Old 01-10-2012, 02:54 AM   #76
aryapradana
Oddometer: 5
whoa i just red about the test using wd-40. a lot of my friend told me that wd-40 is good for cleaning, but since it's a penetrant, they told me that is not good using it for lubricating chain. a chain lube is better
aryapradana is offline   Reply With Quote
Old 01-11-2012, 05:29 AM   #77
Maxi
Oddometer: 9
interesting. Thanks for the experiment
Maxi is offline   Reply With Quote
Old 01-12-2012, 09:30 AM   #78
tgeliot
Topher
Oddometer: 1,352
Originally Posted by DaFoole View Post
Nice work. But what about olive oil???
Astro-glide FTW!
Topher
1989 Transalproject. 2008 Suzuki V-Strom 650
I don't have a bucket list, I have a post-bucket list. So far it includes
1) Coroner's report is to read "Death by misadventure."
2) Dixieland jazz band at my funeral.
tgeliot is offline   Reply With Quote
Old 04-17-2012, 12:10 AM   #79
erkankaplan
Oddometer: 8
Very very nice work thank you..
erkankaplan is offline   Reply With Quote
Old 04-17-2012, 01:46 AM   #80
Jud
Jud's Avatar
Oddometer: 2,291
Thanks for taking the time.
Pics- http://s563.photobucket.com/albums/s...eon/?start=all
Places visited on two- http://s563.photobucket.com/albums/s...0two%20wheels/
Endeavor to Persevere
Blue Skies Coming
Jud is offline   Reply With Quote
Old 04-18-2012, 02:33 AM   #81
erkankaplan
Oddometer: 8
wd-40 is the difference between silicon and silicon-free?
Old 06-29-2012, 08:43 AM   #82
urbanXJ
urbanXJ's Avatar
Oddometer: 3,056
Awsome thread!
...SPEEDING PAST THE LINE OF GOOD TASTE...
urbanXJ is offline   Reply With Quote
Old 06-29-2012, 09:24 AM   #83
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,884
Great research work.
Scientific and detailed. Thanks for this. Cheers.
Old 06-29-2012, 09:46 AM   #84
MotorCade
Rugby whore
Oddometer: 457
KLR riders...
Ok, actually, this is cool. Thanks for running the experiment. Sample size is a little small... (I'm a qual. eng! ha ha)
I also still do not run WD-40 on my chains, cleaning or otherwise. I use a chain cleaner and yamalube. The WD in WD-40 stands for 'water displacement', as the initial intent was to prevent rust. It's a great cleaner and solvent, and so it will dissolve the lube that's already held in place by the o-rings. But it's good to see that perhaps a light application (like on a rag?) might be a nice way to clean up surface crud on the chain.
Cheers,
Cade
MotorCade is offline   Reply With Quote
Old 06-29-2012, 10:38 AM   #85
Wuwei
Oddometer: 1,108
Do a little Googling and you'll find lots of riders use nothing on their o-ring chains but WD-40 and report excellent results. Here's one good write up about it.
For my part, I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to move. Robert Louis Stevenson
Wuwei is offline   Reply With Quote
Old 06-30-2012, 08:38 AM   #86
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,821
Will this thread ever die?
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 06-30-2012, 05:43 PM   #87
Jud
Jud's Avatar
Oddometer: 2,291
Does it matter? I like the banter.
Blue Skies Coming
Old 06-30-2012, 06:45 PM   #88
FixerDave
KLR650 - XR200R
FixerDave's Avatar
Oddometer: 386
Not if I can help it And I just did. Maybe I should put a google reminder in for 2018 or so... come back and poke it again.
But, on a more serious note, I was thinking about doing some regular winter chain maintenance... somehow getting the water out from behind the O-rings and getting grease back in. Maybe something like pulling the chain (I use master links, so no big deal) and putting in in a big can of grease, then heating the grease up until it flows... maybe make it a pressure vessel and use vacuum while it's hot and then pressure as it cools. Maybe cycle a couple of times.
But, you know, I ride a KLR. I've maybe put 3 chains on the bike in 20 years. Besides that, I don't do winter maintenance. So, screw it, blast it with WD-40, wipe it off, spray on whatever can of chain lube I happen to have, and then go for a ride. $200 for chain and sprockets every 10-20K... not worth the hassle to think about. Of course, that $200 was for the last set... and it seems that was an entire chain-life ago.
David...
FixerDave is online now   Reply With Quote
Old 06-30-2012, 07:57 PM   #89
NortwestRider
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 3,806
I read EVERYthing I can on chain maintenance and no matter what I do short of lubing every 50 miles ( thats a round trip for me everyday ) I can only get about 10-12,000 miles out of a chain on my DL1000 !!!!.I ride in rain atleast 150-200 days a year and try to lube it once a week but I have to adjust it atleast once a month !!.
2012 Honda NC700XAR
1990 XT350 Overlander
GS500ADV..THE PURPLE EXPLORE
Facebook..PNW Adventure Riders..Facebook
MY BUILD http://www.advrider.com/forums/showthread.php?t=938440
NortwestRider is offline   Reply With Quote
Old 06-30-2012, 09:00 PM   #90
FixerDave
KLR650 - XR200R
FixerDave's Avatar
Oddometer: 386
Originally Posted by NortwestRider View Post
...I can only get about 10-12,000 miles out of a chain on my DL1000 !!!!
You're getting pretty much what I am right now (km to miles conversion going on here). You just ride more. If you're not concerned with the mess, you might want to try one of those Scott-type oilers. Just a constant dribble of motor oil... suppose to be best overall for the high-mileage folk. Keeping the thread on track... you can use WD40 to clean up the mess
If you're not into the mess, you could swap that 1000cc engine out for some 80cc scooter plant, I can pretty much guarantee your chain will last much, much longer of course, so will your commutes.
David...
Times are GMT -7.   It's 05:39 PM.
