Old 06-06-2013, 11:49 AM   #1336
motolab
motolab's Avatar
Oddometer: 2,529
Originally Posted by bradrh View Post
One other thing. The float and float/needle valve seem to be an assembly, not like the pictures shown at the beginning of this thread. Correct? Or should I try harder.
It is an assembly, however it can be taken apart for needle inspection. If the tip has a witness line where it has been contacting the seat (check with and without magnification), the float valve either leaks or will begin leaking soon.
Regards,
Derek
motolab is offline   Reply With Quote
Old 06-12-2013, 03:01 PM   #1337
ER70S-2
ER70S-2's Avatar
Oddometer: 6,130
You're correct. The carb shown at the beginning is out of a KTM and that's one of the most confusing differences.
Regards,
Derek
2004 DR650SE at 46,xxx miles:
Also at 46k:
Not my photo, showing the witness line:
2004 DR650: 62,402 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 06-13-2013, 05:58 PM   #1338
laramie LC4 OP
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,369
hey guys, i could use your help. this is a shameless request for your vote.
trying to win an intake system for my 990 and need your vote. please go to this THREAD and make a post for a vote with my member name.
thanks,
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 06-14-2013, 06:41 PM   #1339
tdreyer
KTiM
tdreyer's Avatar
Oddometer: 503
thanks,
laramie
Hey guys the Op is looking for a little help, only takes a minute. Anyone?
~Tim
"04625 SXC
'04 625 SMC 76,xxx mi.
'97 CR500 Sold
tdreyer is offline   Reply With Quote
Old 06-14-2013, 07:52 PM   #1340
ER70S-2
ER70S-2's Avatar
Oddometer: 6,130
BTDT
2013 WR250R
Old 07-01-2013, 12:24 PM   #1341
wvrocks
wvrocks's Avatar
Oddometer: 601
I'm slowly working my way through all 90 pages of the Bible. I recently bought a 2000 640 Adv and have some questions about my carb set up. There is a leak from the carb overflow if the bike is left to sit with the petcock and the bike will sometimes die if you chop the throttle coming to a stop, especially on downhills. It also bogs a bit right off idle. Idle is pretty smooth. Because of that I decided to tear into the carb and find out what the previous owners had done. I'm the 4th owner.
I've got a 147.5 main jet (142.5 was stock), 45 pilot fuel jet, Idle mixture screw is at 3.25 turns from bottom, the needle is in the 3rd slot and had a small shim under the metal washer so its effectively in the 3.5 slot. Slide is not drilled, spring appears to be uncut. The stock Supertrapp has been cored (rather sloppily) and has 8 discs and the center cap. The air box has been opened up a little by drilling 3 1.25" holes in the top between the snorkel and battery. The snorkel is still in place.
I live at 2000' and most rides are between sea level and 5000'. The bike runs ok as far as I can tell. Its my first KTM so I have nothing to compare it too. It won't lift the front wheel as easy as my 95 R1100GS would but has way better power than my 08 KLR did.
I believe my leak is a float adjustment problem, the rubber float weight tip is in good shape. I set the float by blowing into the fuel line and it looks like it was set too high. I'll know more once I get it put back together. Also thinking about backing the idle mixture screw down to 2.5 turns to see if that takes care of the off idle bog.
Do my settings look about right for my elevation? Any changes you would suggest? I'm adding a Stenhouse mixture screw to help with tuning. Thanks!
Never underestimate the power of stupid people in large groups.
wvrocks screwed with this post 07-03-2013 at 11:32 AM
wvrocks is offline   Reply With Quote
Old 07-01-2013, 01:27 PM   #1342
ER70S-2
ER70S-2's Avatar
Oddometer: 6,130
These can cause running problems and should be replaced, ethanol doesn't help.
If the larger one leaks, fuel bypasses the float weight needle.
2013 WR250R
ER70S-2 screwed with this post 07-19-2013 at 02:09 PM
Old 07-01-2013, 01:35 PM   #1343
wvrocks
wvrocks's Avatar
Oddometer: 601
Thanks, I'll check them out
Old 07-01-2013, 11:00 PM   #1344
bmwktmbill
Traveler
Oddometer: 5,049
The BST40 is different than that, the o ring is above the needle seat and yes it will fail and cause an overflow.
b
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 07-01-2013, 11:05 PM   #1345
ER70S-2
ER70S-2's Avatar
Oddometer: 6,130
b
It's the BST40 on a DR650SE.
2013 WR250R
Old 07-02-2013, 06:41 AM   #1346
wvrocks
wvrocks's Avatar
Oddometer: 601
Yeah, mine is the KTM version. Only has the one o-ring on the float frame. Is there supposed to be an o-ring inside of the needle jet? There is one between the needle jet and the carb body, but not one inside where the float weight seats.
Old 07-02-2013, 03:53 PM   #1347
laramie LC4 OP
crash test dummy!
Oddometer: 2,369
thanks,
laramie
Thanks to those of you who have voted. I'm in the lead with 1 more day to go. Tightening up a bit, if you haven't had a chance to vote yet I'd sure appreciate it.
Thanks,
Laramie
Old 07-02-2013, 09:46 PM   #1348
bmwktmbill
Traveler
Oddometer: 5,049
Rocks, do you have the parts manuals?
b
Bill Shockley
Old 07-02-2013, 10:16 PM   #1349
motolab
motolab's Avatar
Oddometer: 2,529
Originally Posted by ER70S-2 View Post
If the larger one leaks, fuel bypasses the float weight.
Do you mean that if the larger one leaks, fuel bypasses the float valve?
Old 07-02-2013, 10:24 PM   #1350
motolab
motolab's Avatar
Oddometer: 2,529
No.
There is not supposed to be an o-ring between the needle jet and carb body. The nearest o-ring to the needle jet would be the one between the slide guide and the carb body. I have seen the term "float weight" used several terms in this thread, but am otherwise unfamiliar with the term.
Regards,
Derek
Times are GMT -7.   It's 05:01 AM.
