Old 10-11-2004, 12:48 PM   #751
PASSMORE
Just the last name...
PASSMORE's Avatar
Oddometer: 4,251
Originally Posted by meat popsicle
elevational changes. Any experience or sense of this stuff yet?
Meat - I ride regularly in Sacramento (basically sea level - 25 feet above) and in/around Lake Tahoe (6000+/- min.) and I do not feel an appreciable degradation in performance. I have the FCR41.
Please keep in mind that I may be too dumb to tell... Your mileage may vary.
M
- Michael
facebook.com/passmoreranch
PASSMORE is offline   Reply With Quote
Old 10-11-2004, 01:14 PM   #752
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,260
M
Thanks Passmore,
I wonder if they meant something more, like 8,000+? I know that's when humans start to get altitude sickness; dunno about carbs.
On a trip long ago over the Bighorn Mountains in Wyoming, my somewhat neglected 78 KZ1000Z1R just shut itself off when I came off the gas to pull over but started up again and kept going as long as i stayed on it. That was at 10K. I didnt really notice too much loss of performance, but I was gawking at the scenery so I probably wouldn't have noticed much.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 10-11-2004, 01:41 PM   #753
PASSMORE
PASSMORE's Avatar
Oddometer: 4,251
I do not know either - elevation wise... While most of the time is around 6000, I believe the passes are approaching 8k and I am undure of what the elevation is around Kingsbury Grade (anyone?). So to further clarify, I would say that at 8k and below I do not notice anything significant powerwise.
M
Thanks Passmore,
- Michael
Old 10-11-2004, 02:13 PM   #754
Renazco
Formerly AKA Boejangles
Renazco's Avatar
Oddometer: 4,742
Thanks for the info Mr. Boejangles!
BTW, your HP numbers... I thought the stock bike was supposed to put out ~44hp. I would search for this but with KTM LC4 and 640 all not workin with Baldy's new and redone search engine, I can't.
Someone correct me if I'm wrong on this one but I believe you add 15 hp on top of dyno results.
Renazco is offline   Reply With Quote
Old 10-11-2004, 02:23 PM   #755
PASSMORE
PASSMORE's Avatar
Oddometer: 4,251
Yeah, we were talking about that Friday - I have heard likewise (at the "crank" vs. to the wheel). I think Vrago said 13?
M
- Michael
Old 10-11-2004, 02:28 PM   #756
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
OK, your wrong. (you did ask)
A modern Dyno will take readings from the rear wheel and the computer software and sensor systems will correct it for variables. The final number(s) are HP/TQ... at the rear wheel.
I think Factory uses an Eddy Current Dyno; it is my understanding, as I have never used one side by each with a Dynojet, that their numbers are a bit lower on average than a Dynojet dyno. Not that it matters, as a dyno is more valuable as tuning tool rather than a comparing different bikes, locations, times, etc etc.... tool.
You can add a percentage, based on average drive line frictional and heat losses to obtain a "crank" HP/TQ value. Depending on who you talk to, a chain drive will be a 15% to 25% loss from crank to rear wheel.
So, lots of variables and apples and oranges and......
So... how's tricks?
creeper is offline   Reply With Quote
Old 10-11-2004, 03:02 PM   #757
kurtw
Child of the Wind
kurtw's Avatar
Oddometer: 209
So what does that seat-of-the-pants dyno say, anyway? How noticable is the difference (granted, the airbox and exhaust are changed too).
kurtw is offline   Reply With Quote
Old 10-11-2004, 03:13 PM   #758
meat popsicle
Ignostic
Oddometer: 14,260
So I guess the factory numbers were on the crank and yours were on the rear wheel... and creeper forgot to see the silver lining in that cloud he just floated (this is IF i understand creeper's tech talk): you are sittin on a bike that might be making 10+ HP over stock. Purdy dang good Mr. Boejangles!
Old 10-11-2004, 03:56 PM   #759
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Musical Dyno....
I recommend the "Duane Eddy Current Dyno" to all my friends....
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 10-13-2004, 02:31 PM   #760
seb416
seb416's Avatar
Oddometer: 19
Eek Fork Springs
Has anyone replace the standard 4.4 springs with stiffer ones, or cut the 4.4 to get em harder???
seb416 is offline   Reply With Quote
Old 10-13-2004, 03:05 PM   #761
Happe
Offroad Nut
Happe's Avatar
Oddometer: 684
My Rally Replica has 4.8 springs.
If you cut a spring it will be shorter not harder
Auf Wiedersehen
KTM Lc4 660 Rally MY98 pre e-start; KTM EXC450 MY14 Torque Rally Conversion; KTM EXC450 MY04 HDB Rally Light; Honda XRV750 RD04 MY91 AfricaTwin -for Sale-
Happe is offline   Reply With Quote
Old 10-13-2004, 03:37 PM   #762
BOXER1
Oddometer: 141
Pic from my ride today:
Ducati Streetfighter 1098S
BOXER1 is offline   Reply With Quote
Old 10-13-2004, 10:15 PM   #763
BlitzBike
LC4 Pilot
BlitzBike's Avatar
Oddometer: 800
Springs
I thought stock 48mm Adventure springs were .46???
BlitzBike
BlitzBike is offline   Reply With Quote
Old 10-14-2004, 01:51 AM   #764
Happe
Offroad Nut
Happe's Avatar
Oddometer: 684
I think we are talking about the WP Extreme USU Forks
Old 10-14-2004, 03:40 AM   #765
rapiti
IOR Veteran
rapiti's Avatar
Oddometer: 1,914
Happe has the WP 50mm USU forks. I believe Seb416 has a 2004 Adv with 48mm USD forks. Still, the advice against cutting is good, whether an apple or an orange Who knows a good source for .46 or .48 springs for the 50mm forks?
...its the best paint scheme that has ever been or ever will be on an Adv...-AussieRob
rapiti is offline   Reply With Quote
Times are GMT -7.   It's 01:28 AM.
