Old 06-05-2008, 07:56 PM   #46
aardschok
Fallout Rider
aardschok's Avatar
Oddometer: 558
Originally Posted by St_rydr
I have this can of spray (Maxima Crystal Clear Chain Lube) It has mostly mineral spirits in it. I spray it every couple weeks when I'm done riding while my chain is still warm. If it rains alot, a little more. Yep every couple weeks and thats it. If I lubed my chain every 200 miles I would go nuts worrying about it. I got 6k on it now and it looks like new.
When is a good time to change the chain? Mine has 15k miles and still looks good to me.
"When you have to shoot...Shoot! Don't talk."
MVT
aardschok is offline   Reply With Quote
Old 06-05-2008, 10:52 PM   #47
Doghouse_Riley
Wannabe Adventure Tourer
Doghouse_Riley's Avatar
Oddometer: 2,019
When it's stretched beyond the service limit as specified in your service manual.
Ciao
Doghouse
Canis meus id comedit.
Doghouse_Riley is offline   Reply With Quote
Old 06-09-2008, 12:16 PM   #48
suprPHREAK
suprPHREAK's Avatar
Oddometer: 42
Originally Posted by ibafran
It is my experience that WD-40 is a terrible chain lube. I get 25k miles using real lube and/or 120wt gear oil from an oiler.
I lost a perfectly good chain in 12k miles. No ammount of WD-40 was helpful. The chain dried rapidly and a red oxide/dust appeared rapidly. O-rings got hard and cracked off.
WD40 alone should never be used as a lubricant. It dries and evaporates fairly rapidly, that it will not provide much lubrication after only a few hours. It is, however, GREAT for cleaning a chain, and removing gunked on grease.
I use WD40 for cleaning the chain off, getting any dried lube and gunk off, then apply DuPont multiuse Teflon lubricant (for bikes) on there. So far, so good: 23,000km and the chain is like new.
suprPHREAK is offline   Reply With Quote
Old 06-09-2008, 03:50 PM   #49
smokinjoe
hippie kicker
smokinjoe's Avatar
Oddometer: 3,003
WOW! Thanks for taking the time to do this...I'd have never thought about a comparison test.
I'm really bad about cleaning my chain. I lube the thing regularly and inspect it, but clean it....not so much.
You know what would be fun...let's rub salt on our ass and go to a petting zoo!!!
If you won't stand behind our troops....do us all a favor and stand in front of them!!!!
Speak well of your enemies. Afterall, you made them!!!
what are you lookin at, dicknose!!!!
smokinjoe is offline   Reply With Quote
Old 06-12-2008, 09:51 AM   #50
Janosh
Old Man
Janosh's Avatar
Oddometer: 37
WD Mistake?
Back in 66 I was in the Navy and they banned the use of WD40 due to the fact it draws moisture. Spraying unprotected steel with it leaves a coat of rust the next day in a humid environment. Of course, that was 42 years ago. God, I can't believe I have been around that long. I'm certainly not old. I like Diesel myself. Top it with some chain lube to keep it from rusting.
Janosh
Janosh is offline   Reply With Quote
Old 06-13-2008, 11:48 AM   #51
Chad M
Custom User Title
Oddometer: 785
Janosh
Isn't the whole point of W(ater)D(displacing)40 to not draw moisture? Something is not right, by "humid environment" do you mean dipped in seawater and left on the deck of a battleship?
Chad.
Chad M is offline   Reply With Quote
Old 06-14-2008, 04:31 PM   #52
wyowillys46
F=mA
wyowillys46's Avatar
Oddometer: 2,099
Originally Posted by klm4755
Holy crap. You know, it's a KLR, not a submarine.
"I swear to god, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity." -Roscowgo
wyowillys46 is offline   Reply With Quote
Old 06-14-2008, 09:18 PM   #53
Chubber
I am the Brewmaster.
Chubber's Avatar
Oddometer: 549
You gotta hide the porno stash somewhere you know she will NEVER look...
Chubber is offline   Reply With Quote
Old 06-15-2008, 03:01 AM   #54
rivercreep
Oddometer: 3,243
Nice attempt at a "scientific" approach.
The only thing I used on my DR650s' (s- as I've owned a 91 and 97) was spray on silicone. Worked great as a cleaner and lube and since the o-rings are of a silicone compound it just always made sense to not mix compounds to me.
