Old 06-09-2008, 10:45 AM   #1
Gedjack OP
Oddometer: 94
Which High Fender.
As it says, which is the best high fender mod to go for. I am just about to do the 19" 17" wheel conversion and i think it looks better with the fender conversion. So which one is the best, and easiest to fit ????
Regards Gedjack
Gedjack is offline   Reply With Quote
Old 06-09-2008, 11:16 AM   #2
woodchuckexc
Oddometer: 801
the stock fender helps the bike run cooler. A high fender is for offroad. I love all you posers
woodchuckexc is offline   Reply With Quote
Old 06-09-2008, 01:04 PM   #3
Monty_Burns
Excellent.
Monty_Burns's Avatar
Oddometer: 1,297
Ged - I'll give you an opinion without attitude. You don't need a high fender with a 19/17 combo. The only reason to install a high fender is to provide more clearance for the front wheel in sticky mud. With the 19 front, you've got enough clearance that this won't happen.
Monty_Burns is offline   Reply With Quote
Old 06-09-2008, 02:11 PM   #4
Taurkon
Taurkon's Avatar
Oddometer: 755
My stock fender is sitting in a field after I finished unbolting what was left of it.
19" tires would probably not have caused the mud to clog up so much, but it's tough to tell. Never experienced clay and black dirt build up like I did yesterday. The D606 was not helpful in this case.
Taurkon is offline   Reply With Quote
Old 06-09-2008, 02:18 PM   #5
highlandcycles
highlandcycles's Avatar
Oddometer: 451
I broke my stock fender in about 1000 miles and decided to go with a high fender because I spend a lot of time offroad. I used a Super Moto Universal fender and cut the fork protectors off of the stock one. Looks alright and works well. I will probably use different fork protectors at some point, it was just faster to cut the original than fab something up. If you aren't going to spend much time offroad then I would use the stock one, it works really well and I think it looks good.
Just my 2 cents
Ni Siochain Go Saoirse
VIVA LOS MTNADS
www.highland-cycles.com
Highland Cycles
Montrose, CO
970-240-2197
highlandcycles is offline   Reply With Quote
Old 06-10-2008, 03:28 AM   #6
rubbercow80
Confused & Disorientated
rubbercow80's Avatar
Oddometer: 244
Its not just the fender that is the issue. The brake lines were also caught in the mud and were in danger of braking. Taping the right hand caliper to the left hand forkleg fixed the problem. It was the first time i had been caught in the mud on this bike and it may cause me to raise my original front guard a bit and replumb my brakelines.
rubbercow80 is offline   Reply With Quote
Old 06-10-2008, 05:42 AM   #7
LC8TY
must......find.......fuel
LC8TY's Avatar
Oddometer: 2,297
I went for the KTM high gaurd kit. It comes with everything you need, right hand brake line, fork protectors and the same gaurd as used on the 625 sxc. I cut off the the front section because it flops around a bit and looks like crap. The only problem is on wet tracks a bit mud flicks off the front tyre and covers the headlight. That shouldn't be a problem with a 19 inch front though.
Some men like the fish'n,
Some men like the foul'n,
Some men like to hear........
to hear the cannonball a roar'n!
LC8TY is offline   Reply With Quote
Old 06-10-2008, 10:22 AM   #8
Gedjack OP
Oddometer: 94
Can you get the KTM fender in black ????
Old 06-10-2008, 02:17 PM   #9
woodchuckexc
Oddometer: 801
YES
Old 06-11-2008, 07:46 AM   #10
Garand
Keeper of Useful Sarcasms
Garand's Avatar
Oddometer: 679
Check this thread if you're interested in doing it yourself
http://www.advrider.com/forums/showthread.php?t=296490
Here is mine with a Super Enduro Fender
and here is "rgmax" bike with a 690 Enduro fender
Garand is offline   Reply With Quote
Old 06-11-2008, 08:07 PM   #11
woodchuckexc
Oddometer: 801
to you guys who ride offroad and do so in the mud a high fender is a must but to spend that kind of money and then run a 19/17 combo with street tires makes no sence to me.There are a whole list of true performance parts one could buy with that money. Like say some nice floating rotors for those kick ass 19/17 wheels. Just a thought.$300 also buys a steering damper or suspension work or ............. $300 is alot to spend on a fender kit you dont need.
Old 06-12-2008, 05:31 AM   #12
Taurkon
Taurkon's Avatar
Oddometer: 755
I just ordered all the parts for a high fender for my 990... $120!
Old 06-12-2008, 06:01 AM   #13
Gedjack OP
Oddometer: 94
Where did you order that from ????
Old 06-12-2008, 07:35 AM   #14
Taurkon
Taurkon's Avatar
Oddometer: 755
Actually, I think I paid an extra $10 but ordered locally from Blackfoot Motorsports. However, the quote for $120 (a little under I believe) was from here:
www.ktm-parts.com
These are the parts I ordered:
1 7650801000030 KTM 690 Enduro Front Fender Black
1 4700109400030 FORK PROTECTOR L/S R/S 85SX 03
4 59001092050 SPECIAL SCREW M6X12.5 WS=8 .
4 0014060203 HH COLLAR SCREW M6X20 WS=8
4 54808020000 SPACER BUSHING
2 60013025100 - BRAKE HOSE GUIDE FRONT 03
2 60013025050 - RUBBER FOR BRAKE HOSE GUIDE03
Note, this will only work for the 990, and not the 950.
Old 06-12-2008, 08:06 AM   #15
bdefen
bdefen's Avatar
Location: Boise, Idaho - In the heart of Dual-Sport Paradise
Oddometer: 326
The 990 parts are cheaper...
It's my understanding that the 990 Adv. high-fender conversion is less expensive than the 950 Adv job because the 990 already has the dual brake lines coming from the handlebars/triple tree because of the ABS. So you don't need as many higher-priced components.
bdefen
Byron
'13 BMW R1200 GSW
bdefen is offline   Reply With Quote
Times are GMT -7.   It's 05:38 PM.
