Adventure Rider
Welcome, lurker!   Even if you don't post, the system can help you find the good stuff faster if you register.
Register Members Pics Search Today's Posts Mark Forums Read
Old 05-26-2008, 12:01 AM   #1
klm4755
Oddometer: 422
Chain O-ring WD-40 exposure effects study and results
Enclosed is a study to examine the effects of Chain link O-ring exposure to various solvent, cleaners, and lubrications. Many “home grown” solutions exist as to the best method to clean and lube an O-ring type chain. Most popular is the usage of WD-40. The intent of this study is to determine if WD-40 and other commonly used chemicals are detrimental to the chains o-ring and it’s function. The study will consist of 4 parts:
1. Test set-up and controls
2. Short term continuous exposure results. Short term will be defined as 24 hours
3. Long term continuous exposure results. Long term evaluations will occur at regular intervals (monthly?) till a conclusion can be reached.
4. Study conclusion.
Part 1
Start all projects by reviewing relevant data related to the mod/topic
The source of the O-rings. DID master link from a 520 type chain.
extract the 8x O-rings for the study
set up an exam area. Did consider weighing the O-rings, but sold my gram scale when completed college......Hehehe Good times!
Evaluate, measure and record the dimensions. This case inner diameter with an adjustable ball gage. Dimensions are use to check for O-ring swelling.
check dia of ball gage. Inner dia = .227 inch
outer diameter =.356 inch
thickness = .073 inch
record dimensions
macro view of O-ring
O-ring side view
The 7x Fluids to evaluate
The container list: 1. WD-40, 2. Kerosine, 3. Gasoline, 4. LPS-3, 5. DOT 4 brake fluid, 6. PJ1 Chain lube, 7. Gumout carb cleaner
adding the fluids to the cavities
ready for O-ring insertion
Mark date and install O-rings
wrap-up container and store in garage.
Part 2
After 24 hours the O-rings were removed and examined visually for signs of distress. Quick comparison of all O-rings with the control O-ring some signs of swelling.
Each O-ring was squeezed and released to evaluate the elasticity and for signs of brittleness.
O-rings after 24 hours
removing the WD-40 exposed O-ring
WD-40 exposed O-ring ready to dry and evaluate
WD-40 exposed O-ring optical enhanced examination. Looks A-ok
measure thickness of WD-40 exposed O-ring
measure outer diameter of WD-40 exposed O-ring
WD-40 on left air exposed control on right
detail results of review on form
Repeat steps for Kerosene (Kerosene on left, air on right)
Repeat steps for Gasoline (Gasoline on left, air on right)
squeeze test for elasticity evaluation
Repeat steps for LPS-3 (LPS-3 on left, air on right)
Repeat steps for Brake Fluid (Brake fluid on left, air on right)
Repeat steps for PJ1chain lube (PJ1on left, air on right)
last sample....Grandama is still looking for her pill box....hehehe
Repeat steps for carb cleaner (carb cleaner on left, air on right)
Table of results
Conclusion of short term exposure:
1. Carb cleaner and Gasoline samples swelled to significant sizes. Definitely not recommended to use these fluids to clean an O-ring type chain. The carb cleaner exposed O-ring increased in diameter by 29%! The gasoline exposed O-ring increased in diameter by 11%.
2. WD-40, and Kerosene seem to have negligible to no effect on the O-rings (+/-1%)
3. Brake fluid, and PJ1 chain lube seem to have a negligible to small effect on the O-ring’s size.
Ready to ride
Keithm
klm4755 is offline   Reply With Quote
Old 05-26-2008, 01:46 AM   #2
Klay
fixer
Klay's Avatar
Oddometer: 38,864
Interesting. I think I'll stick with kerosene for chain-cleaning.
____________________________________
and the dog crept off, groaning,
to the deepest part of the woods.
Old 05-26-2008, 04:16 AM   #3
JDLuke
Familiar with sarcasm
JDLuke's Avatar
Oddometer: 2,626
What's next? Going to determine once and for all which oil is best, putting an end to all those threads?
Nice work!
Why did I drink all of the ingredients for vomit?
JDLuke is offline   Reply With Quote
Old 05-26-2008, 08:10 AM   #4
deaconjones
deaconjones's Avatar
Oddometer: 185
Ahhh,,,,Science!
