Adventure Rider
Welcome, lurker!   Even if you don't post, the system can help you find the good stuff faster if you register.
Register Members Pics Search Today's Posts Mark Forums Read
Old 06-09-2008, 08:46 AM   #1
klm4755
Oddometer: 422
PART II WD-40 O-ring exposure effect results
Enclosed is the results of the O-ring experiment. The original plan was to assess the O-rings at specific long term intervals. However, to continue with this plan required me to continuously attend the containers. Some of the fluids needed topping off every few days and I did not see myself diligent enough to maintaining the containers over months. So, after 15x days of exposure, I’ll be measuring the failure load of each O-ring for the final evaluation.
O-rings after 15 days
removing the WD-40 exposed O-ring
All O-rings removed and labeled
The failure loads test fixture
50 lbs capacity digital scale
test set up, fill bucket with weights till failure
test weights = 10 lbs 12 oz
first O-ring in test the 15x day exposed carb cleaner specimen, add zip tie
attach to scale hook
attach zip tie to bucket with S hook
empty weight = 6 oz
slowly add weight and O-ring deflects and strains
add all weight = 11 lbs 2 oz
deflected shape with 11 lbs 2 oz
measure deflection, although not used
slowly pull with hand, reading digital values till failure
carb cleaner failure load = 14.4 lbs
Final results for all soaked O-rings
Results of study:
All the chemical had an effect on the strength levels. Based on the reduction in strength after 15 day continuous exposure, it appears WD-40 reduced and had a detrimental effect on the the strength of the O-ring (20% reduction after 15x days). Whereas, the Kerosene reduced the strength level by 12%. More rigorous investigation is required, however based on these results I’ll be using Kerosene to clean my X ring chain.
ready to ride!
Keithm
klm4755 is offline   Reply With Quote
Old 06-09-2008, 08:58 AM   #2
larryboy
Café Racer
larryboy's Avatar
Oddometer: 5,720
Based on those results I'll be using nothing to clean my chains...just like now.
Seriously..nice work!!!
Old 06-09-2008, 09:30 AM   #3
teeedubya
Oddometer: 614
Reminds me of some college physics experiments.
teeedubya is offline   Reply With Quote
Old 06-09-2008, 01:30 PM   #4
markk53
jack of all trades...
markk53's Avatar
Oddometer: 3,943
Just like Mythbusters would'a done... good on ya.
"Ooooohhh, you never know where you're going till you get there..." Sylvester the Cat - Looney Tunes
Mark - klx678
95 KLX650C w/Vulcan piston bigbore
90 Zephyr 550
78 SR500 Street tracker to be
M27 Sherpa T period restoration (first bike in 1971)
markk53 is online now   Reply With Quote
Old 06-09-2008, 03:21 PM   #5
duck
duck's Avatar
Oddometer: 2,744
1) Why does the tensile strength of an O-ring matter? Granted it's an elastic material but I think your test is a stretch. (Pun intended.)
2) How come you didn't soak one in beer, one in bacon grease and one in mother's milk? This is ADV you know.
93 K1100LT "The Alien"
94 K1100RS "Kato"
87 K75C w/ Pichler Fairing
93 K1100RS w/ K1200 engine
05 KTM 450 SMR
IBA #17739 (SS1K, BBG, 50CC)
Link to some of my MC adventures
duck is online now   Reply With Quote
Old 06-09-2008, 03:48 PM   #6
xtphreak
from B4 "adventure bikes"
xtphreak's Avatar
Oddometer: 6,758
ok
what would you think should be tested?
compression?
hardness/softness?
abrasion resistance?
how would you set up a repeatable / measurable test for each?
this at least gives a representative data set for changes in the elastomer based on a control set and with multiple degrading fluids
Do one thing every day that scares you. Baz Luhrmann
Women and cats will do as they please, and men and dogs should relax and get used to the idea.
An armed society is a polite society. Manners are good when one may have to back up his acts with his life.
Robert A. Heinlen
Adventure is discomfort recounted at leisure. Flash / GSWayne
Chrome don't get ya home. Rob Nye
Stamp Out Hoplophobia in Our lifetimes.
