what I wanted. It was cheap (150 in the mid 90s).
He made the pannier tanks they used on the Gus Kuhn racers, so he was interested in BMWs.
I'll send you a PM later.
Times are GMT -7.   It's 10:26 PM.
