Old 05-09-2013, 09:27 PM   #676
benwiggin2
benwiggin2's Avatar
Oddometer: 2,146
Not if you are comfortable with the possibility of a failure on your long dualsport ride.
Originally Posted by dirtfarmerrich View Post
My TE 510 has 2300 miles on it and I,ve noticed broken O-rings on my garage floor . The chain has,nt streched much and does,nt seem wore out. I,ve got a long dual sport trip coming up , should I replace it?
benwiggin2 is offline   Reply With Quote
Old 05-16-2013, 05:29 AM   #677
bobnoxious67
Baby steps...
bobnoxious67's Avatar
Oddometer: 2,854
Do I need to repack my muffler? How often?
7500 miles now, and I'm noticing a lack of power, especially up top...and it seems louder with just the spark arrester than before. I normally run the DB reducer insert, but it just doesn't have the grunt it used to...not a heck of a lot better with the spark arrester.
'00 640 ADV, '01 Girlie, '09 TE450
bobnoxious67 is offline   Reply With Quote
Old 05-16-2013, 05:45 AM   #678
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,857
Are you running the short insert or the longer Euro insert?
I recently re-packed my Arrow can, and now, after all that work, I wish I had not re-packed it. You have to cut out a stainless steel inner piece that is really the muffler itself, which turns the aluminum outer cover into the new muffler body structure. After re-packing, it was no quieter than before and with complaints from my road mates, I purchased a Euro dBkiller for $65 and man, what a difference, more low end grunt and much quieter, wish I would have done the dBkiller instead of repacking.
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 05-16-2013, 05:50 AM   #679
bobnoxious67
Baby steps...
Oddometer: 2,854
That's the insert I usually run.
So they use packing material...but don't actually make allowances in the construction to repack/rebuild it?
Old 05-16-2013, 07:13 AM   #680
benwiggin2
benwiggin2's Avatar
Oddometer: 2,146
Hey Jake, how does the insert db killer install?
Old 05-16-2013, 10:08 AM   #681
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,857
Funny guy, you just stick it in, (spark arrastor has to come out first).
I screwed my muffler up so much by cutting the internal stainless body out if it, that the end cap was not longer square enougfht for the dBkiller to fit flush with the snap ring groove, I had to grind down the flange area of the dBkiller so that I could get the snap ring into its groove.
Old 05-16-2013, 10:10 AM   #682
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,857
Correct, I used a metal cutting blade in a circular saw, set the depth to where it would just cut thru the stainless housing.
Old 05-16-2013, 10:18 AM   #683
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,857
Since you are running the Euro dBkiller and the bike seems louder, then yeah, you are gonna have to either cut the Arrow up and repack, or buy something new.
Cutting the stainless body out was not that big a deal, and packing it back up and putting it back in the aliminum housing wasn't the easiest thing, but I got it done and pop-riveted back together, and it's really quiet now AND seems to have a little more low end punch.
AustinJake screwed with this post 05-16-2013 at 01:16 PM
Old 05-16-2013, 10:20 AM   #684
benwiggin2
benwiggin2's Avatar
Oddometer: 2,146
Ok guys- where is the link for db killer insert?
Old 05-19-2013, 04:45 PM   #685
bobnoxious67
Baby steps...
Oddometer: 2,854
ok guys- where is the link for db killer insert?
p/n: 8000h0827
Old 05-19-2013, 07:40 PM   #686
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,857
14,000 miles and still hangs with the 500 EXC....
Old 05-21-2013, 07:05 PM   #687
Tachedoutoffroad
Mr. Parrish
Tachedoutoffroad's Avatar
Oddometer: 647
Loving the 510. Put about 400 miles on it now. Mostly in 1 hour-2 track excursions. Rode about 50 miles of street today just to see how it did.....
-Is it truly "bad" to cruise at 65mph/ 6600rpm for 20-45min? Or 2 hours?
-Is it really worse than super high revving, over and over, and banging gears for the same about of time on a trail?
-Is cursing at 55mph/ 5500 rpm much better?
'00 KTM 400EXC --plated!
'89 Honda Transalp
Sikorsky UH-60L
Support your local know-it-all gear guy and give your money to Brian at https://www.atomic-moto.com/
Tachedoutoffroad is offline   Reply With Quote
Old 05-21-2013, 07:12 PM   #688
drrags
Dorkus Malorkus
drrags's Avatar
Oddometer: 1,816
Well, *I* don't think it's bad. I cruise at that speed/RPM all the time. It's well within the design limits. I can't comment on the super high revving though as most of my trail riding RPM is below 5,000 RPM. Of course, in the end, the longer the engine sees high RPM, the sooner it will wear. How much fun do you want to have!
drrags is offline   Reply With Quote
Old 05-21-2013, 07:12 PM   #689
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,364
Anyone else had the valve cover bolts strip the threads in the cam caps. I had and oil leak at the front of the valve cover dripping onto the exhaust covering everyone in smoke when i pulled up. Checked the valve cover bolts to find one loose that i could turn by hand and the other was tight but pulled out a couple of threads when i removed the cover. Cant get new cam caps, have to buy a complete head, so will stick some helicoils in and hopefully solve the issue.
poppy screwed with this post 05-21-2013 at 07:18 PM
poppy is offline   Reply With Quote
Old 05-21-2013, 07:32 PM   #690
Tachedoutoffroad
Mr. Parrish
Oddometer: 647
Cool. Thanks.
My TE310 was at 7000rpm at 55mph with a 50 tooth rear and I felt like it was going to explode at any second. The 510 still feels... Comfortable?? at 6000-6500rpm. Wasn't sure what was recommended by the engineers.
Oh, does every bodies 510 EAT rear tires? my XR doesn't do it like this
'89 Honda Transalp
Sikorsky UH-60L
Times are GMT -7.   It's 03:49 PM.
