06-03-2008, 11:09 AM
#1 |
Oddometer: 131
Simple? On/Off Switch Wiring...
This may seem obvious to many of you, but I wanted to change out my on/off switch to my IPF driving lights. The only problem is that the existing IPF switch has three wires (red, black and white) and the replacement has only a positive and negative. I do know that one of the three wires to the IPF switch, (let's assume white), encorporates the wire which senses 12v power to the bike for activation of all accessories through the Centec fuse box. In order to make this work, would I need to connect the white wire to the relay which activates the Centec panel? Maybe I answered my own question...
Rusty ___________ '10 R12GS Fairfax, VA |
06-03-2008, 01:06 PM
#2 | |
Satellites not acquired
Oddometer: 5,422
Take the power out of the switch to the switched connector on the relay to the Centech and you're good to go..
Cyclenutz.com motorcycle accessories Get a SmugMug account and use coupon code DwHE0pDRjpJfw to save yourself $5. |
06-03-2008, 03:02 PM
#3 |
Oddometer: 9,781
All the 3 pole on off switches I have are I/O and a lead for the always on light.
06-03-2008, 04:13 PM
#4 | |
Oddometer: 131
06-03-2008, 04:27 PM
#5 | |
Oddometer: 5,422
Some 3 pole switches have power in, power out, and ground. I did find this diagram for IPF's on a truck but it's the OEM switch so maybe it's the same as yours?? http://www.fjcruiserforums.com/galle...ght_wiring.JPG
06-03-2008, 08:42 PM
#6 |
What could go wrong?
Oddometer: 4,955
How many positions does the existing switch have? Does it have a light built in?
Kawasaki H1 build thread 71- 450 Honda CL re & re Just another pathetic sheep following the herd |
06-04-2008, 04:20 PM
#7 | |
Oddometer: 131
06-05-2008, 10:22 AM
#8 |
Oddometer: 1,849
i've never heard of a IPF switch...but most lit switches---the + gets connected to your voltage scource, the (-) connect to the return to the battery (a lot of people refer to this as a "ground"-whatever), and the (??) connect to the device you are controling
06-05-2008, 11:39 AM
#9 |
The road never ends
Oddometer: 1,510
This would be my GUESS. Using a volt meter with Black connect to negitive side of battery. Lights OFF. On switch Red wire would have 12 voltages Black wire would have 0 volts
White wire would have 0V Lights ON RED would still have 12v BLACK would have 12v White would have 0v If the above is true then the Red and Black wires are the switch wires and the white wire is not used with the new switch. Old Switch Red (+)is from the battery (fuse box) Black(+) goes to the controlled device (lights) White (-) is for the built in light on the switch and is not needed if the new switch has no light NEW Switch Red (+)is from the battery (fuse box) Black(+) goes to the controlled device (lights) Andrew |
