Old 07-10-2008, 03:44 AM   #61
guns_equal_freedom
Oddometer: 5,535
Poor WD40....
WD40 = Water Displacement compound #40.
It's not a lubricant, it's not a penatrating oil, it's meant to displace water and it's supposed to leave a thin coating of its base oil on the surface after the solvent evaporates..
The military now uses VVL-800 as the primary water displacement compound.
Krause (Sidewinder) and DID did not have specific cleaning instructions.
EK chain:
Do not use harsh solvents or chemicals, such as gasoline or benzene. EK recommends using a biodegradable degreaser with a soft (non-wire) bristle brush or clean cloth for removing dirt. Use kerosene (paraffin oil) if necessary, let dry and lubricate immediately within 10 minutes.
http://www.ekchain.com/install.htm
RK Chain:
Q How should I maintain my O-ring chain?
A. Doing routine maintenance on any chain is a crucial step to getting the maximum wearlife out of your chain. You should clean and check its adjustment every 400 miles (sooner if the chain gets excessively dirty). Use formulated O-ring chain cleaner or other similar product to keep dirt from building up around link plates and rollers. Don’t use a wire brush or pressure washer. If your chain comes in contact with water, be sure to use a moisture displacement (like WD40). Lubing an O-Ring chain is vital for maximum wearlife. All RK O-Ring chains are injected at the factory with a lifetime supply of internal lubricant. The purpose of an O-Ring lube is to keep the chain from rusting and the O-rings from drying out. We recommend RK special formula O-Ring Chain Lube because it is a non-aerosol, specifically formulated to stick the chain, yet not attract excessive dirt.
http://www.rkexcelamerica.com/faq.html
Regina:
If the chain is not too dirty, the operation of lubrication is normally sufficient to clean the chain.
When the accumulation of dirt on the chain (sand, mud, asphalt particles or other foreign materials) is excessive, the chain must be washed with a brush and kerosene. After washing, the chain has to be dried immediately with a jet of compressed air.
After off-road use, when the dirt built-up is heavy, wash the chain with a water jet, then dry it immediately with compressed air.
Avoid the use of steam, gasoline or solvents.
When cleaning O-Ring chains, avoid the use of hard brushes or other methods that could damage the rubber O-Rings (compressed air should be kept at 50 cm/2 ft distance minimum).
After washing, immediately lubricate the chain as explained in the next chapter.
http://www.reginachain.it/eng/use_an...how_to03.shtml
Tsubaki:
To clean your Tsubaki chain, it is first necessary to raise the motorcycle on its centre stand with the engine off and the transmission in neutral. Then rotate the rear wheel of the motorcycle (using care to keep your fingers away from the sprockets and chain), spray a moisture displacement lubricant to one side of the chain. After 2 or 3 full revolutions, switch sides and repeat. In this manner you have floated the dirt off the chain and now you need to wipe off the chain with a clean cloth to remove the excess lubricant and dirt residue. Never use a flammable solvent such as gasoline, benzine or kerosene. Additionally, never use water, detergents, steam cleaner or a coarse brush as these damage the chain.
http://www.tsubaki-rider.com/?type=maintenance
Diamond Chain:
O-ring chains may be cleaned externally by washing in kerosene. Do not use
any other cleaning agent or the O-rings may be damaged. When cleaning O-ring chain, clean only the external areas of the chain.
Do not attempt to force kerosene into the pin-bush cavity.
For chains which are still usable, soak them in SAE 40 or 50 automotive engine oil (without additives).
Flexing the chain in oil will assure greater penetration of lubricant. Inspect
and clean sprockets.
http://www.diamondchain.co.uk/usr_do...ycle_chain.pdf
Clear as mud.
I use Gunscrubber (Good ole ozone depleting global warming 1,1,1-TRICHLOROETHANE) sprayed on a rag to remove all of the built-up grease, dirt and mung from the chain and sprocket, then I spray it down with WD40 and wipe that down and let it dry, then I use chain lube (currently using PJ1 blue label) to lubricate the chain. I let it sit and then I wipe the excess from the chain.
If I wash the bike I skip the Gunscrubber and spray the chain with WD40 to displace the water from the chain, then I lube with chain lube.
This is one of those deals where manfacturers recomendations lose to personal preferences.
guns_equal_freedom is offline   Reply With Quote
Old 07-13-2008, 09:14 AM   #62
gboezio
gboezio's Avatar
Oddometer: 363
Holy shizzle, they are all different, I guess I should boil the whole bike in a grease bath once in a while, but that may not get past the O-rings
gboezio is offline   Reply With Quote
Old 08-24-2008, 02:50 PM   #63
RTL
RTL's Avatar
Oddometer: 8
Originally Posted by klm4755
Wallowa,
The O-rings were from manufacture DID and were from spare master links (what I had available). I do not know their material composition. I assume some type of rubber compound and that all vendors O-rings would be fairly material consistant. If you can tell me a (simple) way to test the spare O-ring to determine it's compound let me know and/or perhaps other members will chime in.
Keithm
This is what I think most motorcycle chain o-rings are made of:
Buna-N (Nitrile) O-Rings
Description:
Standard Nitrile is also known as Buna-N. Excellent resistance to petroleum-based oils and fuels, water and alcohols. Nitrile also has good resistance to acids and bases, except those with a strong oxidizing effect.
Limitations: Avoid highly polar solvents (Acetone, MEK, etc.) and direct exposure to ozone and sunlight.