2001 Bandit1200s (Sold)
1978 R100RS
1979 T140 Bonne
deaconjones is offline   Reply With Quote
Old 05-26-2008, 08:31 AM   #5
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 6,194
Nice..
I'm surprised brake fluid didn't destroy the o-rings..
Closed Loop, Balanced and Adjusted.
We spend our lives chipping away at our ignorance. You just knocked off a big chunk and are a better man for having done so. -- DAKEZ
Old 05-26-2008, 08:43 AM   #6
fallzboater
Kiss My Shiny Metal Ass
fallzboater's Avatar
Oddometer: 508
You could actually test elasticity and/or tensile strength with some wire and weights. Might be intersting.
I love your digital mic!
David Mackintosh
DoD #1360
'94 Cagiva e900 Elefant
'01 Aprilia Fuono
'94 Miata CSP
fallzboater is offline   Reply With Quote
Old 05-26-2008, 12:50 PM   #7
VStromTom
Oddometer: 759
Oh yea! Well, well, well.......WD-40 doesn't work, plus if you smell it or touch it your manhood will come off in your hand next time you whiz.
But, nice report and good work.
VStromTom is offline   Reply With Quote
Old 05-26-2008, 01:10 PM   #8
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 7,086
Very cool - thanks!
Loud pipes lose rights
Mista Vern is offline   Reply With Quote
Old 05-26-2008, 01:31 PM   #9
Wallowa
Oddometer: 3,214
O-Ring Material?
Rubber or silicon o-ring or ??? material? All o-rings are not created alike..maybe I missed it in your test...
Phil
"In Wallowas"
2007 R1200GS Adventure
Wallowa is offline   Reply With Quote
Old 05-26-2008, 01:40 PM   #10
klm4755
Oddometer: 422
Wallowa,
The O-rings were from manufacture DID and were from spare master links (what I had available). I do not know their material composition. I assume some type of rubber compound and that all vendors O-rings would be fairly material consistant. If you can tell me a (simple) way to test the spare O-ring to determine it's compound let me know and/or perhaps other members will chime in.
Keithm
Old 05-26-2008, 01:44 PM   #11
Wallowa
Oddometer: 3,214
No I Don't But..
Originally Posted by klm4755
Wallowa,
Keithm
No I don't but a number of years [20] ago the o-rings I used to use in my profession went to silicon from rubber...silicon lasts a lot longer and less UV damage..that is why I asked..just curiosity..you are correct I will bet that all o-ring chain manuf use the same material and I will also bet it is silicon..
Good job on test...but you have WAY too much spare time!
Phil
"In Wallowas"
Old 05-26-2008, 05:02 PM   #12
FriedDuck
Why die all tensed up?
FriedDuck's Avatar
Oddometer: 801
Nice work! Here's the stuff/technique I use on my chains. Works like a charm.
I've never had problems with WD40, but feared that some of it might slip past an errant o-ring and work it's magic on the grease within.
I'm looking forward to the long-term test. Some of those o-rings are going to be begging for mercy!
Jeff
FriedDuck is offline   Reply With Quote
Old 05-28-2008, 01:07 AM   #13
Doghouse_Riley
Wannabe Adventure Tourer
Doghouse_Riley's Avatar
Oddometer: 1,871
You forgot to test with ATF.
Ciao
Doghouse
'98 XR650L
'97 F650 "Funduro"
Canis meus id comedit.
Doghouse_Riley is offline   Reply With Quote
Old 05-28-2008, 11:28 AM   #14
DaFoole
Que la Chinga?!
DaFoole's Avatar
Oddometer: 1,258
Nice work. But what about olive oil???
"Scratching the wrong places since 1955!!"
"...when I handed the 40 ouncer to him, he got that far off stare that a cat gets when it just gets done licking its ass for the last 15". Yeah, THAT stare." -WTF-Over
Striving to beat Treadless's Post Count in '09!! Won't you help?
DaFoole is offline   Reply With Quote
Old 05-28-2008, 11:47 AM   #15
Dirtgeek
Oddometer: 1,434
awesome! you get an
A+
al
Dirtgeek is offline   Reply With Quote
vB code is On
Times are GMT -7.   It's 04:47 PM.
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright ADVrider 2007
