Old 06-01-2008, 04:42 PM   #1
Mr Head OP
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,674
Grip Replacement
120,000 miles. Ugly old grips. This is a late 2004 1150 Adventure. The OEM grips looked like those found on the 1200's.
Started with them looking like this:
Removed the hand guard, and mirror to allow access:
As can be seen the underlaying material was already somewhat exposed. I started with a new blade in the xacto knife and carefully began to peel and cut my way into the assembly,
A little further along things look like this:
The heating wires lay in small gooves, you'll want to take some time and care. I found peeling back along the body of the grip to work best. This side I worked from the barend in. At the throttle side I worked from the other direction. It was a little easier on that side to see what was going on. Also there was more adhesive on the throttle holding the rubber on so it was slower and harder on the fingers,
Alright completely peeled:
You will note this little cap that is normally molded into the grip I pulled the clutch side out and wrapped the end with tape to hold the diring down while I slipped the new grip into place.
I forgot to pick up some cheap hair spray but with two daughters in the house I had nothing to worry about on that front...
And the throttle side:
Done:
And Done:
This took me about an hour. Left me with sore fingers, but new grips. I checked them for function and they still work!
Though the thicker rubber provides a bit more insulation...
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline   Reply With Quote
Old 06-01-2008, 04:53 PM   #2
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
What brand of grips did you use? I'm ready do replace mine, they're worn through in a couple of spots.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 06-01-2008, 05:40 PM   #3
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,113
Looks like he's got the BMW "sport touring" grips on there. I replaced my bmw grips with progrips 714- california sport touring has them, if you can't find them locally. They're excellent grips.
And they're $7.25 a pair.
If you need 2 throttle side grips, it's still cheap.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 06-01-2008, 05:56 PM   #4
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Those 714s look pretty nice, Zak. Can't argue with the price either.
Some company though, make a replica of the BMW "sport touring" grips for about the same money.
Old 06-01-2008, 06:16 PM   #5
papavero
Just good enough.
papavero's Avatar
Oddometer: 114
Part number for the grips. Shame to leave us hanging like that. Looks good though. Only another 100,000 and I'll be ready to change mine. Are the new grips a larger diameter?
"Failure is only the opportunity to begin again more intelligently" unknown
Paul
'07 R1200GS
papavero is offline   Reply With Quote
Old 06-01-2008, 06:19 PM   #6
Mr Head OP
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,674
I ordered the OEM Grooved Right side grip from the earlier GS's.
P/N 32721458396
Larger diameter, but I'm used to holding big stuff...
$20 for a pair form Max BMW. I like them cause they send me M&M's... I'm a sucker for chocolate...
Oh, and I get them pretty fast too.
...Dick
Smugmug
Old 06-01-2008, 06:43 PM   #7
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
I think he used the aftermarket brand, Paul. I thought I heard him say that anyway.
Or, you can use 2 of BMW part number 32 72 1 458 396 (right grooved handle for K-1) exact match for the "sport touring" grips on the non-adventure 1150. At one time the '396' part was in the parts fiche. Now it looks like the only factory replacement grips are the complete heated grips for about $200/pair.
[EDIT] Oh cool, they're still available.
Old 06-01-2008, 08:07 PM   #8
Mr Head OP
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,674
See above, I bought two of the 396's.
Just put in the number and make it for two.
$20.
Easy-peasy....
...Dick
Smugmug
Old 06-01-2008, 09:21 PM   #9
mrfreeze54
mrfreeze54's Avatar
Oddometer: 102
My grips are wore bad also. I was told at a few dealers, only fix was new heated grips. Bull crap. I am not paying $300 to get new grips. I was also told I would never be able to cut them off like you did. I will try now. Thanks for pics and how to....
r1200gs 2005
xr650l 2007
Eagles don't flock, they soar alone.........
mrfreeze54 is offline   Reply With Quote
Old 06-01-2008, 10:39 PM   #10
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Yea I saw that.
Now, where do I get that special adhesive in the fancy aluminum aerosol?
Old 06-02-2008, 12:24 AM   #11
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,943
Grips
You ought to be able to stick a compressed air nozzle under the end of the grip nearest the brake/clutch lever, it shifts the glue and they seem to just expand and come off quite easily. To get them on you can use regular bar soap to grease up the area and it dries like glue.
james
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Old 07-11-2008, 07:38 AM   #12
Mr Head OP
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,674
james
Fancy aluminum can-O-Goo, came from the giant box of female beauty crap that is warehoused upstairs. I just walked down the goo isle and found it between a jar of blue-ish goo and a tub of red goo...
I suppose this is what is meant by goo-goo dolls?
And those little heater wires are molded into the original thin grips like you find on 1200's and some special 1150's. Using compressed air might not leave the little heater wires in tact.
BTW, Nick's 2004 1150 adventure, (same year but the slow color) has the ribbed type, while my bike had the thinner later-model types.
...Dick
Smugmug
Old 09-26-2008, 03:41 AM   #13
savage
Oddometer: 125
Has anyone tried this grip change on a GS1200 ??
savage is offline   Reply With Quote
Old 09-26-2008, 05:42 AM   #14
diabolik37
Push Dumb C***
diabolik37's Avatar
Oddometer: 922
Yep.
Same story....
Also you can use even thicker grips and the heater will still work.
The trick is to go very slow so not to damage the wires.
diabolik37 is offline   Reply With Quote
Old 09-26-2008, 07:45 AM   #15
Mr Head OP
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,674
The heat transfer is less with these ribbed grips compared to the thinner stock grips. Not a big deal here in the OC.
However when I venture out of the warm fuzzy that is the OC, I have to keep this in mind, and carry extra protection...
...Dick
Smugmug
Times are GMT -7.   It's 05:31 AM.