1999 Tiger 885 - 1995 XT600E - 1992 TDM850
xtphreak is offline   Reply With Quote
Old 06-09-2008, 03:52 PM   #7
xtphreak
xtphreak's Avatar
Oddometer: 6,758
empty weight = 6 oz
Results of study:
ready to ride!
Keithm
which is what RK / Yamaha / Kawasaki say to use ... maybe the manufacturer actually does know best???
now consider that when I clean a chain with Kerosene, I wipe it clean afterwards, removing most of the kerosene, then I lube it, which no doubt displaces even more kerosene.
Same if I use WD-40 (sprayed on a rag, NOT on the chain).
Bottom line, kerosene (or WD-40) doesn't sit on the o-ring more than a few minutes, not days.
great test
thanks for the effort
Robert A. Heinlen
Old 06-09-2008, 06:06 PM   #8
duck
duck's Avatar
Oddometer: 2,744
Originally Posted by xtphreak
ok
compression?
hardness/softness?
I was just being hyperctrical for kicks. I suppose this test is as good as any but focusing on hardness and compression would be ideal. Or running 8 bikes 100,000 miles over ten years.
94 K1100RS "Kato"
05 KTM 450 SMR
Old 06-09-2008, 06:18 PM   #9
p_s
Nerdly Adventurer
p_s's Avatar
Oddometer: 204
It's interesting work. To be fair, you should run each test at least 3 times(and preferably much more) to see how much variation there is in the o-rings themselves or the experimental technique. I know that's three times as much work ... but maybe that's three times as good if you enjoy this sort of thing.
p_s is offline   Reply With Quote
Old 06-09-2008, 06:37 PM   #10
DirtyDog
Lust for dust...
DirtyDog's Avatar
Oddometer: 1,864
Thumb
Yep, REPLICATION is required for statistically significant results. But I'm sure you know that.
I'd like to see a similar test with various lubes. I'm sure the differences would be much less, but interesting, I'm sure.
JD 1999 KLR650 A13 Tulsa, OK
Ride Reports: Blessed Hellride, Lake Mohave, Greenback Valley, Reno Pass, Eagle Creek, Coronado NF
www.GreenHouseClothing.net
DirtyDog is offline   Reply With Quote
Old 06-09-2008, 07:51 PM   #11
DaFoole
Que la Chinga?!
DaFoole's Avatar
Oddometer: 1,258
Christ!! Even a guy with this much free time doesn't have THAT much free time....... Thanks for your work and thanks for the info!
"Scratching the wrong places since 1955!!"
"...when I handed the 40 ouncer to him, he got that far off stare that a cat gets when it just gets done licking its ass for the last 15". Yeah, THAT stare." -WTF-Over
Striving to beat Treadless's Post Count in '09!! Won't you help?
DaFoole is offline   Reply With Quote
Old 06-09-2008, 09:56 PM   #12
anonny
What could go wrong?
anonny's Avatar
Oddometer: 2,255
Your a genius! Glad you didn't do it all for me as 1 bike is belt drive 1 is shaft drive and the rest get cheap non o ring chains. Great read though.
anonny is offline   Reply With Quote
Old 06-10-2008, 01:53 PM   #13
Hardleft
Vomit is not a food.
Oddometer: 227
Amazingly good post. Thanks for putting in all of this work and sharing it with us.
Hardleft is offline   Reply With Quote
Old 06-10-2008, 02:57 PM   #14
Crisis management
Latte riders FTW!
Crisis management's Avatar
Oddometer: 300
Great test and good indicative results, thanks for taking so much time to do this so thoroughly!
So now it's clean with kerosene.....
Kabooms, a big one & a little one....
Well no, I lie, sold the 990 Adv, bought a 640 Adv but the baby boomers still there (200EXC)
Crisis management is offline   Reply With Quote
Old 06-10-2008, 03:14 PM   #15
30Bones
30Bones's Avatar
Oddometer: 3,384
People really care that much about chain lube? I use whatever I have on hand and even then I am bad about chain maintenance and have had 2 failures. Maybe I should steup up my regimin some.
2008 Husqvarna TE610
2006 Triumph Sprint ST
1974 Honda Trail 70
1994 Yamaha Razz
30Bones is offline   Reply With Quote
vB code is On
Times are GMT -7.   It's 05:48 PM.
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright ADVrider 2007
