Old 04-11-2013, 09:14 AM   #661
benwiggin2
benwiggin2's Avatar
Oddometer: 2,120
these bikes were designed to run with the power up kit installed.
benwiggin2 is offline   Reply With Quote
Old 04-13-2013, 06:53 AM   #662
bobnoxious67
Baby steps...
bobnoxious67's Avatar
Oddometer: 2,635
This. I'm amazed at how shitty they run without it.
Field & Forest Recreation Area
00 KTM 640 ADV
01 Girlie
09 TE450
bobnoxious67 is offline   Reply With Quote
Old 04-13-2013, 07:54 AM   #663
biggsxr
Oddometer: 40
I found a good used cover, and promised myself to never use the kick starter.....
Now that she's running, she's got some problems;
2007 TE510, starts and idles ok. I hears a lot of loud rattling at idle and lower speeds. Like piston slap, or maybe timing chain/valves.
When revving up it sometimes "revs down" very quickly, and sometimes revs down and dies very quickly.
It almost seems like a rod bearing seizing up. Although it cranks over and starts again.
Oil change showed some fine particles on the magnet, no big chunks.
I'm looking for this to be a reliable trail/street machine. Sounds like a tear down is in order. Thoughts??
Originally Posted by biggsxr View Post
I just bought a 2007 TE510. A bit rough , but running.
# 1 big issue...
Do I have any chance of finding a used Clutch Case and cover?
biggsxr is offline   Reply With Quote
Old 04-13-2013, 10:30 AM   #664
Tachedoutoffroad
Mr. Parrish
Tachedoutoffroad's Avatar
Oddometer: 637
I'm no mechanic, but your shit sounds fuked up
Looking forward the he PU kit.
If I don't flash it immideatly, will it still be rideable? It will be another week before I can get it to the dealer.
Also put my 610SM up for sale and found some SM wheels for the 510.....
'00 KTM 400EXC --plated!
'89 Honda Transalp
Sikorsky UH-60L
Support your local know-it-all gear guy and give your money to Brian at https://www.atomic-moto.com/
Tachedoutoffroad is offline   Reply With Quote
Old 04-13-2013, 12:43 PM   #665
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,783
It's been sitting up quite a while right? I'd think a carb cleaning would help the idle/dying thing. The rattling could be loose valves that need re-shimming. Fine particles in the oil is not a big deal.
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 04-14-2013, 06:25 AM   #666
bobnoxious67
Baby steps...
Oddometer: 2,635
You can "power up" without dealer input...removing the O2 sensor and installing the resister plug into the wiring harness in it's place tells the computer to use the race map already built into the computer.
I have 7500 miles on mine.
00 KTM 640 ADV
01 Girlie
09 TE450
Old 04-14-2013, 03:45 PM   #667
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,783
I am getting near to 14,000 miles, today, on a hard dual sport ride, me and my buddy on the Beta both filled up at the same time, and did a 32.5 mile loop with our EXC buddy, the Beta man put 1.3 gals in after the loop, about 25mpg, and I put in 1.4 gals, probably 23mpg, we were haulin' ass for sure, temps in the high 80sF. The TE450 can hang with the newer 450RR and 500EXC.
Old 04-14-2013, 03:49 PM   #668
drrags
Dorkus Malorkus
drrags's Avatar
Oddometer: 1,814
Nice. I have never complained about the lack of power on my 450 and I have no desire to replace it with anything else anytime soon. Love that bike
drrags is offline   Reply With Quote
Old 04-16-2013, 10:45 AM   #669
Tachedoutoffroad
Mr. Parrish
Oddometer: 637
Damnit.
Intermittent e-start button issues already my 310 has all kinds of issues and ended up pissing me off pretty good.
It also just cut off once when I was slowing down from 60mph to a stop... Then it wouldn't start back up...
Just venting now. Hope it will get me home and can dig into it tomorrow.
-it wasn't hot, this was the first start in the morning.
-could hear the fuel pump priming
Just no hit when I pushed the button... I hate wiring!
'89 Honda Transalp
Sikorsky UH-60L
Tachedoutoffroad screwed with this post 04-16-2013 at 11:07 AM
Old 04-17-2013, 07:58 PM   #670
Tachedoutoffroad
Mr. Parrish
Oddometer: 637
Alright , alright. The 510 is a fukin beast
The previous owner had taken out the cover thingie on the air filter and the cat in the exhaust, but no O2 sensor delete. Only took a little while to button everything up and go haul ass! It feels perfect now. The power is very traceable and smooth. The hesitation and drag is gone. Just instant wheelie or burning the rear tire down in the dirt. But it's very traceable? I guess. Manageable maybe? Whatever it is, it's fun!
The sporadic start is the clutch cancel switch in the lever just have to pull t in alllll the way, sometimes twice, but then she fires up. Will probably just bypass it soon.
Amazing machine!
'89 Honda Transalp
Sikorsky UH-60L
Old 04-17-2013, 08:15 PM   #671
Bobby Ginger
Cat Herder
Bobby Ginger's Avatar
Oddometer: 974
Just wanted to share some info. I finally had a chance to take out my 08 450. I had a fun ride on some fast dirt roads and two track. I cannot even compare my DRZ to this bike, it is not in the same class. Anyways on the to the story, I got off on to a trail by accident and sunk my bike in a deep water hole. I got the engine off quickly got it home on my truck.
I dried every thing out. Took the airbox out, clean the plug, flushed the oil 3 times, dried and cleand the air filter. Everthing back to normal . BRAPPP ON!
2009 GSA 2008 Husky TE450 2013 Husky Terra 2006 KTM 950 SM
IBA 50407
Bobby Ginger is offline   Reply With Quote
Old 04-18-2013, 07:16 PM   #672
Bobby Ginger
Cat Herder
Oddometer: 974
Rox on TE450
I did not see a post on here about it so I thought I would share. I put 2 in rox on this evening. I did not thing about the throttle cables but they were to tight. I pulled the tank, even though it was full , to see if there was any slack. I did not have enough so I routed the cables underneath the bars and everything is good again. If you have not played with a throttle cable assembly before it can be a bit of a PITA, at least it was for this amature wrencher.
IBA 50407
Old 04-21-2013, 11:45 AM   #673
Tachedoutoffroad
Mr. Parrish
Oddometer: 637
Love this beast.
Very Dual Sporty!
Only one one knobbies in the sport bike safety course yesterday...
Knobbie chicken strip
Then today hit the MX track. Only one with a 4.2 gal tank and a Garmin
I couldn't have chosen a worse random person to take pics
And got stuck in the mud on the way home......
Good times!!!
'89 Honda Transalp
Sikorsky UH-60L
Old 04-30-2013, 08:11 PM   #674
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,653
Due to ridiculous import laws in Canada, I can't import my TE510. I'm rather partial to it. It's a 2010 with more mods than the bike is worth. I'm thinking of tearing it down and bringing the pieces home - minus the US frame. I'll bolt all the great stuff onto a Canadian bike.
My question to all, are the 2008/2009/2010 frames from the Husky line up similar? Do I need to stay with another 2010, fuel injected bike?
Thanks for any insight.
J
dirtydeeds is offline   Reply With Quote
Old 05-09-2013, 05:21 PM   #675
dirtfarmerrich
Richard
dirtfarmerrich's Avatar
Oddometer: 106
Chain replacement
My TE 510 has 2300 miles on it and I,ve noticed broken O-rings on my garage floor . The chain has,nt streched much and does,nt seem wore out. I,ve got a long dual sport trip coming up , should I replace it?
dirtfarmerrich is offline   Reply With Quote
Times are GMT -7.   It's 08:25 PM.
