Old 05-28-2008, 02:58 PM   #16
Wallace
Seat belt tight babe?
Wallace's Avatar
Oddometer: 833
Good stuff..............Thanks.
Wallace is offline   Reply With Quote
Old 05-28-2008, 08:36 PM   #17
bonox
Tryin Hard
Oddometer: 2,998
Originally Posted by Doghouse_Riley
You forgot to test with ATF.
since it's mostly like thin motor oil and me and every other chap in the world with an automated chain oiler runs it (scott say that their fluid is basically ATF), that hardly seems important.
He immediately paid me the one of the highest compliments an Advrider can receive: "You're nuts!" (Alcan Rider)
bonox is offline   Reply With Quote
Old 05-28-2008, 10:42 PM   #18
Doghouse_Riley
Wannabe Adventure Tourer
Doghouse_Riley's Avatar
Oddometer: 2,019
You could say the same about kerosene since chain manufacturers recommend it for cleaning o-ring chains.
Nevertheless, interesting experiment. Thanks for for sharing the results.
Ciao
Doghouse
Canis meus id comedit.
Doghouse_Riley is offline   Reply With Quote
Old 05-28-2008, 11:06 PM   #19
bonox
Tryin Hard
Oddometer: 2,998
and the results he had proved why
Old 05-29-2008, 05:54 AM   #20
Tigertracks
Press On
Tigertracks's Avatar
Oddometer: 80
I always used ATF ( Automatic Transmission Fluid ) in my Scottoiler on my Triumph. Stood to reason because ATF is specifically designed to keep rubber
pliable and in good condition inside the transmission.
It did a nice job of keeping the chain very clean.
It is light weight so it also kept the back wheel nice and filty.....
very Macho ....
I do not have a Scottoiler on my current Trumpet ... but I do wipe the chain down with ATF ( and still use some spray on stuff )
Another oiler system may be in cards.
Tigertracks is offline   Reply With Quote
Old 05-29-2008, 05:15 PM   #21
D-Mac
D-Mac's Avatar
Oddometer: 613
Excellent work! FINALLY we get some empirical data on this topic.
At home I use kerosene to clean the chain and then a good lube (Bel-Ray Super Clean or the Dupont stuff usually). On the road I substitute kerosene with WD-40. I figure that it's ok once in a while and the WD-40 comes in handy for lots of other uses too.
Long-term testing with some heat applied would be especially interesting.
D-Mac is offline   Reply With Quote
Old 05-29-2008, 07:47 PM   #22
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,916
Maybe it's just me, but my interpretation of the problem with WD40 was not that it cause the o-rings to swell. Instead that it's basically a penetrant, and would get past the o-rings and contaminate the captured grease, causing premature wear..
Old 05-29-2008, 07:58 PM   #23
gcb
gcb's Avatar
Oddometer: 118
Exactly what my honda manual says.
the chain has some small o-ring, lube, o-ring.
if you use wd-40 it will dissolve the lubricant inside the thing. The manual has a big red box about not using penetrating oil on the chain.
Also, the test lacked a Coke sample. Unacceptable!
gcb is offline   Reply With Quote
Old 05-30-2008, 01:29 PM   #24
Chubber
I am the Brewmaster.
Chubber's Avatar
Oddometer: 555
Good study. I would have liked to see what the totals were after 7 days of exposure. After all, anything that gets behind the o-rings is going to stay there.
Also a test of simple-green or other similar cleaners would be cool.
Now if I could just my neighbor to stop using it as his only lube on his non-o-ring dirtbike chains. He sprays that chain off, hoses it down with WD-40 and parks it, ready for the next ride. He wonders why he gets only about 5 months out of a rear sprocket...
Chubber is offline   Reply With Quote
Old 05-30-2008, 03:58 PM   #25
Mad*Sparrow
NoMadic Wanderer
Mad*Sparrow's Avatar
Oddometer: 181
What about Diesel?
Where does Diesel fit into this equation (since I cannot afford the 5 gallons of kerosene, smallest amount found in my area )? It is another oil and I am told similar to Kerosene. I'm guessing it'll fall in the oil based conclusions. Suzuki anyway says go with Kerosene every 600 miles.
None are more hopelessly enslaved than those who falsely believe they are free.
Johann Wolfgang von Goethe
Mad*Sparrow is offline   Reply With Quote
Old 05-30-2008, 11:56 PM   #26
Doghouse_Riley
Oddometer: 2,019
Sorry, I'm not following your logic.
Ciao
Doghouse
Old 06-01-2008, 02:15 PM   #27
bonox
Tryin Hard
Oddometer: 2,998
If a manufacturer specifies a chemical as usable, do you think you're going to see a significant effect on the component parts?
Old 06-02-2008, 11:31 AM   #28
R-dubb
Dubbious Adventurer
R-dubb's Avatar
Oddometer: 5,016
I have more than once purchased a quart of kerosene at the local ACE in the paint solvent section. Just a thought.
R-dubb is offline   Reply With Quote
Old 06-02-2008, 12:19 PM   #29
matey peeps
Bead Buddy
matey peeps's Avatar
Oddometer: 3,337
I've also seen it in the camping section at the local Wal-Mart.
matey peeps is offline   Reply With Quote
Old 06-02-2008, 12:56 PM   #30
AZKLR
Oddometer: 39
What does that manual say you CAN use?
AZKLR is offline   Reply With Quote
Times are GMT -7.   It's 08:32 PM.
