Old 08-25-2004, 11:17 AM   #46
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,716
Originally Posted by creeper
Have you tried the Silent Sport packing... or was that the Moose stuff in the sleeve? Stupid question but gotta ask, you have been getting the 4-stroke stuff right?
Yup, using the 4T stuff in all cases. Tried 2 kinds from Moose, no results worth noting cept that I have to repack it again after a day! Getting kinda expensive, ya know?
Getting tempted to make my own baffle within this can, eliminating the need for packing. Got the can as a trade for some BMW parts, so I'm not too worried about chopping it up.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 08-31-2004, 11:16 AM   #47
bibendum
Oddometer: 9
Akrapovic Slip On Advice - HELP!
Guys,
I'm planning to install a Akrapovic slip on exhaust on my '04 640 Adventure.
The guys at KTM-Sommer tell me that to get max performance from the exhaust, I also need to get the free flow airbox cover, change the main jet to a bigger one and reduce the size of the air idle jet(?).
I was talking to the guy over the phone so I'm not sure if I understood him right since I don't speak German and his English wasn't 100%.
So I decided to email them instead....
This is what they said with regards to the jet:
"to win any/further torque and hp both steps have to be used with the jetting
kit for bst 40 (about 38 ?) plus deactivating sls = Sekundärluftsystem (?
0,45)."
Can someone explain this to me? What does deactivating sls mean?
Hope someone can shed some light, I would highly appreciate it.
bibendum is offline   Reply With Quote
Old 08-31-2004, 11:25 AM   #48
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Originally Posted by bibendum
Guys,
0,45)."
For the BST40 carb, asside from the air box side cover, you will end up with a 157.5 to 165 MJ, #4 needle groove (from the top), drilling the vacuum piston transfer ports to .117" (3mm) -.125" (1/8") and for a large percentage pre '03 models, a 1.1 air jet OR 47 pilot jet.
So... how's tricks?
creeper screwed with this post 04-26-2005 at 07:13 PM
creeper is offline   Reply With Quote
Old 09-16-2004, 07:56 PM   #49
bibendum
Oddometer: 9
creeper,
thanks for the info!
i decided to go with the akrapovic slip on system, air cleaner setup and new jets.
i ordered the stuff from KTM-Sommer.
they are sending me the proper jets for use with and without the internal silencer or what they call the db eater.
i'll update once i have everything installed and running.
it may take a while since i won't be back home till mid october.
Old 11-17-2004, 10:48 PM   #50
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,253
Exhumed, but just because I noticed that TT is getting quotes for the Akrapovics slip on around $350 dollars... not bad at all.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 11-18-2004, 07:32 PM   #51
rapiti
IOR Veteran
rapiti's Avatar
Oddometer: 1,917
...snip
Guys,
0,45)."
Sekundärluftsystem = Secondary air system. Smog device. Look at you headpipes, otherwise, what Creeper said so many months ago.
...its the best paint scheme that has ever been or ever will be on an Adv...-AussieRob
rapiti is offline   Reply With Quote
Old 12-13-2004, 04:55 PM   #52
meat popsicle
Ignostic
Oddometer: 14,253
Staintune
BUMP!
http://www.staintune.com.au/exhausts/ktm/index.htm
Staintune distributor - and links to retailers in the USA.
KTM LC4 pipes: $210
KTM LC4 can: $385
Here:
http://www.cbtimports.com/stntnktmapps.htm
PS - staintune are 100% mechanical baffles, no internal parts to wear out... good for those who like to forget about it or long distance Adv Tourers I guess.
Old 03-07-2005, 09:36 AM   #53
meat popsicle
Ignostic
Oddometer: 14,253
BUMP for those 05 buyin' bastages!
and an additional link:
http://www.ktmamerica.com/powerparts...um=57305007000
KTM/FMF 4-Stroke Titanium Header Pipe 640 LC4/ADV
For 640 LC4/Adventure
$600
Old 03-07-2005, 10:29 AM   #54
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,868
I thought it should be mentioned that Wings makes a silencer for the LC4, and our own Andy-rew Fekete is a Wings dealer.
Also worth mentioning is that a set of two Ti silencers for the 950 cost about what a single Akra can costs for the LC4, and a set of spark arrestors for said set of cans is $75.
Andrew hasn't quoted prices on the LC4 system yet, but it looks promising that we should be able to get a Ti can w/SA for a reasonable price.
Some pics of the Aluminum version (even less expensive):
More info here
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 03-07-2005, 10:41 AM   #55
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Good add Stobie... I believe the Wings systems are relatively new to the market and were not even available when this thread was started about a year ago.
Nice looking stuff it is.
So... how's tricks?
Old 03-07-2005, 10:51 AM   #56
BLUE(UK)
BLUE(UK)'s Avatar
Oddometer: 3,423
I just plodded to the end of the thread thinking i will tell ya's about the 'wings' when some fecker(stobie) beat me to it.
I have akro's on me 950 but if i didnt i would have wings(remove the sticker tho)
BLUE(UK) is offline   Reply With Quote
Old 03-07-2005, 12:50 PM   #57
AFekete
AFekete's Avatar
Oddometer: 3,208
Thumb info coming shortly....
More info here
As soon as I get more info I'll post it in the vendor forum...
thanks,
A
AFekete is offline   Reply With Quote
Old 04-26-2005, 07:01 PM   #58
meat popsicle
Ignostic
Oddometer: 14,253
BUMP -for you 2005 bastages!
Old 04-26-2005, 07:20 PM   #59
Gerg
Cupcake
Gerg's Avatar
Oddometer: 8,457
As a '05 bastage I thank you
Today I got on the list for the SuperTrapp at
www.adventure-motorcycle.com
Roger has two coming in around the first of June. If you want one better get in line. If there is enough comitment he probably can get more.
Thanks to Creeper and Meat for the leads/info
Gerg
Greg
Certified Ole Fart
Gerg is offline   Reply With Quote
Old 04-26-2005, 10:54 PM   #60
meat popsicle
Ignostic
Oddometer: 14,253
Gerg
no problem Gerg - it was grand seeing the Great Pumpkin in person
Times are GMT -7.   It's 07:35 AM.