Chemistry: Copolymer of butadiene and acrylonitrile. By varying the acrylonitrile content, elastomers with improved oil/fuel swell or with improved low-temperature performance can be achieved. Specialty versions of carboxylated high-acrylonitrile butadiene copolymers (XNBR) provide improved abrasion resistance. And hydrogenated versions of these copolymers (HNBR) provide improve chemical and ozone resistance elastomers.
Trade Names: CHEMIGUM ® , HYCAR ® , PARACRIL ® , PERBUNAN ®
ASTM D1418 Designation: NBR, XNBR, HNBR
ASTM D2000/SAE J200 Type, Class: BF, BG, BK, CH
Temperature Range: –55° to 120°C (–65° to 248°F)
Typical Uses: Ion Implant, PVD
Compound# ColorHardness
Shore A
Tensile
Mpa (Psi)
Elongation %22Hr C/S
@ 100C
Low TempHigh Temp
B1000Black7015.0 (2,150)40010–40°C(–40°F)120°C(248°F)
* Buna-N is available in a wide range of Durometers and Colors,
as well as many compound variations designed to meet specific applications.
RTL is offline   Reply With Quote
Old 10-29-2008, 10:50 PM   #64
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,224
Originally Posted by Janosh
Have you ever noticed there is lots of miss information, and deception in life? A friend told me that planet Earth is an Insane Asylum and the best we can do is try and be sane.
Janosh
I'm trying, and even if my attempt at sanity was half-baked and poorly executed, I was trying... well, at least I can offer a response from the maker's of WD-40:
http://www.advrider.com/forums/showthread.php?t=312191
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 03-17-2010, 02:44 AM   #65
spence.smith
Oddometer: 2
Hello guys,
I searched and got conflicting answers.
Some say WD40 is of kerosene base so safe on o-ring chain when used for cleaning. Others say it might damage the o-ring.
So should I use WD40 on my SV's chain or not?
Thanks in advance for your help.
Military gifts specialists offer a select range of custom designed Military Rings for all branches of the armed services.
spence.smith is offline   Reply With Quote
Old 03-17-2010, 10:19 AM   #66
showkey
Oddometer: 1,916
Originally Posted by spence.smith
Hello guys,
http://www.wd40.com/faqs/
What does WD-40 contain?
While the ingredients in WD-40 are secret, we can tell you what WD-40 does NOT contain. WD-40 does not contain silicone, kerosene, water, wax, graphite, chlorofluorocarbons (CFCs), or any known cancer-causing agents.
(chain) Lube is a personal perference ..............dozens of threads on dozens of sites
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Old 03-17-2010, 11:05 AM   #67
groop
So much to ponder
groop's Avatar
Oddometer: 3,246
nice test but you may consider longer exposure times and not using a vitamin basin filled with plasticizers (maybe Bis-A?) that may affect the (re)action of the solvents.
Just installed my first o-ring chain on my CR250 last week and I was wondering about lube.
Because you cannot eat a salad with a spork.
groop is offline   Reply With Quote
Old 03-17-2010, 04:43 PM   #68
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,504
I thought it was made out of menhaden.
Old 03-17-2010, 08:00 PM   #69
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,973
It's varsol and a little bit of oil.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 03-18-2010, 08:41 AM   #70
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,785
I am surprised no one has mentioned how much better chains are today than 20+ years ago. In the 80's I had to adjust the chains ALL the time. Now, my DL650 hasn't even moved since new. My other bikes maybe one notch in the life of the chain so far. My routine is to keep it clean, adjusted properly and keep an eye open for chipped sprocket teeth.
Hate gets you nowhere.
Old 04-13-2010, 10:16 PM   #71
KRS
Sand.... My Nemesis
KRS's Avatar
Oddometer: 333
Great test (I know it's older but hey, the thread is back man). I wonder how the o-rings react to various lubricants used and then the solvents?
What I mean is, what if the rubber reacts to the rider's lube of choice and then reacts to the cleaning agent because of the lube?
WD-40
Oil
Wax
Chain lube spray
what else do ya-all use?
These were all 'virgin' o-rings.
Just thought I'd ask if anyone else had wondered?
KRS
Current Bikes: '07 DL1000
Past Bikes: '00 KLR650, '92 Vulcan, '86 Seca 650RJ
KRS is offline   Reply With Quote
Old 04-13-2010, 11:48 PM   #72
meat popsicle
Ignostic
Oddometer: 14,224
I just found out that I had it ALL WRONG, all this time... it's not WD-40 on your chain; it's ATF. A friend told me a reliable fella says he has 77,000 miles on his chain, and he only uses ATF on it.
Note: I don't think this means I was wrong about WD-40, because its not the best thing for your forks...
Old 04-15-2010, 02:17 AM   #73
a$$hole
a$$hole's Avatar
Oddometer: 972
Well damn. I just realized that it was pretty stupid to use compressed air AND WD40 to blow the crap off my chain! Hopefully I didnt ruin it. This sucks.
a$$hole is offline   Reply With Quote
Old 04-15-2010, 08:05 AM   #74
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,655
Agreed. The advent of the O-ring (and the subsequent Z- and X-ring) chain has markedly improved chain life. The steel has also gotten much better. All my bikes are chain drive and it does not bother me one iota.
Old 04-15-2010, 09:39 AM   #75
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,504
Yep, I just changed my DL650 chain at 23,000 miles. Only reason to change out was the counter sprocket was getting crunchy. When I compared the new chain to the old stocker, there was very little stretch. Stock chain on my Strom was an X-ring, not no steenkin o-ring.
Times are GMT -7.   It's 09:02 AM.
