Old 08-22-2008, 10:00 PM   #46
jsrider
Oddometer: 3,495
Originally Posted by woodchuckexc
the stock fender helps the bike run cooler. A high fender is for offroad.
My 950 spends most of its time on the road, but I have gotten stuck in the mud due to the front wheel gluing itself to the fender, so I'm interested in this mod. Does the bike run significantly hotter? Does a vented fender help? Other downsides (noise/handling/susceptibility to cross winds)?
Oh, and is this mod compatible with fork seal savers? I would assume "yes" but I'm a thorough fork newbie.
jsrider is offline   Reply With Quote
Old 08-23-2008, 03:00 AM   #47
alpheus
Italian Carrot
alpheus's Avatar
Oddometer: 80
alpheus is offline   Reply With Quote
Old 08-23-2008, 07:17 AM   #48
PABiker
Anywhere but here
Oddometer: 3,918
My bike runs no different, temp or handling, after the mod.
'03 Suzuki DL1000 V-Strom
'12 Suzuki DR650SE
'10 Husaberg FE450 Plated
PABiker is offline   Reply With Quote
Old 08-24-2008, 02:05 AM   #49
howl
990 Adventure
howl's Avatar
Oddometer: 98
Hi I fitted the std KTM MX high guard with vent holes drilled in it and the std brace , SX80 fork guards and had no problems with over heating or handeling up to 130 mph ( cloed road ect )
howl screwed with this post 08-24-2008 at 02:11 AM Reason: I can not see the the second pic . Help !
howl is offline   Reply With Quote
Old 04-07-2010, 03:41 PM   #50
CHRIS_D
CHRIS_D's Avatar
Oddometer: 966
Help with High Fender install 990 Adv
I started my high fender install today. The fender went on fine but I can't seem to get a handle on how to modify the left fork guard to work in conjunction with the ABS sensor. Do you end up cuting off the plastic arm that retains the wire to the ABS sensor so that you can get this guard to fit behind it? Which bolt holes on the guard did you use and which did you modify? If someone has a close up picture it would be really appreciated!!
Other options.... Has anyone use something like a rubber tube type cover for the fork instead (like they used on the KLR)? Or has tried cutting the OEM fender off and trim it down to leave the original sides as the fork guard portion? My big concern with this is that it may be to flimsy then.
2014 KTM 1190 Adventure R
2011 Victory Cross Country
CHRIS_D is offline   Reply With Quote
Old 04-07-2010, 04:35 PM   #51
a$$hole
a$$hole's Avatar
Oddometer: 992
Yup, I just trimmed the piece that holds the wire off and drilled a hole in the guard for a zip tie to hold the wire steady. Then I clearanced the corner of the guard to fit. And as far as the other bolt I made a oval shaped washer that has worked out very well and hasnt came loose in a few thousand miles. This was all done with 2003 SX 85 guards on an 09 990.
a$$hole is offline   Reply With Quote
Old 04-07-2010, 07:45 PM   #52
sven520
Oddometer: 94
Eh? Over the bars
I'm finishing up the high fender install tonight,used the parts list from PA
biker(thanks). I have been reading about broken fenders and front wheels being glued to the ground, but nothing about being thrown violently over
the bars. I wish i would have read that little tid bit. After about 126 miles of riding though mud and snow I heard a pop from the fender,that was the right side coming off. I didn't think much about it, I was cold tired and wet and
thinking of a warm fire and drinks. Anyways I hit a straightaway and gassed it
I remember hitting 3 gear then I'm picking myself up off the ground. Holy crap
that will ring your bell. The cross over brake line grabbed the front wheel and
locks it up. So before you ride in the mud change the fender
sven520 is offline   Reply With Quote
Old 04-07-2010, 08:44 PM   #53
G$
Lack of Adventurer
G$'s Avatar
Oddometer: 987
I ride a lot of off road so the raised front fender was a must for me. I had an old supermoto front fender lying around and it worked out great for me. I made several cuts with a hole saw to open up the rear of the fender for cooling. Here's a pic.
G$ is offline   Reply With Quote
Old 04-08-2010, 04:19 AM   #54
CHRIS_D
CHRIS_D's Avatar
Oddometer: 966
That's what I thought. Thanks for the pictures!!
Old 04-08-2010, 04:35 AM   #55
RickA
Fat Old Adventurer
RickA's Avatar
Oddometer: 87
High Fender 990
This is how I converted the 990 R - looks good in white I think.
RickA is offline   Reply With Quote
Old 04-08-2010, 08:07 AM   #56
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,754
Are the brake lines on the outside of the forks stock on a 990?
I'd be worried about ripping a line off when riding offroad.
How I've done mine:
Upper and lower guide so line runs straight up and down:
Old 04-08-2010, 10:29 AM   #57
Aquanout
Hooliganantic
Aquanout's Avatar
Oddometer: 748
Highness
My bike had a low fender and a high fender on it at some point in its life when I bought it, so the right side brakeline was already installed. I switch between the two because I really like the look of the low fender, it is just pretty useless offroad. Im going to make some tabs to raise the low fender an inch and see if I can get away with that.
Aquanout is offline   Reply With Quote
Old 04-09-2010, 07:09 PM   #58
carmima
All Orange :-)
carmima's Avatar
Oddometer: 2,951
Just did mine and used the Acerbis SuperMoto fender - it bolts straight on without any cutting or modification.
I also bought a set of generic KTM SX85 style fork protectors.
It all fitted really well and the job was down in about an hour.
I routed the ABS cable up the front of the protector as I didn't like the original routing around the side of the axle mount. I reckon where it was running originally, it'd get snagged on something if the bike went down on the left side!
These fork protectors have a join at the rear so it was easy to route the brake lines inside the protector and cable tie them to the fork leg
Nice clean look and cable routing
carmima is offline   Reply With Quote
Old 04-10-2010, 11:19 AM   #59
SSrider
SSrider's Avatar
Oddometer: 121
That looks great !! I have the same year and color bike. I was wondering who made white palstic. Do the fork gaurds only come in orange? Once again great job. I'll be copying you just so you know.
KTM 990
KTM 640
KTM 520
KTM 380
KAW klx650
Honda xr75
Honda trail 50
SSrider is offline   Reply With Quote
Old 08-25-2010, 11:03 AM   #60
Dusty
Dusty's Avatar
Oddometer: 1,300
Good shit in this thread for the 990 conversion, many different configs. Thanks for all the good pics of the abs sensor chop and different routings.
I need to find a fender that doesn't restrict the air flow to the radiator, trying the Acerbis SM next, the one i have now totally fuks the air flow.
Thanks to all, the closeup pics are wonderful...
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Times are GMT -7.   It's 05:58 PM.
