Old 12-19-2012, 10:51 AM   #1186
motolab
motolab's Avatar
Oddometer: 2,521
Originally Posted by blackcap View Post
hi all, just posted this ove in the DR650 thread but someone reminded me this is probably a good place to get some exposure too. ive got a unifilter installed on the vent hose that goes to the top of the carb but it looks like a few hundred kms of the talcum powder that makes up the logging road surfaces in borneo just went straight through the unifilter and into the carb. does anyone run anything other than the unifilter on their carb vent? as far as im concerned its useless for anything other than stopping sand.
I completely disagree with your assessment of the UNI, but here is an alternative strategy: http://advrider.com/forums/showpost....postcount=1087.
Regards,
Derek
motolab is online now   Reply With Quote
Old 12-20-2012, 04:52 AM   #1187
blackcap
blackcap's Avatar
Oddometer: 538
Regards,
Derek
that looks like it could work in tandem with my intake filter strategy. nice and simple and easily repaired with stuff i can find here. just a though, what might the consequences be of using a tee piece to connect the carb vent line to the other small hose that terminates at the airbox behind the primary intake filter? good idea or is that asking for trouble by essentially linking the two air circuits and messing up all the required pressure differentials?
"One must die sometime and to die with ones boots on is very noble" - Carl Stearns Clancy, first RTW motorcycle, 1912-13
Australia to Iceland on a DR650 http://oztoice.wordpress.com
and facebook https://www.facebook.com/oztoice
blackcap is offline   Reply With Quote
Old 12-20-2012, 02:32 PM   #1188
motolab
motolab's Avatar
Oddometer: 2,521
I would not link the underside of the diaphragm to the bowl vent (if I'm understanding which hoses you're referring to correctly).
Regards,
Derek
Old 12-20-2012, 02:46 PM   #1189
BluesCruiser
BluesCruiser's Avatar
Oddometer: 83
I believe he is talking about what on a DR650 is the breather tube from the engine case that enters the back of the airbox "inside" the filter. No, this would NOT be a good idea to connect these two hoses!
2009 DL650A "Mendoza"
2000 DR650 "Thumpa"
California East Bay
BluesCruiser is offline   Reply With Quote
Old 12-21-2012, 01:07 AM   #1190
blackcap
blackcap's Avatar
Oddometer: 538
Regards,
Derek
had a feeling it wouldnt end well, just thought id check with the pros. would be nice to eliminate one more filter.
Old 12-24-2012, 05:05 PM   #1191
zimi
Oddometer: 57
Hi there,
this thread was very interesting for me to dismount a clean my carb.
But I lost on O-Ring and another one need to be change. My KTM garage told me they can't order me these. can anybody give me the sizes?
It's the needle valve O-Ring (probably Di=7 and d=1.5) and the Fuel/air mixture O.Ring (maybe Di=3 d=1)???
Thanks really apreciate your help
zimi is offline   Reply With Quote
Old 12-24-2012, 07:15 PM   #1192
motolab
motolab's Avatar
Oddometer: 2,521
Originally Posted by zimi View Post
Hi there,
You can use these Suzuki part numbers:
13374-35C00 needle seat o-ring
13295-29900 fuel screw o-ring
Are you sure the fuel screw o-ring is not stuck to the floor of the fuel screw well?
Regards,
Derek
Old 12-25-2012, 03:07 AM   #1193
zimi
Oddometer: 57
Thanks Derek for your very fast answer!!!
No the O-ring is not in the carb anymore
Old 12-25-2012, 11:49 AM   #1194
motolab
motolab's Avatar
Oddometer: 2,521
You're welcome.
Did you find the washer?
Regards,
Derek
Old 12-27-2012, 04:22 AM   #1195
zimi
Oddometer: 57
yes I have the washer. no problem on this side, thanks!
I couldn't get the O-ring yet, everthing is closed for the christmas holidays..
Old 01-05-2013, 06:56 PM   #1196
toondebt11
ADVRIDERKEVIN
toondebt11's Avatar
Oddometer: 333
cleaning Day
just finished up cleaning my 2009 Dr 650 Carb. 26XXX miles of mixed use. Lots of dirt under the diaphram. After a healthy cleaning, new o rings and float needle from procycle, she is purring like new. I will be adding some additional filtering to the vents. Thanks for the great (How To) write up.
too n debt
Black 2009 DR 650
Black 2004 DL 650
I B A # 42258
toondebt11 is offline   Reply With Quote
Old 01-05-2013, 07:02 PM   #1197
motolab
motolab's Avatar
Oddometer: 2,521
Did you inspect the slide guide and emulsion tube for wear?
Regards,
Derek
Old 01-05-2013, 07:26 PM   #1198
toondebt11
ADVRIDERKEVIN
toondebt11's Avatar
Oddometer: 333
I cleaned everything very well and just did a visual inspection. I did not do any measurements. The needle had very minimal wear beginning. other than that, everything looked good.
too n debt
Black 2009 DR 650
Black 2004 DL 650
I B A # 42258
Old 01-05-2013, 08:50 PM   #1199
motolab
motolab's Avatar
Oddometer: 2,521
If you had to guess, how deep do you think the depressions in the bottom corners of the slide guide/concentric to the bore are? (See http://www.moto-lab.com/gallery/view?itemid=298, http://www.moto-lab.com/gallery/view?itemid=299, http://www.moto-lab.com/gallery/view?itemid=300, and http://www.moto-lab.com/gallery/view?itemid=301 {click images for a high-res view}).
What color were the deposits under the diaphragm?
Regards,
Derek
Old 01-05-2013, 09:34 PM   #1200
toondebt11
ADVRIDERKEVIN
toondebt11's Avatar
Oddometer: 333
well if I had known then what I know now, I could tell you more. At least I know what to look for the next time I have it apart. For now, it's running smooth and strong. Thanks for the education.
too n debt
Black 2009 DR 650
Black 2004 DL 650
I B A # 42258
Times are GMT -7.   It's 05:43 PM.