I'd clean/lube with the stuff every 1,000 miles and routinely get between 15 and 20,000 miles per chain/sprocket combo. Not bad factoring in all the water crossings and river grit.
Shame I didn't find what I was looking for here in regards to my chain wear search, though!
Good Job but, there's just sooo many variables to consider.
rivercreep is offline   Reply With Quote
Old 06-15-2008, 06:26 AM   #55
gboezio
gboezio's Avatar
Oddometer: 363
Thumb
Great report, this would end up some eternal debate on chain cleaning
Great work
gboezio is offline   Reply With Quote
Old 06-19-2008, 11:35 AM   #56
klm4755 OP
Oddometer: 575
Great work
Thanks! part II test results are shown here:
http://www.advrider.com/forums/showthread.php?t=350310
I consider a 20% reduction in O-ring strength, due to WD-40 usage, a concern. I'm considering a part III test to evaluate the degeradation of the O-ring OEM grease within the link it's self.
Keithm
klm4755 is offline   Reply With Quote
Old 06-20-2008, 08:16 AM   #57
Wuwei
Oddometer: 1,108
WD40 tricks
Stupid bike shop trick: When I worked as a mechanic in a bike (bicycle) shop we would blow up old inner tubes like balloons, spray them with a little WD40 and then toss them in a corner. After a few hours the tube would explode, hopefully causing everyone not in the know to spill their coffee. In our shop we were careful to keep WD40 away from tires and inner tubes. WD40 does negatively impact some rubbers and plastics, but not others. I try to keep it away from any rubber or plastic, just to be on the safe side.
For my part, I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to move. Robert Louis Stevenson
Wuwei is offline   Reply With Quote
Old 06-21-2008, 12:53 PM   #58
Janosh
Old Man
Janosh's Avatar
Oddometer: 37
Displace or Draw
The way WD deals with moistrure apears to be that it absorbes it, then the distilates evaporate leaving the moisture behind which then ocidizes with the metal.
This is why the Navy banned it's use back in the 60's
They changed to CRC at the time.
I think I'll have to go with the Silicone for chains, it doesnt cake up with gritty dust, and doesn't hurt the O rings.
Have you ever noticed there is lots of miss information, and deception in life? A friend told me that planet Earth is an Insane Asylum and the best we can do is try and be sane.
Janosh
Old 07-09-2008, 12:49 PM   #59
fixer
KLR-riding cheap bastard
fixer's Avatar
Oddometer: 7,439
i tried many things on bicycle chains back in the day.
dipping chain in melted paraffin. worked well, but required periodic reapplication, which meant pulling the chain and melting the paraffin in a double boiler. laso left me with a squeaking chain around mile 150 of a 200 mile ride. stopped using it after that.
WD-40: not very good, needed very frequent application.
Tri-Flow: worked good, but left dark marks on anything the chain touched.
Silicone Spray: clean, but seemed to need FREQUENT reapplication.
LPS-3: waxy, worked well in everything except dusty environments. also provided great service when i got a street bike (moto) and i'd get over 20,000 miles out of an RK chain. don't think it's what i'd use for dual-sport abuse.
Sit tall in the saddle, Hold your head up high
Keep your eyes fixed where the trail meets the sky
And live like you ain't afraid to die
And don't be scared, just enjoy your ride.
"... in my version of Heaven you get all your dogs back." Mista Vern
"Old dogs don't die, they just wait for you in another place." Twilight Error
I'll show you a place, high on a desert plain, where the streets have no name.
fixer is offline   Reply With Quote
Old 07-09-2008, 05:46 PM   #60
smokinjoe
hippie kicker
smokinjoe's Avatar
Oddometer: 3,003
Janosh
Well, leave it to the military....that's why WD-40 was invented. Water Displacement formula #40.
Like I say, I'm not real good about cleaning the chain, but I do check it almost every time I go out, and it gets lubed with Chain Wax after a 5-10 minute ride to warm it up; just like the directions say. In the olden days before O-rings, I would break the chain, clean with diesel, let it dry, then into the oven for a bit to warm it up for 30-45 minutes on a low setting. When it got good and warm, I'd drop it into a bucket of 80/90 or 80/120 gear lube. What can I say, it worked great on that old '49 Panhead!!! Life was so much simpler back then!!!
Times are GMT -7.   It's 01:18 AM.
